Hybrid for Adventuring
Bikes: Specialized Crossroads Cruz 1994
Quoted: 15 Post(s)
Hi everyone,
I have a quick question about bikes recommended for adventuring. I am relatively new to the cycling world and am looking for a good bike for adventuring on paved roads, dirt paths, and gravel. So are there any bikes recommended for this use? Also, what should I look for in a bike for this purpose as well?
Thank you everyone, for your help!
Quoted: 185 Post(s)
Liked 38 Times
Hi everyone,
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
My opinion fwiw.
For many, maybe most uses except mountain biking, any bike that can fit at least 32mm tires is going to do okay, and it's just up to you how you want to sit. Lots of hybrids come with 35-38mm tires so they do okay too. Pay at least enough to get away from Tourney components and 7-speed freewheels. You can have a suspension fork if you want but it's heavy and probably not necessary and the ones on cheap hybrids aren't great.
If you intend to run over anything suddenly or leave the ground at all, buy a hard-tail mountain bike with sturdy components and a real suspension fork with oil damping.
Genesis 49:16-17
Genesis 49:16-17
you should read thru this thread, you will find some relevant posts therein:
https://www.bikeforums.net/road-cycli...omponents.html
Bikes: 2013 Trek 4.7 Flatbar Madone, 2018 Giant Roam 2
Quoted: 103 Post(s)
Since you said "adventure on paved roads, dirt paths and gravel", I would say get a Trek DS or Specialized Crosstrail with suspension lockout. If you don't like Trek or Specialized, get similar bikes from other brands, like the Cannondale Quick CX, etc... Just make sure it has the suspension lockout.
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
Hi everyone,
These things matter. Some people say they want to do some off roading but find in practice, 95% or more of their riding is paved trails or roads. Others might want to do some aggressive single track, but also plan to use their mountain bike for riding around town or to the trail.
Quoted: 15 Post(s)
Hmm. Adventuring? What do you mean by that? Are you looking just for something to ride? Or are you picturing some loaded off road touring? How far are you looking to ride? And how fast? And how much of each surface do you anticipate riding? And when you say dirt and gravel roads, are they fairly even and groomed or fairly rugged?
Liked 208 Times
This is not an exhaustive list. I am sure other bikes might work, but any of these will fit the bill if they fit.
Señor Member
Quoted: 649 Post(s)
Liked 294 Times
Any hybrid bike will work for what you want to do. Don't take the brand-specific recommendations too seriously as the bikes are all made by the same contract manufacturers in Asia until you start looking at some seriously expensive rides.
The primary difference between the various models of bikes is fit - some have a very upright seating position and some have a more stretched out position and some are in the middle. You decide how you want the bike to fit. Stems and handlebars and seatposts can be swapped out if the bike you get needs fine-tuning after you ride it for a while.
Within the different model lineups there are usually quality levels such that the more expensive ones have components that last a little longer and stay in adjustment a little better. Find a shop you like that sells a bike that fits you, then select the one that fits your budget.
Personally I think you should avoid suspension forks for the type of riding you are doing as it is just another moving part that can fail while adding weight and cost but providing little benefit (especially on roads), but many people disagree with me.
Quoted: 15 Post(s)
Thank you for the list! So I have a specialized crossroads cruz at home from the early 90s and was thinking about converting that into a gravel bike, any thoughts?
Quoted: 15 Post(s)
Well I was considering putting drop bars on and changing out the tires, the bike currently has a flat bar and wider tires that would not be useful for both road and gravel. However, I know putting on drop bars would be a lot of work since the gears are not self trimming and I would have to install new braking levers.
Quoted: 13 Post(s)
I mostly use Jamis, they have some nice hybrids, I went back to steel with a Coda elite for the 400 mile Erie trip this Year, great all around. Allegro for a more livelier feel etc, every body has Treks, they must be good...
Señor Member
Quoted: 649 Post(s)
Liked 294 Times
Liked 208 Times
Quoted: 15 Post(s)
Ok, I was starting to figure out the classifications of the bike I was looking for but that helps a lot!
That's true that it would cost more than the bike...
Bikes: Giant ToughRoad Giant talon
Quoted: 705 Post(s)
If you plan riding 80% on paved roads you might find suspension a drawback, especially if you like to ride fast. I say might because some people hate the loose feeling, the bobbing (even with a lockout) that is continual. Others don't mind this. If in doubt get a rigid fork like the Giant Toughroad or ROAM would be my suggestion. If you have pockets full get two.
Quoted: 15 Post(s)
I do like to go fast on both pavement and gravel, and I think it will be about 50 50 for gravel and paved.
Quoted: 15 Post(s)
Fast on the road would be about 20-25mph and fast on gravel would be about 15-20mph, however I need to build up my stamina in order to keep that pace for longer distances.
Liked 208 Times
If you can go 25 mph for 60 miles on an old Cross Trail, you should consider turning pro. Seriously.
