cleaning The Chain
cleaning The Chain
The last few weeks have been very busy. Reports that need to be done, paperwork etc. By the time I ride home, I'm beat. Today I cleaned the chain for the first time in a couple weeks. The chain was Gummy and very dirty. (It's a wonder it didn't start to skip!) How often do you clean/lube your chain? What is the longest you've gone without cleaning it?
Bikes: ...a few.
Liked 410 Times
Depends on the conditions under which I am riding. Riding on wet pavement, especially with road salt, I have to clean it about once a week. Under dry conditions I can go weeks and months.
Liked 2,959 Times
There are a vast number of threads on this, and the answers are all over the board.
Personally I don't clean chains, but instead keep them fairly clean by running them through a paper towel once in a while as needed.
Likewise with lube, lots of lubes out there, lots of opinions, plus the lube choice, along with local conditions will determine how often you need to lube and clean.
FB
Chain-L site
FB
Chain-L site
Bikes: Trek Crossrip 2 2017, Cube Cruve Pro 2015 and Berlín Dutch Bike 3 speed 2014
I clean my drivetrain once or twice a week in the winter time and lube the cables under the bottom bracket, jockey wheels and the derailleurs.
In the summer time I had to clean the chain once a week as I had to leave it outside of my workplace.
I am potato.
Liked 1,742 Times
I've burned through a chain in 2000 miles, and I've had one go 5000 with no defectable wear. So chain life IME is really all over the map. I used to put a drop of tri-flo on every link every 500 miles (about once per month) and one got gummy, attracted dirt, and wore out, the other lasted for ever. I can't explain why. Now, every couple of rides I give the casette a quick spray with WD-40 while running the crank backwards. They appear cleaner and l haven't worn one out yet. As a rule of thumb, I know if they sound squeaky I'm delinquent.
...and I never clean.
YMMV
YMMV
Car dependency is a tax.
This is another big debate. I'm on both sides of the fence.
For the bike I purchased in 1979, I had never cleaned the chain. It was only when my son worked in a bike shop 34 years later was there any work done on the chain. He changed it.
A few years ago, when I finished my first winter of bike commuting, I cringed at the thought of purchasing a new bike and putting it through the harshest of conditions winter will throw at it. But as it turned out, I did make that purchase and I thought I better take care of it or it won't last for many more winters. So I got a chain cleaning kit and started scrubbing the chain clean for the first time in my life.
Some people still think simply wiping the gunk off is good enough. That may be true too.
Bikes: 2005 Gazelle Golfo, 1935 Raleigh Sport, 1970 Robin Hood sport, 1974 Schwinn Continental, 1984 Ross MTB/porteur, 2013 Flying Piegon path racer, 2014 Gazelle Toer Populair T8
Liked 11 Times
Being a daily rider in a very wet and grimy environment I do chain maintenance on a weekly basis.
1. I wet it with a solvent lube like White lightning dry, or Finishline dry.
2. I spin it for a minute or so then wipe it, and jockey wheels with paper towels, and then a terrycloth rag.
3. I repeat 1 & 2 when really dirty.
4. I put a drop of Chain-L or White lightning wet on each link then spin the chain for a minute.
5. I wipe with paper towels and terrycloth rag until clean and dry on the surface.
I don't keep track of mileage but they seem to last at least a year+ so I would guess 6k to 7k miles.
On my bikes with chaincases, I oil them once a year and they last for many years.
Thinking that winter was over, I removed the chain from my winter bike and dropped it into a jar of kerosene. My plan was to leave it there until next winter. Then it snowed and I had to get it back out. There was quite a bit of grit left in the jar. I was shocked. Kind of like when you get one of those new vacuum cleaners that lets you see how much dust you're picking up.
On other bikes, I've gone a year or longer without penalty. These days, I have to admit that I clean my chains for aesthetics more than function, because I like how my bikes look with a nice clean chain!
Bikes: SWorks Stumpy, Haibike Xduro RX, Crave SS
Liked 12 Times
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Liked 8 Times
On my route it hardly matters how "long" it is. I have put a brand new chain on, ridden 10 miles to work (at the old place). 4 miles of that is gravel road. If it's raining, I'll park the bike in the stairwell and when I get back on it in the evening, the 10 mile old chain won't bend anymore because it's entirely caked in dried clay.
I got to the point where I just power wash it and daub some lube on it when it's dirty, and put lube on when it starts making noise. I tried keeping it clean and lubed and my payoff for hours of work over the life of the chain was an extra 150 miles (about 2 weeks) life on a $6 chain. I decided diligence is overrated.
The BEST I can do, if I'm super diligent and spend hours cleaning the chain, is about 2000 miles on a chain. If I am lazy, I get 1800 miles.
I've gotten to where I don't bother measuring my chain anymore either. I just run it until it starts to skip - about 8000 miles, and then replace the entire drivetrain. It's actually LESS money than replacing the chain every 2K.
Work: the 8 hours that separates bike rides.
10 miles per day, usually dry, dirty roads. No dirt roads.
I use dry lube to reduce the nasty oily greasy build-up in both the chain and cassette. I usually lube the chain every 3 weeks or so, depending on if it's been wet. Every 500-1000 miles, I pull it off and give it an overnight bath in mineral spirits and re lube. Visual inspection every morning. Working pretty decent so far. If it sounds gravel-y and dry... it is.
Bikes: Raleigh Port Townsend, Raleigh Tourist
Liked 11 Times
People actually clean their chains? About the only thing I do is at the end of the winter season I'll put a lot of lube on the chain or my winter bike and make sure none of the links are binding.
Liked 11 Times
OP, Kickstart and I live and ride the same area, same conditions. He does commute more than I do. I do not clean my chain until it makes some noise or I have some vacation days. I used to clean my chains and lube them regularly. I slowly decreased to this. And, I have not noticed any increase in needing to replace chains or cassettes. I have my bikes maintained by a pro a couple of times per year, and he has not noticed any big difference.
I wounder where the difference is. Maybe because I'm a heavier rider on heavier bikes, maybe because I use lower end chains and components, maybe some of the roads I ride are in worse condition, maybe because I'm careless about cross chaining, maybe all of them?
Liked 12 Times
That's interesting, The reason I became diligent about chain maintenance is because I was going through chains and components too quickly.
Liked 3,612 Times
Liked 11 Times
I am about 185 plus gear, I do tend to buy expensive stuff (if there is overall value), from my memory of your bikes, my bikes are lighter (I don't have enough miles on the ebike to know about its chains, yet), roads are likely the same, I try to avoid the cross chaining.
I wish I knew the secret as chain maintenance isn't something I'm fond of, and the reason why I have a couple of bikes with chaincases.
Liked 2,632 Times
Even when I'm riding frequently, it's at least a couple of months between cleanings for me.
Señior Member
Liked 8 Times
It really depends on your situation. In my situation, if I didn't clean my chain, it gets to the point where it literally will not bend anymore. If I try to pedal, it just jams in the derailleurs. I have to sit down next to the bike and force the links to bend one at a time until I can ride. This can happen with a one day old chain.
They also can get so squeaky that they drive me crazy, in just a day or two, depending on weather.
I tend to lube maybe once every couple of weeks if it's a nice dry summer. In the winter and mud season, as needed. At least once a week, sometimes twice a day.
Keepin it Wheel
Liked 3,541 Times
I rotate between two chains every 6 months (about 1000 mi), and the off-duty chain gets shaken 'clean'-ish in some simple green, rinsed and dried in the oven, before getting coiled flat into a ziploc bag with a couple Tbsp of Chain-L. I flip it to let the Chain-L trickle through to the other side when I notice it in the garage cupboard. If the chain makes noise between swaps, I add some Chain-L and wipe down. If I happen to get my face close enough to the chain to notice gunk on it, I'll wipe it with a paper towel. (I need to do this)
working on my sandal tan
Liked 2,579 Times
Keepin it Wheel
Liked 3,541 Times
Liked 2,807 Times
I'm cleaning and relubing chains much less often with Tri-Flow -- once or twice a month, depending on conditions. I ride three or four times a week, 10-60 miles per ride, a mix of pavement and gravel.
Initial chain prep seems to help. I began with a new chain and wiped it as clean as possible without stripping it with solvents. Usually I can ride for a few weeks before I can hear a bit of chain noise. Then I'll wipe the chain with a shop rag, squirt it with Tri-Flow while spinning the chain, wipe it down as much as possible, and just ride until I can hear it again.
And the Tri-Flow smells pleasant, vaguely fruity like mango-banana candy. So I don't mind squirting it on in the tiled hallway before riding. Just some newspapers under the bike to catch the drips.
So far no rides in pouring rain with Tri-Flow on the chains. For a year I used Park CL-1 and was satisfied with it overall, although no matter how much I wiped it down it would still pick up more road grit. But the CL-1 lasted well through pouring rain and actually felt cleaner and less noisy for days after a rain. But Tri-Flow is much easier to apply and wipe down cleanly. Doesn't seem to leave a persistently oily/greasy residue like Park CL-1, but that may be why the Park lube lasts so well in rain too.
I used to clean chains regularly, but I stopped. I don't have time for that nonsense, and I don't believe it actually prolongs the chain's life. The other week I snapped, though, and did a major scrub on the drivetrain of my road bike. It was so filthy it was making me crazy. But I didn't try to flush the grease out of the inside of the chain like I used to do, I think that's bad for it. Just cleaned the outer surfaces. Hopefully that will reduce the accumulation of grime on my derailleur pulley wheels and rear cassette for a little while. Looks much nicer, now.
