Putting 700c wheels on a old frame that had 27" wheels
Bikes: Pedal Force ZX3
Beside the 126 mm rear spacing issue, what issue will I have with putting modern 700c wheels on an old frame that normally had 27 inch wheels, will they fit?
Minneapolis
Bikes: 1998 Stumpjumper Pro, SE Draft, 1984 Bianchi ATB, 1980? Raleigh Comp GS, Civia Loring
The distance to the brake hole will increase 4mm, which needs to be accounted for in the "reach" of your calipers.
feros ferio
Liked 1,373 Times
An expensive option is an offset "drop bolt," which will allow you to use calipers with shorter arms. However, every 1960s or 1970s bike I have owned had long enough brake caliper slots to accommodate both sewups (700C rims) and clinchers (27" in those days).
cab horn
Bikes: 1987 Bianchi Campione
Liked 29 Times
They'll fit, brake issue mentioned above. I'd just get good quality calipers with long enough reach, try harriscyclery. That and you'll have a bigger gap than otherwise on the brake bridges.
