Saddle woes
Saddle woes
Hi all,
After trying a lot of saddles I am currently using a Specialized Romin Evo Expert saddle, and I like the fit of it. Its the only one so far that doesnt cause a lot of chafing on my upper thighs.
However, on long 4-hour rides, my sitbones do hurt during the last hour or so. So the first 3 hours are usually fine, the last hour my sitbones are sore.
Is this normal?
It is a pretty firm saddle, not a ton of cushioning. There are lots of potholes and bad pavement where I ride, so the pain could be due to bouncing up and down the saddle for long periods?
= Should I try a softer saddle? I have heard too soft of a saddle is also not good.
Thanks!
Is this normal?
Thanks!
Bikes: Garmin/Tacx Bike Smart
Liked 296 Times
Unfortunately, I don't think anyone can really answer this question. Saddles are so personal that what works for me will not likely work for you. I'm riding a Brooks C17 and it works for me, but others sear at it, not by it. A softer saddle might work, but it might cause other problems, like overheating.
As I do agree with dmanthree that saddles are a personal choice, anyone on the saddle for more than 4 hours is going to get some saddle pain softer padding or not. I experience that same after 3 hours my sit bones start hurting. I believe this is normal. What I do find to help some is your shorts or bib are a good fit and padding as well.
Bikes: Colnago, Cervelo, Scott
The problem is that your legs are getting fatigued after 3 h and you're spending more time on your butt for the last hour...the problem may be with your fitness to tolerate a 4 hour ride, not your saddle
I had a Specialized Romin Evo and I had the same problem after long rides. I switched to a Specialized Power saddle and I solved the problem of saddle soreness. Everyone is different and your mileage may vary. I went through 8 saddles until I found "the one". Good luck.
Bikes: Colnago CLX,GT Karakoram,Giant Revel, Kona Honk_ Tonk
They are personal preferences but conditioning does factor in as well.
just another gosling
Liked 2,102 Times
I tried that saddle for a couple long rides, one a century. I found that the padding in the saddle has a softer bit of foam right where the sitbones go, probably by design. However over the hours, that spot kind of sinks down and causes a larger area of sitbone-covering flesh to have its circulation cut off, causing pain. So feel with your thumb right where you sit and see if I'm right about that. I took that saddle and all the other Spesh saddles I tried back. But I bought 4 of these:
VELO SENSO SPORTS VL-3206 Saddle, Black x White
Which have the same approximate shape as the Toupe series, but with much higher quality materials and for much less money. Also does not chafe my upper thighs, which is always my issue too.
Results matter
Results matter
Advocatus Diaboli
Liked 1,613 Times
I have four different bike that I ride, each with a different saddle. I have (maybe) a hard ass because I have never had an issue. That being said Is the saddle the right size for you?
Liked 2,102 Times
Flyin' under the radar
Hi all,
Is this normal?
Thanks!
Is this normal?
Thanks!
In a matter of about 45 minutes, I was able to try numerous saddles and see very easily which saddles gave me hot spots (high-pressure areas) and which saddles did not. For 16 years I've used saddles with cutouts. Ended up with a non-cutout saddle, which I never would have even considered had my fitter not suggested I try it solely to see what it looked like on the pressure map. It is by far the most comfortable saddle I've ever ridden on . . . like having an angel cup your crotch.
So my experience, at least, is that pressure mapping can save you A LOT of time and money (if you're like me and have tried about 20 different saddles).
Liked 296 Times
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Liked 29 Times
I've learnt that it's not the saddle, it's your arse
any decent saddle is fine, but your arse has to get used to sitting in a saddle,..... that takes miles and miles
but once your arse is broken in, you don't even think saddle .... no matter what saddle you are using
Farmer tan
I have the same saddle and had the same issue.
Also have the power saddle and the chicane. Both generate less sit bone pressure.
You can also try double bagging your shorts to see if more padding helps.
I've been known to adhere additional materials to my saddles to address fit issues.
You can definitely try easy mods with felt, leather, rubber, and electrical tape.
After someone mentioned I should raise the nose on the saddle, any discomfort was eliminated. Kona specs a Brooks B-17 on the Sutra, my first experience. I can see why others praise them so.
That is a good point, I hadn't thought of that. Let's see if it gets better as I get fitter. Thanks!
