lockrings
Likes For Scrodzilla:
Clark W. Griswold
Liked 4,553 Times
Next time tell them to put on the lockring with grease and tighten it down to proper spec and make sure to check it every so often. If you are using the pavement as your undies and skidding, you will want to check it even more often.
loctite
Hi, not sure if it's blue or red. Looks like they applied it to the threads, so I can't see it. What is the difference between red and blue? My bike has front and rear brakes that I use to stop, guessing the lockring still needs to be checked sporadically? Is the loctite a pain to get off the threads after breaking it?
Dave
Dave
Is it a true track hub (with a smaller-diameter left-thread lockring) or a road hub? If it's a road hub, the lockring is right threaded and using loctite makes sense.
Liked 4,333 Times
Loctite on a lockring? I've never heard of that before. Now, I don't skid and never have. But I still don't know why you would need Loctitie. Backing off the cog tightens the lockring. Unless things are so loose to start with that you are stressing and damaging the threads, I see no need. (And that's what chainwhips and lockring spanners are for; tools every shop has.)
Ben - a guy who's been riding these fixie things for 40 years and the miles of (4) laps around the plane
Edit: Trakhak - good point
Warehouse Monkey
Liked 7 Times
Back when I got the Kilo, I needed to gear down from the stock 48t ring to a 44t ring. Wouldn't you know it, the bastard came with the Locktite on the chainring bolts. Had to drill 'em.
'10 Specialized Hardrock
FWIW red and blue Loctite both loose their strength around 100C. If it does not come apart with reasonable force, heat it up with a heat gun until spit sizzles and try it then. It should come right off.
Ride Safe,
Joe
Ride Safe,
Joe
Liked 4,333 Times
100C is boiling water. I hope I am not putting myself in danger adding olive oil to my pasta water.
Ben
Ben
Clark W. Griswold
Liked 4,553 Times
No danger, just wasting perfectly good olive oil in boiling water. Oil in pasta water really doesn't do much. If you keep your water at a boil and stir your pasta with some regularity you shouldn't get sticking. Generally it is the people who turn down the heat or don't stir that will get sticky pasta. Also good quality pasta can help out and it will taste better when properly prepared.
- Soli Deo Gloria -
Liked 738 Times
The Loctite Red 271 product page says it requires 260°C or about 500°F.
Henkel (manufacturer of Loctite) has a blog post which says 550°F.
Either way, pretty much permanent for a bike. The LBS obviously doesn't do many fixed gear bikes.
I'd bring the bike back to the LBS and politely ask them to remove the lockring. If it turns out to be Red 271 then I'd politely ask them to replace my wheel and take it from there.
-Tim-
-Tim-
My pants used to fit me
You shouldn't do this. Slick noodles don't hold sauce as well. Starch in the water is your friend. In fact, at work I harvest starch off the pasta tank to add to the sauce as a thickener. Just make sure you stir the noodles from time to time to keep them from sticking.
Salt in the pasta water is more important than oil.
Fresh Garbage
