Serial number ID on Sekai 3000: What was the year of manufacture?
Old 12-29-16, 09:52 AM
Oregoner
I want to determine what year my bike was manufactured. My hope is that someone here has a list of Sekai serial numbers or an eighties catalog or two that advertises this model number with the same components.
The original components still on the frame are all mid eighties from what I've been able to discover:
Sakae/Ringo Sp100AL pedals
Sakae/Ringo Custom P5 Laprade fluted seatpost
Sugino Gt Crankset
NITTO 115 bars
Technomic stem
Araya 27x1 aluminum rims
Suzue hubs
Suntour arx front and rear derailleurs
Suntour Symmetric downtube (suicide) shifters
DiaCompe AC500 brakes
As for the frame itself, the decal reads, "champion no.2 chrome molybdenum butted tubes tange industries ltd."
No proper head-badge, just a a decal. Same for all markings save a painted Tri-Comp on the forward end of the top tube and the serial number, which is as follows; M4B00317
Oregoner is offline
Old 12-29-16, 02:20 PM
dazevedo
Look thru this post should give you a year
https://www.bikeforums.net/classic-vi...-database.html
dazevedo is offline
Old 12-29-16, 05:28 PM
cdmurphy
cdmurphy's Avatar
Bikes: Too many, but sometimes not enough.
Quoted: 225 Post(s)
Liked 18 Times in 14 Posts
Yours is almost certainly an '84. That serial follows the format for the "Miki" built Sekai bikes, as well as many of the top end Centurion frames. (I have a 76 Centurion Semi-Pro, which is essentially identical to the Sekai 4000 from the same period.)
Can you post some pictures of your frame? There doesn't seem to be much out there about the 3000 model. (Possibly a similar frame to the 4000, but without any chrome, or maybe down spec'ed components?
- Cameron
cdmurphy is offline
Old 12-29-16, 05:34 PM
cdmurphy
cdmurphy's Avatar
Quoted: 225 Post(s)
Forgot to mention it could be either a '74 or an '84 based on the serial, but there doesn't seem to be any mention of a Sekai 3000 before the mid 80s. Also, I don't think there was a Tange Champion #2 back in 74, I think it was just "Champion" until the late 70s and they started to differentiate their tubing a bit.
The leading "M" is for Miki, then "4" is the year, then "B" is the fortnight, ie 2nd week of January, 1984. The number after that is a sequential serial number, but I'm not sure if it's per fortnight, or follows through the year. (T-Mar would be the one to ask, as he deciphered most of this for Centurion and Sekai bikes among others. Thanks T-Mar!)
- Cameron
cdmurphy is offline
Old 12-30-16, 10:57 AM
T-Mar
Quoted: 4722 Post(s)
Liked 3,049 Times in 1,884 Posts
It's definitely 1984. In 1974, Tange did not not use the number classification on their decals to differentiate between tubesets. The SunTour ARx derailleurs were 1982-1986 and the Sugino GT came out in the early 1980s, so everything points to 1984.
The serial indicates the 317th frame manufactured during the second fortnight (i.e. weeks 3-4) of 1984. There were two manufacturers who used this format but Miki of Japan was a known manufacturer for Sekai, so it is almost certainly a Miki product.
T-Mar is offline
Old 12-30-16, 01:31 PM
Oregoner
Wicked, thanks all. I'll comment again tonight/tomorrow with frame pics, so if there's anything specific you'd be interested in seeing in the center of the shot let me know.
Oregoner is offline
Old 01-02-17, 03:53 PM
Oregoner
Oregoner is offline
Old 02-21-17, 04:42 PM
Duke of Prunes
Bikes: '85 Miyata 610; ‘84 Centurion Pro-Tour 15; ‘81 Univega Specialissima; ‘78 Raleigh Super Course; '94 Trek 850
Quoted: 17 Post(s)
Liked 6 Times in 2 Posts
A close Sekai 3000 Pro Comp cousin
I'm glad to find this thread, because I just picked up a similar vintage (same year, same model, same fortnight) Sekai 3000 Pro Comp, S/N M4B00246, for $85 that, with an hour of Simple Green scrub, looks to be pretty pristine, though not the same assortment of components my peer Oregoner reports. Did Miki/Sekai/Norco sometimes dig related parts out of a bin if others weren't on hand, or were some frames assembled at local shops (I'm in Madison, WI, so likely Yellow Jersey here) that may have substituted? I'm sure the wheels are newer, but not sure why Shimano 600 rear derailleur and shifter, but Suntour front. And the seat post and downtube decals are fer **** --I'm inclined to heat them off, unless that is considered sacrilege, no matter how hideous the design is. At 54cm, it's too small for me, so I'll probably clean & re-grease and sell it on the relatively competitive spring Madison market.
Oh, hell...the forum doesn't allow me to put in links to photos because of my n00b status. Dang. I guess I won't show off the to-die-for '84 Trek 610 barn rescue I picked up for $45.
Duke of Prunes is offline
Old 02-21-17, 05:05 PM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 2978 Post(s)
Liked 3,090 Times in 1,574 Posts
I think most manufacturers reserve the right to change specs and use a similar item if something is not in stock. More likely, especially in the case of a rear derailleur it is a replacement part.
Welcome to the forums. Any pics?
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Old 02-21-17, 05:09 PM
Clang
Quoted: 1127 Post(s)
Liked 2,359 Times in 1,358 Posts
Eh, you just need 10 posts to be able to post images. In the meantime, here's the pic from the ad. I saw this on CL.
Clang is offline
Old 07-03-18, 04:59 PM
Taylormic6015
Hey guys I've been trying to dig up some information on a sekai bike we currently have in the shop, the serial number reads "M7015000" or maybe "M7D15000" the bike is spec'd almost entirely dura ace. All black with chrome lowers on the chainstays/forks. Really a neat bike but with all the stickers pulled off and no visible model number I'm trying to get a confident answer on year/ model bike! Any help would be appriciated!
-Mike
Taylormic6015 is offline
Old 07-04-18, 10:16 AM
T-Mar
-Mike
It was definitely built in 1977 by Miki, It sounds like a Sekai 4000.
T-Mar is offline
Old 07-04-18, 07:30 PM
Taylormic6015
awesome thanks! Anyway to tell if it's a 5000 vs 4000?
Hummer
Classic & Vintage
3
08-04-23 11:05 PM
since6
Classic & Vintage
6
04-12-19 02:45 PM
ryansu
Classic & Vintage
11
03-15-19 07:11 PM
bicyclridr4life
Classic & Vintage
1
07-21-14 03:06 PM
dolphinlady
Classic & Vintage
16
06-17-12 02:46 PM
