Chain broke twice tonight
Quoted: 30 Post(s)
Had just finished putting on a new set on Conti's and was all geared up for a ride when my chain broke literally 100 ft into the ride. So, I brought her back in, removed a link, and tried to head back out. Bam, chain broke again. Literally didn't even make it 5 ft. Took it out for about two weeks ago and everything was fine. Bought and installed the Reynolds R4's recently but haven't been able to test them, tonight was going to be the first time out. I'm baffled at what could have made the chain snap like that. The Reynolds did require a 10sp spacer for the hub, but that shouldn't have hurt anything. Everything ran smoothly until I tried to actually use the damn thing.
I'm a bit perplexed. Anyone have anything similar happen over the years? I'm running out of things to check and I don't want to buy another chain only for it to happen again.
Quoted: 5976 Post(s)
Liked 2,883 Times
I doubt you know for sure, but it probably broke at your splice.
Poor connections are far and away the most common cause of derailleur chain failure.
However, if it helps you, there are two main types of chain breakage.
1- pin/plate connection failure. This is caused by the plate being worked beyond the end of the pin, and you'll recognize it by an intact plate with the pin out, and the opposite side plate bent with the pin still attached.
2- broken plate. Almost always the outer, and you'll see the broken plate (the opposite side may be OK or not), with the fracture running through the hole.
The plates can be defective and the victim of poor heat treating, an undersized hole so the stress of the pin is too great, or other manufacturing issue. Or the plate can become brittle and fail because of chemical attack, usually by chlorides in chain wash liquid or road salt.
Plate failure is rarely isolated, and if a plate cracked at a pin, odds are you'll find other plates showing stress cracks at pin holes and ready to crack at a the slightest provocation.
If you had plate failure, the ONLY remedy is to replace the chain. However connection failures can be repaired by properly splicing in a link or two using a closure pin or connecting link.
FB
Chain-L site
FB
Chain-L site
Quoted: 252 Post(s)
The fact that you're just popping out links like it's nothing, are you using the dedicated joining pins or links, or are you just rejoining with the pins you pushed out?
Quoted: 30 Post(s)
The chain (Ultegra) was put on by someone who I bought the bike from. I've since made bunch of changes to it but never messed with the chain. He said it was a brand new chain when put it on, and seemed to know what he was doing. I've only ever really dealt with quick links so maybe there was something I missed with the Ultegra chain? It rode fine before I switched out the wheels though.
Quoted: 7713 Post(s)
Liked 3,645 Times
I know I have "fixed" a chain but hurried too much and didn't check every link ... and then "fixed" link was too tight and caused the drive to stutter. if I had kept riding it would likely have snapped there again. otherwise .. when I am mystified I blame the aliens. I can tell by who laughs and who looks nervous which people I can count on later ...
when the zombies attack.
Liked 2,883 Times
That's one failure accounted for, what about the other. I assume the second closure was yours, so unless you got the bike with a chain spliced together from 2 parts (two closures) then you need to check the mirror for the cause of the 2nd failure.
FB
Chain-L site
FB
Chain-L site
Quoted: 1422 Post(s)
Liked 7 Times
You can't just push out and push back in a pin on any Shimano 10 or 11 speed chain and probably not on other ones either, but I can't remember that far back.
You either use the special pin that comes with the new chain and break off the extra bit when done OR you use a SmartLink or other type of master link from KMC, SRAM or Wipperman.
The Infractionator
Bikes: Classic road bikes: 1986 Cannondale, 1978 Trek
Quoted: 875 Post(s)
I believe ALL Shimano chains REQUIRE that you use a dedicated snap-off pin when rejoining their chains. It's been that way for 20+ years.
Quoted: 30 Post(s)
Thanks guys. I've honestly never had a road chain break on me. Once on my mountain bike but I had a quick link with me.
Liked 2,883 Times
EVERY Shimano chain produced after the advent of Hyperglide and requires closing with a special pin.
Hyperglide and the other gated shifting systems that followed (all brands) tends to force outer plates outward when shifted under any kind of load. So the pins need to be peened over the plates to resist that. When you push a pin out, you shear off the pin, and there's no practical way to fix that.
FB
Chain-L site
FB
Chain-L site
Super Moderator
Quoted: 1175 Post(s)
Liked 937 Times
Use a quick type link. Problem solved. Don't let that guy work on your bike.
that bike nut
Bikes: 2010 Motobecane Immortal Force 90' Trek 1400; 90' Trek 850; 06' Trek 520; 01 Iron Horse Victory
Quoted: 25 Post(s)
I pretty much always use a SRAM of KMZ quicklink and carry one in my saddle bag. I've used the Shimano connecting pin one or twice with ok results but if it is not installed well it will fail and I've seen several fail. You have to be very careful with them. As others have said the push out/in method is an emergency temporary measure of last resort when you fail in the middle of nowhere without a quicklink and need to try and make it home and then trash the chain afterwords.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
OP...you mentioned a wheel change and the dreaded spacer....is there a chance your der stops not set correctly for the new spacing...and your chain overshifted into the gap of the dropout?
Don't the newer Shimano chains ship with a quick link link? Or am I remembering wrong?
Yep.
Liked 2,883 Times
But that misses my point, which was that whether you use a designated splicing/closing pin or connector, you CANNOT properly cut and splice or close a chain by pushing a pin back and forth like we did before Hyperglide.
FB
Chain-L site
FB
Chain-L site
Liked 406 Times
I don't believe that Shimano has moved to a connector, as have Sram, KMC, and Wippermann. Last I looked, Shimano and Campy stayed with a pin type system.
Shimano introduces Quick-link for 11-speed chains | Bicycle Business | BikeBiz
Very true on re-using pins though ofc.
Liked 2,883 Times
I remembered it being announced in the spring, wasn't sure if it hit QBP/retail yet
Regardless of what Shimano provides, you already had the option of using a connector from another company.
The point isn't what the options are, just what they aren't.
FB
Chain-L site
FB
Chain-L site
Quoted: 30 Post(s)
A lot of good info here, thanks again. I may have missed it but can you use an SRAM or KMC with Shimano? I'd like to stick with the quicklink if possible.
Quoted: 30 Post(s)
Thanks again all, I'll be sticking with KMC this time round I think. The proprietary stuff on Shimano irks me for some reason.
Quoted: 30 Post(s)
Ok, then here's another question. Can you use the other quicklinks with Shimano chains? Again, apologies if this was obvious from previous posts.
Portland Fred
A bit spendy, but by far the easiest to use. Plus you can use one link for at least 4 chains so the TCO is actually quite cheap.
Quoted: 30 Post(s)
Awesome thanks, I'll definitely be checking them out in the future. Actually just ordered a KMC X10 SL in gold for a little bling factor. Fingers crossed!
that bike nut
Quoted: 25 Post(s)
Yes all chains of the same speeds are the same width (other than Campy vs Shimano/Sram). I've used both SRAM and KMC quicklinks with Shimano chains.
