Giant ATX 760, bottom bracket is smoked
Hey guys, long time lurker. I was a lot active a few years ago when I used to bike a lot more often, cars basically took over my life and I'd love to hop on the back of my cycle.
I have a 1996 Giant ATX 760, and I need a bottom bracket, bearing assembly, whatever you'd like to refer to it as. Obviously I need to replace the unit, can anyone point me in a direction? I have a newer set of Shimano Cranks that I put on after my old ones bit the dust.
Thanks guys! Please consider my ignorance, its been awhile. I can provide any specifics, measurements, etc if needed.
Quoted: 4239 Post(s)
Liked 3,975 Times
Yes, all specs will be needed. Photos help a lot to filter out the initial nonsense. Andy
I just googled "giant atx 760 bottom bracket" and found
1996 Giant ATX 760 - BikePedia
Shimano BB-LP26, 113 mm spindle 68mm English
Hope this helps
Hope this helps
Really Old Senior Member
Spindle length may be different or not.
What model # are the new cranks?
Quoted: 454 Post(s)
Liked 104 Times
Hope this helps
Hope this helps
We need the OP to come back with details of what is fitted today, not when it left the factory.
The OP said the crank has been changed (to a new set of Shimano, which could mean still Square Taper, or HT1, or HT2), so what was originally fitted may not have any relevance to what is currently fitted.
Quoted: 454 Post(s)
Liked 104 Times
Like I also said, more info is needed from the OP with exactly what is fitted today.
Liked 3,975 Times
Funny how the two shortest replies hold the greatest solutions. Andy.
Quoted: 454 Post(s)
Liked 104 Times
None of the reply's (less #AnkleWork) are really any use (and then that seems to have been too obvious) without the detailed info from the OP as to what is currently on the bike (which most of us, including you have asked for), till we know that, it's all guess work, with a little knowledge from what was available during the time frame given.
Hope this helps
Hope this helps
Likes For Bill Kapaun:
Liked 3,975 Times
Which is why besides the specs (as actually on the bike) photos are a good confirmation or corrective data. Again the short replies ring true. Andy
Likes For Andrew R Stewart:
I bought a 68x113 Shimano UN300 BB based on that bikepdia post/above poster's response, and can confirm it is a 73x113... granted it's now 2024, but the info still holds. My ATX 760's BB was also "smoked". Can't wait to put this frame back together. It was a $40 (Correction, I overpaid at $60) buy from an unhoused person and should last another 2 decades with a new BB/chain/derailleurs. Super stoked. Thanks to the OP, who was apparently also smoked? this thread was a wild ride; I hope the unhoused person I bought it from got to spend the $ on helping himself.
and it is indeed INCORRECT.
Ignore List
Also, I only have 4 posts on this forum, feel free to put me on the ignore list. Hopefully the next AT760/770 owner can get the correctly sized BB. Have a blessed day.
