Modern Wheelset on Vintage Bikes?
Anyone running modern wheelsets on your vintage bikes? Im assuming it will have to be vintage hubs (126mm) on modern wheelsets.
Quoted: 3471 Post(s)
Liked 2,846 Times
Lot of 120mm spaced frames running around here too.
Stuffing a 130 hub into a 125-126 frame can be done, indexing may suffer without realignment of the dérailleur mount. Italian frames and those makers that blacksmith end the drive side rear dropouts as the Italians often did would be best to take advantage of the full cog range. Often clearance problems otherwise.
I put a 130 hub in my 126 spaced aluminum Trek and have no indexing issues with the 10 speed Tiagra group I'm using.
Front indexing did suffer but I think that was due to chainline. I just needed a touch more range on my front to not get rubbing. Ended up going to a friction shifter.
Quoted: 5939 Post(s)
Liked 3,665 Times
Spreading a bike from 126 mm to 130 mm is not a big deal esp. if talking about a steel bike. There is a long thread on BF about vintage bikes with modern groups.
https://www.bikeforums.net/classic-vi...i-s-ergos.html
feros ferio
Quoted: 1410 Post(s)
Liked 1,367 Times
Yet another example of why I detest front indexing.
Yup I put 130mm hubs on my Cuevas and will be doing the same on my Bertoni when I get to that point.
Bikes: '74 Raleigh International utility; '98 Moser Forma road; '92 Viner Pro CX upright
Quoted: 939 Post(s)
Liked 5 Times
Phil freewheel hubs 126mm with Synergy rims (asymmetric rear) on '74 Raleigh International
My daughter's '86 Team Fuji spread from 126mm to 130mm using BHS hubs and Kinlim rims (built by Hoops), Ultegra 9-speed
this little spread does not require cold-setting
and a '78 Strada-clone crank
My '92 Viner CX has Miche RG2 hubs, Open Pro rims and a 2x9 wide compact double.
Quoted: 1628 Post(s)
Liked 635 Times
Steel is real (flexible). I swap in and out 130 OLD hubs a lot on my 126mm steel bikes and it's no big.
Got a couple of late 80s aluminum Cannondales that are ostensibly 126 but actually more like 128 so they take the 130s just fine, too.
Bikes: Focus trash find commuter, Eddy Merckx Corsa, BP Stealth TT bike, Leader 720 TT bike, Boardman Comp Hybrid drop bar conversion, Quantec CX budget cyclocross build, SerottaNOS frameset ready to build up!
Quoted: 130 Post(s)
Liked 106 Times
That Sugino wide double looks bloody awesome for a commuter.
Not lost wanderer.
Quoted: 901 Post(s)
Liked 1,049 Times
I am running a Deore LX rear cassette hub on my 83 Centurion Pro Tour. Took a bit of a grunt to cold set the rear to 132 and a squeeze to get the wheel in. Search for a Centurion Pro Tour and you can see mine.
https://www.bikeforums.net/classic-vi...-pro-tour.html
Bikes: 1974 Copper Raleigh International, 1975 Olive Green Raleigh Grand Prix, 1974 Raleigh Europa Custom
Quoted: 104 Post(s)
What??? Only 2 wheels?
Quoted: 1225 Post(s)
Liked 658 Times
If you use a modern wheelset built with vintage 126mm hubs is it still all-original? Oops, wrong thread. I mean, is it still modern?
(Of course, I'm asking the philosophical question what is a modern wheelset?)
Real cyclists use toe clips.
jimmuller
jimmuller
Quoted: 939 Post(s)
Liked 5 Times
thank you, friend - always have a plan, and I swear it's always form follows function, and if it looks good, too, so much the better.
If I'm not adjusting cones on and off the bike to get them dialed in, yes, it's a modern wheelset.
But I like my less than modern C-record hubs, too - even though they're 130mm rear axle.
I was in one LBS one day on this bike with my buddy and some transaction he was doing. The head mechanic saw these hubs, and brought his whole staff by for archaic show-and-tell
My turn for a rhetorical question - does running Boca SiN loose balls lose its antiquity?
Quoted: 665 Post(s)
Liked 491 Times
And for anyone wondering, 11 speed hub and cassette working fine on my Raleigh with 126mm spacing. Really tight clearance at the seat stay in smallest cog but chain still clears. 105 front derailleur indexing and trimming with no issue.
Quoted: 939 Post(s)
Liked 5 Times
that one is tight, massive dish, and no offense, looks like chain-suck city - what's your smallest rear cog? (you know better than us whether it works...)
Quoted: 939 Post(s)
Liked 5 Times
It would be, bro. I live in serious hills - 400' climb with up to 14% grade to get home. Miche custom cassette for this:Mike Sherman's Bicycle Gear Calculator.
I set up the cassette with 5 narrow cruising gears and 4 wider climbing gears, and switch to the granny for for narrow climbing steps.
Most of the time it works mindlessly as a 1x9
shuru421, IME just installing a hub with 130 mm OLD in a frame that measures 126 mm works well without cold setting...cold setting for this change isn't required. Harris Cyclery does, or used to, suggest that a 126 mm OLD hub will work in a frame with 120 mm spaced drop outs without cold setting. Going from 120 mm to 130 mm will probably require cold setting, but I haven't done this so I'm not positive.
Most often a classic looking rim is used, but something more modern can work well and be attractive, in this instance decals are often removed if they clash with a build theme.
Brad
PS Closely inspect the rear triangle for any existing defects that may cause a failure whether simply installing a wider hub or cold setting.
PPS This subject can cause debates/
Brad
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
this little step does not require cold-setting
Quoted: 939 Post(s)
Liked 5 Times
agree and, again, it's form follows function. I want all the qualities of steel frames, and you can't go out and buy new frames of this quality for $200-$300 (even $500).
I realize there is another school of pure-period/catalog-correct collector, where form matters more than function.
I've just never been in that school. My first steel bike was a door for improvement, never intended to be a museum piece.
To me, all bikes are platforms for good tires.
feros ferio
Liked 1,367 Times
Note that most of the examples in this thread have traditional-looking wheels, which I define as having at least 32 spokes per wheel. I did a similar upgrade on my mountain bike, replacing the original 32-spoke 7-speed freewheel wheelset with an 32-spoke 8-speed cassette. I prefer the look of my new wheels, because the originals had black anodized rims.
Quoted: 576 Post(s)
Liked 619 Times
I agree with all of the above but if you don't want to or shouldn't (aluminum frame) mess with cold setting I would add that the Sheldon Brown mod of changing out a 6 or 7 speed 126mm Shimano freehub body for a 8,9,10 body has worked beautifully for me. I can usually get new Ultegra bodies for under $20 on ebay or even pulled from a newer hub with ruined races for next to nothing.
Quoted: 939 Post(s)
Liked 5 Times
Black, aero, decorated rims are ok - to me, when it gets out of line is when the wheels become the subject of the bike
Quoted: 939 Post(s)
Liked 5 Times
Quoted: 475 Post(s)
Liked 8 Times
Thanks again.
