Any Trek carbon frame owners have the BB play issue?
Bikes: 2016 Trek Domane 5.2
Quoted: 29 Post(s)
Back in late September my 2016 Trek Domane 5.2 developed play in the cranks after only about 750 miles. The LBS I had just purchased it from brand new two months before said it was because the bottom bracket shell was just slightly too large for the BB90 to maintain a snug fit. This is apparently a fairly common issue with Trek carbon road bikes, and Trek has retrofitted some slightly larger BB90s to resolve the problem. The LBS installed one of these N/C, so I hoped the problem was resolved. I checked the cranks for play every few weeks, and everything seemed fine until a few days back I noticed some left foot and ankle discomfort while riding. At first I thought my cleat had moved, but after repeated adjustments it still didn't feel right. Then I remembered I hadn't check the cranks for play lately, and sure enough, they had 1mm or so of play, which may well have accounted for the discomfort.
So with just 1204 miles, back to the LBS I go and I'm told the BB shell was too worn to fix the problem, and a new frame would be needed. I was told to expect it to take 2-3 weeks minimum, and should know more in a day or two. I really love the bike, so am hoping I'll get squared away soon. Most importantly, I hope they can provide some assurance this won't be a recurring issue.
Anyone here had a similar issue with their Trek that can give me an idea of what to expect?
Shouldn't this be on the carbon fiber sucks thread?
Likes For texaspandj:
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Trek has a lifetime warranty on the frame so i'm sure it will be delt with. it just sucks that you will be without a bike for a month or so. Maybe the LBS can give you a loaner.
I had a Madone 4.6 and put 15k on it before upgrading to a Emonda SLR and just hit 11,000 miles in 2 years. neither had a single problem. My son races a Madone 6.5 and never a problem.
***** happens and sometimes there are defects.
I've got 4 (less than 4 year old) carbon Treks in my garage with mileage varying from 150 to 6000 and none of them have any issues. I've personally sold north of 30 carbon Treks at the shop this year (34, actually) and none of them have come back in for any issues.
We've seen one bike this year with an issue similar to this and Trek had a replacement frame (albeit in a different color, but same model tier) out to us in less than a week. Note: the customer approved the color change.
Based on stock levels, what the frame is, I don't think 2 to 3 weeks is unreasonable. We were very surprised that the swap on our customer's frame was so quick. Typically it's 2-3.
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
I have a carbon Trek with a SRAM BB86 GXP bottom bracket. I've never had any play, and to be honest I've never even removed the crank since the bike was new 4 years ago. The bearings still feel smooth so I haven't bothered.
Quoted: 2355 Post(s)
Liked 5,329 Times
Man,it's been years but I had that once with either the Madone 4.5 or the 5.9. I just don't remember. But it was a one time deal fixed by installing a bigger one if I remember correctly.
Bikes: '86 Centurion Elite RS '17 Trek Domane SLR6 Disc '16 Trek Boone 5 '15 Trek Fuel EX 9 '20 Trek Checkpoint SL6
Quoted: 25 Post(s)
I've had two Domane 5.9 frames, the first had about 5000 miles on it before it was replaced (for a completely different reason) and now the replacement has about 4000 miles on it. Neither have had this issue.
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 649 Post(s)
Liked 139 Times
my 2010 madone eventually developed a slight creak, but no "play". My new Emonda is totally fine. Loctite to the rescue, but I'm not so sure that will work if you are talking about actual play in the cranks, that was an issue a long time ago when they first developed the BB90, but haven't heard of that in any of their newer models.
My 2014 Domane has had the right crank arm fall off while riding 3 different times. LBS tells me it is because the bearings are not quite tight enough in the bb shell. Supposed to be press fit, but from what I understand, there was very little pressing needed to put the bearing back in (right side only). Last time the crank arm fell off was this summer and have not had the issue since.
Kinda hoping it does break again so I can have an excuse to get the SLR frame
![Smilie](images/smilies/smile.gif)
Quoted: 29 Post(s)
Then today the same guy said he decided to Loctite it after all, and after stress testing it on some hills, he's confident the problem's solved.
Me, not so much. I don't know why he'd say it was too far gone to Loctite, then turn around and Loctite it after all. I'm thinking he was told to do that by the warranty guy. Going to pick it up tomorrow and stomp on it on some big hills.
Likes For Gasser5.2:
Quoted: 6556 Post(s)
Liked 58 Times
They originally told me over the phone they were going to Loctite Green the BB and that should fix the problem. But when I brought it in the same guy looked at it and said that wouldn't work because the shell was too worn, so they'd have to warranty it.
Chases Dogs for Sport
Gasser, during this process of warranty assembly/disassembly/diagnosis, does the bike shop charge you for labor? (My LBS would, so I'm curious to see if that's normal.)
Quoted: 29 Post(s)
Just bring one of your crank arms up to 12 o'clock and rock it towards you and back toward the bike to see if there's any play. You'll feel the play through the crank arm if there is any.
Quoted: 29 Post(s)
Absolutely not. I've never heard of a shop charging labor when there's no dispute something is covered under warranty.
Quoted: 2660 Post(s)
Liked 3,227 Times
Unless things have changed since I worked in bike shops, most, if not all, bike companies selling bikes in the US cover labor on warranty repairs for the first year but not thereafter.
Quoted: 29 Post(s)
They're looking at the Loctite as the permanent fix, but have assured me in writing if it doesn't work they will replace the frame. For now, that's good enough for me as they've always done right by me in the past. If I do end up needing a new frame I'm going to insist on a free bike fit for my trouble.
Things must have changed. Look up the Specialized warranty. "Owner must pay the cost of all labor" and "all work must be performed by an authorized Specialized dealer." Dumb.
Quoted: 29 Post(s)
Just a follow-up. The BB loosened up again, so I took the bike to my LBS last night and they're going to warranty the frameset. Was told to expect a minimum turnaround of 3 weeks.
Agreed. If a slightly over size BB isn't even working, this seem like a bodge. Temporary fix at best. Imo, and all that ...
Oh! sorry, wast realising I was replying an old post above. Im happy you will get an other frame. If the press fit isn't securing the BB in place the frame is likely out of spec anyway.
Quoted: 29 Post(s)
Just to update - rather than replace the frame, Trek built up the BB shell with additional carbon fiber to provide a snugger fit. I haven't had a chance to log too many miles on it yet, so we'll see if this provides a permanent fix.
Five and Dime
Quoted: 15 Post(s)
Ah, the BB90 demon strikes again. I have the same frame, and I was hoping Trek had sorted through their "stretched" bottom bracket issues, but apparently not.
