All-around wheel for training/racing crits and flat road races
Bikes: Specialized Venge
I've got an option with two pretty good deals:
1) HED ardennes new old stock from 2014
2) New Flo 30
I am looking for a wheel I can use an everyday trainer but that I could also race crits and flat road races on.
Also have heard some stories that there could be some clearance issues with the ardennes and a 25mm tire on an s-works tarmac so would love to know if any of you have experience with them.
2) New Flo 30
Nonsense
Bikes: Affirmative
Liked 541 Times
I use a front flo30 and will vouch for the aerrrrrrrroooooo gainzzzzzz. It's a good deal. I have heard the rear flo 30 gets a bit whippy under high power though. I never bought a rear because I'm tied to my Reynolds laced ptap.
2) New Flo 30
2) New Flo 30
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Tires tend to run wider on the HED rims, so the 25mm might be more like 28mm, but you can always run a 23c and it will probably be about 26mm.
I was leaning towards the ardennes prior to the thread, honestly tough to find many people saying bad things about either.
Also looking at the Zipp 30's as they supposedly are more aero, but have heard they are a bit overpriced for what they provide.
Narrowed my choices, the decision comes down to one more question if someone with more experience than me can chime in:
Assuming the wheels are used for both racing and training, would a 23mm rim or a 25mm rim that is also about 100g heavier be better? All else essentially the same.
Because experiences from someone going from a narrower rim to a wider rim are going to be very similar experiences to what I would have with a wider/narrower rim. While their may be minor variations in preference, It's not like I am going to have the exact opposite experience with a wheel set as someone else.
You in Dallas riding through that insufferable heat expect to have the same experiences as someone in the bitterly cold home of HED wheels? Hmm, well that is something. Anyways, wider is trendy right now. Even the not as wide option is more so than a traditional wheel from a few years ago.
Pick one and go ride the snot out of it.
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Liked 116 Times
Specialized Turbo Pros 23mm (now discontinued) were 26mm wide.
Specialized S-Works Turbos 24mm, both tubeless and tubed, were 27mm wide.
Michelin Pro4 Endurance V1 25mm (now discontinued) were 30mm wide. They were 27mm+ wide on my old Open Pros.
Specialized Roubaix Pros 23/25mm are 28mm wide. These are the tires on those wheels now.
My guess is that the above tires would be 1-2mm narrower on the original Ardennes wheels. I think they'd be a good choice for the OP.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
My last round of searching I came up with the late model Roval CLX40's (the tubeless compatible ones).
They're about the sweet spot of weight (1375g) vs. aero (40mm). Not the widest profile at 23mm, but they fit my SWorks SL2 and Sworks SL4 (with Schwalbe Pro 1 TL 25's) no problem.
They're at least as aero as my old DV46, and with in 25g of my old climbing wheels (Rolf Elans). I find I no longer have any reason to swap wheels back and forth.
You can pick em up in good shape on ebay for around ~$1100 if you're patient. I may know of a set coming available in the next few weeks if you're interested.
I have a set of HED Ardennes + wheels on one of my bikes. Note that these are the 25mm-wide version, while I think the OP's NOS ones are the original 23mm-wide ones. I played around with different tires on these wheels and these are the results:
They'll both give you the advantage of being able to run lower pressure for better ride quality with good rolling resistance. The wider rim will likely be more aero and possibly handle better as well (running a wider tire on a narrower rim give you more of a mushroom-shaped tire profile, which tends to be not as good for cornering/aerodynamics).
