Headset Removal
Bikes: 2006 Trek Pilot 1.2, 1972 Schwinn SS
Quoted: 156 Post(s)
Headset Removal
I took off the stem and spacers and get to this point. I feel like I should be able to unthread this but those two notches in the ring probably mean I need a tool?
Quoted: 1441 Post(s)
Liked 1,095 Times
Warp an old leather belt around the knurled part and grab it with a Channelok or Vise grip pliers.
Quoted: 996 Post(s)
Liked 594 Times
Probably there's a specific tool for that. You *could* probably do it with a flat-bladed crewdriver engaging a notch and tapping the handle with a plastic mallet. My first choice would be a large pliers (such as a Channellock https://www.channellock.com/440-Straight-Jaw-Plier.aspx) with a couple layers of duct tape on the collar so as not to mess up the surface.
Steve
EDIT: Hahahaha! Great minds ^^...
Steve
Quoted: 4894 Post(s)
Liked 4,064 Times
A pipe wrench would also do the job nicely (with the same precautions above).
Edit: unless there is rust, unscrewing that cup should not be hard. By hand shouldn't be difficult. When you replace it, use a lot of good grease on the threads.
Ben
Ben
Quoted: 156 Post(s)
Thanks, it helps to know that it should turn easily. I thought that but I've been burned trying to turn things that shouldn't turn
Old fart
Quoted: 3617 Post(s)
Liked 3,456 Times
Quoted: 72 Post(s)
The Hozan C-203 is the tool you want to use. It has the plier face to grip the knurled circumference and the twin tips would probably perfectly mate to the cutout notches acting as a lockring
Old fart
Liked 3,456 Times
I respectfully disagree. If you've ever used the Var 78 pliers they are smooth. They would be the wrong tool for that knurled headset piece.
Quoted: 996 Post(s)
Liked 594 Times
I was thinking (dreaming) of something that would engage the slots. A more modern, Shimano-like tool would probably be round, with a hole in the center surrounded by wrench flats (headset wrench size) and projections on the other side to fit the slots.
Luckily there are more than one way to skin this cat!
Steve
Anticipate not re assembling it, and get a whole new headset, with the more serviceable ongoing Hex adjustment .
Quoted: 156 Post(s)
This bike has a lot of non standard parts so I don't know. I'm going to get it painted, then reassemble with new rims and see how it feels. The trick here was actually not to try and turn it from the outside put to apply tghe pressure on those two interior notches. A regular pliers and a light amount of force did the trick.
Is it French? that's unfortunate.. English thread has become the overwhelming commonality in the bike biz.
The French made their own Cul De Sac , then rather late, they joined the rest of the market..
Old fart
Liked 3,456 Times
Not sure I agree with that. In the heyday of the bike-boom, there was widespread adoption of metric standards all around the world, the United States being the only significant hold out. And even today, just about everything on a bike is metric thread, except bottom brackets and steer tubes.
Liked 4,064 Times
Ben
Of fractional tube sizes 28 vs 28.6 (1.125"..9/8")), 25.0 vs 25,4 (1"). 22.0,vs 22.2(7/8"), etc..
Prime Meridian going thru Paris, did not happen, either .. GMT is in and thru Greenwich , England....
