What's the scoop on Rotor Q-Rings?
Bikes: Steel 1x's
Quoted: 632 Post(s)
A nearby LBS is pushing several riders in our group to change to these oval, elliptical, Rotor Q-Rings saying they are better all around.
What is BF's take on these things?
Middle-Aged Member
Bikes: Bianchi Infinito CV 2014, TREK HIFI 2011, Argon18 E-116 2013
Quoted: 24 Post(s)
They suck. I ran them for a few years and went back. I have a more comfortable pedal stroke now that I don't use them.
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
Middle-Aged Member
Quoted: 24 Post(s)
Yes. I hated the super exact settings necessary to actually be able to up-shift. Even then it was a crapshoot. Once I went back to round (praxis incidentally) and I initially set the FD it shifted precisely. Fine tuned it and it shifted on a razor blade (metaphorically I suppose).
Bikes: Steel 1x's
Quoted: 632 Post(s)
So shifting in front was an issue. Was it positive aside from that?
The LBS is putting them on 1x setups. No front DR.
Gold Member
Bikes: Pinarello Dogma F8, Pinarello Bolide, Argon 18 E-118, Bianchi Oltre, Cervelo S1, Wilier Pista
Quoted: 34 Post(s)
This is a myth, there's really nothing to it. You just measure above the highest point and that's it. I have them on both mechanical and electronic groupsets, and it doesn't take any longer to set up than with round rings.
To the OP: I use them on all of my bikes except my fixed-gear track bike. Luddites on BF who have never tried them will say that they don't work, yet strangely enough every time I go to one of my time trials I see them all over the place and most of the fastest guys using them. I won't try to convince you though, since you probably already have your mind made up and BF collective ignorance will dominate the conversation anyway.
Middle-Aged Member
Quoted: 24 Post(s)
My biggest hate on it was my threshold cadence around 110. when you bottom out the pedal stroke the crank whips your foot past the 6 o'clock up to 9 o'clock because the load on the pedal decreases so suddenly. At high cadence and descending it was a very lurching sensation. Climbing, down at threshold cadence below 50, was a dream though
They're the crabon of chainrings. Make of that what you will.
EDIT: No, I have never used them Would like to give them a try, but not willing to spend for it.
Quoted: 30 Post(s)
Middle-Aged Member
Quoted: 24 Post(s)
