Powermeter
Powermeter
Old 05-31-17, 09:42 AM
topslop1
topslop1's Avatar
Liked 7 Times in 4 Posts
Powermeter
Which of the $399 variants are good to go? Interested in seeing power numbers with minimal hassle.
topslop1 is offline
Old 05-31-17, 10:26 AM
topflightpro
topflightpro's Avatar
Liked 680 Times in 431 Posts
Used SRM. They are getting down close to that price range.
topflightpro is offline
Old 05-31-17, 10:49 AM
PepeM
PepeM's Avatar
Liked 119 Times in 59 Posts
PT hub.
PepeM is offline
Old 05-31-17, 10:50 AM
Seattle Forrest
Seattle Forrest's Avatar
Liked 10,646 Times in 6,054 Posts
My L/R balance gets closer to 50/50 as my power output goes up and farther from 50/50 as it goes down. Wouldn't want a power meter that only measured one side.
Seattle Forrest is offline
Old 05-31-17, 10:56 AM
mvnsnd
mvnsnd's Avatar
Bikes: Factor O2, Caad10, Caad2
Liked 123 Times in 79 Posts
Originally Posted by PepeM
PT hub.
This. the PowerTaps just work.
mvnsnd is offline
Old 05-31-17, 11:16 AM
noodle soup
noodle soup's Avatar
Liked 1,882 Times in 998 Posts
I wish I purchased a second Powertap GS when they were $299.
https://www.powertap.com/product/powertap-gs-hub
At $399, its still a good deal.
noodle soup is offline
Old 05-31-17, 02:34 PM
topslop1
topslop1's Avatar
This gets laced into a new wheel build?
topslop1 is offline
Old 05-31-17, 02:37 PM
ypsetihw
ypsetihw's Avatar
Bikes: s-1
I'm on a 4iiii purchased from clevertraining.com for $369 with a discount code. love it, great data, very easy to install and use, pairs with my garmin 510 first time every time.
ypsetihw is offline
Old 05-31-17, 02:47 PM
topslop1
topslop1's Avatar
My question with this one - can you pair a shimano 105 with a higher group-o or do they not intermingle? Or is that just weight/quality.
topslop1 is offline
Old 05-31-17, 02:56 PM
PepeM
PepeM's Avatar
They intermingle.
Single sided power is... less desirable than dual sided power.
PepeM is offline
Old 05-31-17, 03:19 PM
cthenn
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Liked 139 Times in 90 Posts
They intermingle.
Though true, I have a L-only PM and find it very reliable in terms of repeatability. Works well enough for my needs, and cheaper than dual. Depends what you want out of your PM.
cthenn is offline
Old 05-31-17, 03:50 PM
noodle soup
Yes, or a rebuild of an existing 24 spoke wheel you have.
Old 05-31-17, 03:52 PM
garciawork
Bikes: Mikkelsen custom steel, Santa Cruz Chameleon SS, old trek trainer bike
Liked 6 Times in 4 Posts
Bought the same 4iii referenced above, for the same price with a coupon. No tissues at all. I am no racer, and my results seem very typical, so for me it works. Cheap as well!
garciawork is offline
topslop1
topslop1's Avatar
What's the coupon availability?
topslop1 is offline
Old 05-31-17, 03:54 PM
garciawork
Go to DC Rainmakers site, find the review of the 4iii, and there should be a code for 10% off at clevertraining.com.
Also of note, I would imagine at some point in the future that 4iii will trickle down the dual side from Dura Ace through 105 (I hope!) so the single side may be made dual in the future. or so I hope.
Old 05-31-17, 04:49 PM
smarkinson
Liked 13 Times in 7 Posts
They quite happily intermingle. I got a 105 4iiii and I swap it between two bikes, one with an 11 speed 105 crankset and the other with a 10 speed Ultegra crankset.
I got the 4iiii mainly to use with Zwift on a dumb direct drive trainer. A PT hub wouldn't work in that situation.
smarkinson is offline
Old 05-31-17, 06:28 PM
ypsetihw
ypsetihw's Avatar
Bikes: s-1
I have the 105 4iiii on a dura-ace crank, mates perfectly, it's about 20grams heavier that's it. just make sure you get the same length
ypsetihw is offline
Old 05-31-17, 06:31 PM
ypsetihw
ypsetihw's Avatar
Bikes: s-1
about the dual sided vs single sided thing - my right leg is stronger, and having a left side meter has forced me to even out my pedal stroke (benefit in my mind). also, it keeps my numbers realistic and very repeatable and reliable across rides/terrain.
ypsetihw is offline
Old 06-01-17, 12:57 PM
topslop1
topslop1's Avatar
Not sure what length is on my 2013 Cannondale Synapse. Alloy. Shimano 105. HMMMM.
topslop1 is offline
Old 06-01-17, 01:20 PM
ypsetihw
ypsetihw's Avatar
Bikes: s-1
it'll be stamped on the inside of the crank arm, probably either 170, 172.5, or 175 (common on most production bikes), although women's bikes are sometimes spec'd with 165
ypsetihw is offline
Old 06-01-17, 02:12 PM
topslop1
topslop1's Avatar
great, thanks, will look.
topslop1 is offline
Old 06-01-17, 03:50 PM
Danny01
Powertap. I have both the GS hub and C1 rings. Both are truly set and forget. Though I picked up the GS hub new for $210, $400 is still a great deal. Thing is, you have to have a 24 hole rim and probably will need new spokes in addition to the cost of a wheel build if you can't do it yourself. I think it ended up costing me about $120 for 24 CX-Ray spokes and the build. You can pick up dentist's special(almost brand new) C1 chainrings pretty easily for around $400 on ebay. IMO, all of the single sided stuff are outdated. For $100 more, you can get true dual sided Powerbeat.
Danny01 is offline
Old 06-02-17, 01:11 PM
topslop1
topslop1's Avatar
What kind of power differences are there between legs on folks? 3%? 5%?
topslop1 is offline
Old 06-02-17, 02:28 PM
99Klein
99Klein's Avatar
Bikes: 99 Klein Quantum, 2012 Cannondale CAAD10 5, Specialized Tarmac Comp, Foundry Thresher, Fuji Sportif
If you don't have dual side, how do you know? I would think the only way to balance is to be able to see both legs. I too am stronger right leg, and I struggle to even it out. I have gotten much better, but it's taken a lot of work. The more you work, the more both legs progress...
99Klein is offline
Old 06-02-17, 02:38 PM
Seattle Forrest
60/40 % L/R when I'm tooling around, down to 52/48 % when I'm working pretty hard. A left-only meter will double whatever power is coming from the left leg so for me it would be 20 % over when I'm not trying very hard.
It's different every second of every ride.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
