Speedplay Vs. SPD-SL
Quoted: 1531 Post(s)
Liked 7 Times
Why should I only spend a total of $60 on SPD-SL setup when Speedplays look boss, like BOSS DAWG, boss.
Tell me why they look so cool and how much more pro they are.
Thanks for helping me convince myself that they're legit.
Bikes: 2006 Raleigh Cadent 2.0, 2016 Trek Emonda ALR 6, 2015 Propel Advanced SL 2, 2000 K2 Zed SE
Quoted: 115 Post(s)
Pros take care of their stuff, and the Speedplay pedals are easy to lube. Shimano pedals are for people who leave their chain dry to rust after riding in the rain.
Quoted: 23 Post(s)
Nothing is more pro than cycling related overuse injuries...and because speedplay pedals allow more free float, they can often prevent these injuries. So in this particular case, I'd have to give shimano the edge on the pro scale.
-Jeremy
-Jeremy
Bikes: 2015 Storck Scenero G3 (Force 22)
Quoted: 125 Post(s)
What is the weight comparison? I know speedplay are about 100 grams, but the cleat is also 100 grams, roughly. What is the weight of the Ultegra pedal plus it's cleat??
'Pro' edge: Speedplay
Cost per year to operate is very much in Shimano's favor. You could get back a lot of weight savings working a few extra hours instead of maintaining your Speedplay pedals (or buying new cleats) and purchase some weight weenies parts for your bike with the earnings
Quoted: 115 Post(s)
No one ever mentioned cyclocross. They are pedals for cycling, not for people who think it's better to get a perfectly serviceable bike and then carry it around in the mud instead of riding it.
SPD-SL can't be that bad considering that platform is being replicated by everyone but speedplay. Not to say that means it's better, but it can't be that bad.
^^ Didn't Shimano copy that style from LOOK?
Quoted: 105 Post(s)
I got nasty hot spots in the balls of my feet from Speedplays. Roughly eight hours into my first double century I had to step off the bike for a while and stand there while the pressure hot spots receded.
Quoted: 105 Post(s)
Also that was after the Speedplay cleats sheared off my shoe 45 miles into that ride and I had to wait for a very nice volunteer to drive to a nearby bike shop and bring back a new pair of cleats.
No issues with any SPDs at all so far.
Quoted: 125 Post(s)
Unless you buy the special 4-hole Speedplay shoes or spend a large sum of money for the titanium axles, the weight is a wash. My Ultegra 6800 pedals with cleats and all hardware weigh 330 grams. A Zero Chromoly pair with 3-hole hardware weighs 334 grams according to Speedplay. 4-hole is down to 286 grams.
in bagnomaria
Your bike will look more pro, which will make more people want to steal it, but they won't be able to, because, well, who can pedal on those tiny lollipops?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
If cleats sheared off the shoes then there was something wrong the shoes or the cleats were not installed correctly. Whatever it was probably caused the hot spots as well.
-Tim-
Quoted: 105 Post(s)
Cleat position may have been off enough to cause the hot spots, though you could make the argument that it was pedaling for ten hours that was the real cause.
The Shimano pedals and cleats are bigger which spreads the pressure over a bigger surface. They have been fine so far. I'll find out at Alta Alpina in June exactly how fine.
Quoted: 3306 Post(s)
Liked 2,146 Times
The highest price I could find for SPD-SL cleats is $25. Most sites are well under $20. And my SPD-SL cleats have lasted many thousands of miles for me. How quickly are you wearing out yours?
Quoted: 20810 Post(s)
Liked 9,456 Times
Also, I think that the maintenance of SP is often overstated and mostly by people that don't use them. A squeeze of grease in the pedals once in a while and a puff of dry lube on the cleats is easily and quickly done.
in bagnomaria
I'd bet that most SP cleats are replaced when the plate and screws securing the retaining clip are ground down through walking as opposed to being worn out through use (un/clipping and pedaling). If you're not walking around on the metal plate/screws (by using cafe covers, keep on covers, SP's new walkable cleats, etc) they'll last a long, long time.
