Wahoo Chest Strap Acting up x2
anyone have same situation. getting readings on both my gamins of too low of HRT. like under 100 all the time
changed battery,
did a hard reset as well
wash the strap.
took care of it
seems nothing worked
anyone have similar situation
changed battery,
wash the strap.
took care of it
Don't know, but you should call Wahoo. My Garmin chest strap started acting up, I called them, and got a new one in the mail in a few days. There isn't much you can do to fix a misbehaving one as a consumer.
Never had that issue with a BlueHR or TICKR. Call Wahoo.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Liked 122 Times
This would be my suggestion as well. Since this problem is happening on two different Garmins, you can rule out the Garmins as the cause of the problem. I've got my TICKR connected to an iPhone and haven't had any issues with it. Wahoo should replace it for you.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Bikes: Scott CR1 Comp
I had irregular reading with my polar chest strap and I changed to another brand and still had a problem turned out the the problem was with my heart. Apparently certain types of irregular heart beat can cause problems as the electrical signals are somewhat screwed up. It might be something to check if you have a problem with multiple units.
I was getting a lot of dropouts and errors with chest straps (Garmin and Suunto) until I started using this conductive adhesive found on Amazon - "Tensive Conductive Adhesive Gel - Parker Laboratories - 50g Tubes". It's not really that sticky but it gives a good contact. It rinses off the strap with a little water.
