Bottle cage to fit over front derailleur clamp?
Quoted: 5234 Post(s)
Liked 3,609 Times
anyone have one they like? this clamp is not centered between the two screws
Bianchi Goddess
Quoted: 2954 Post(s)
Liked 2,987 Times
I haven't bought a cage like that in years, but Blackburn used to make some. If you need something ASAP you could always us a regular cage with slightly longer bolts and put a few washers behind it.
Sugar "Kane" Kowalczyk
Quoted: 1617 Post(s)
Liked 2,232 Times
Interesting location. Hadn't seen that before. Count on it being on a Schwinn, so innovative!
Vintage cages typically had a dog leg in the mounting tabs and would fit over that derailleur strap.
I guess many vintage cages would work. Off the top of my head, look at the Zefal vintage style cage or the Blackburn "Chicane" cage. Nitto cages would also fit, but that would probably be overkill.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I have that low mount on the seat tube as well. I like it... low.
I mounted a Specialized Road Tool frame pump first, which then gave clearance for the water cage over it.
I actually wanted the frame pump.
Liked 3,609 Times
Liked 3,609 Times
Liked 3,609 Times
Quoted: 4722 Post(s)
Liked 3,046 Times
Not so dumb really on small frames
Not meaning to offend, but for us vertically challenged folks this is the way to go.
It seems like most bike put the bottle brazeon locations the same distance up[ from the bottom on all their frames.
Makes it difficult to use larger water bottle on small frames like I ride (47-49cm).
I had to make up a spacer bar to lower the seatpost bottle on my Roberts.
Liked 2,232 Times
I can understand limited access. My wifes bike is almost that bad.
[IMG]REI Novara Aspen, on Flickr[/IMG]
Liked 3,609 Times
I used alloy spacers I bought at the hardware store. They come in different lengths & widths & are matte silver. They're great for all sorts of mounting solutions.
Liked 3,609 Times
oh yeah, right I recently used some plastic ones to extend my mini clips. better than a bunch of washers I would be fumbling with
Quoted: 5898 Post(s)
Liked 3,513 Times
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 33 Times
Actually, keeping a bottle filled with water, weight low on a bike can only positively contribute to its stability......
If it doesn't quite fit you can always use standoff spacers as suggested by others.
Blackburn MTB cage would have been most common choice for a MTB or hybrid bike of this period.
Quoted: 1361 Post(s)
Liked 425 Times
Not that it really matters to us creaking knees racers, that bottle location is the 'hot setup'. Weight in low CG position but also the kids working at the wind tunnel studies claim its the most aero advantage for bikes. cheer's
Liked 3,609 Times
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
I have a similar Ibera cage on a bike, except mine is aluminum. It works to get around the derailleur clamp issue, but it's not the easiest cage to get a bottle into. It also tends to come loose -- I'm guessing because the top half and bottom half of the cage flex relative to one another, turning the mounting screws back and forth a little bit every time I put a bottle in or take it out.
Jedi Master
Problem Solvers Space Outs are designed for that problem.
