One-Piece Crank Schwinn Super Sport Loose Cup?
On the road
Bikes: Old Schwinns and old Raleighs
Liked 936 Times
Here's something new to me - the drive side bottom bracket cup sits somewhat loose in the frame. The non-drive side is tight and would need a hammer to knock it out, but the drive side I can just pull right out with my fingers. Has anyone had this - where you have a loose bottom bracket cup with a one-piece crank? When I first got the project, the bottom bracket turned OK; the cup was not turning in the frame. Once I loosened the set, it became apparent that the drive side cup sat somewhat loosely in the frame.
And I suppose the alternative to conversion is a thin shim of some kind to tighten the cup fit up just a bit. Maybe a piece of soda can or sheet aluminum?
What's the verdict? Should I do a bottom bracket conversion on it to modern three-piece? Or is this something people just deal with and ride?
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
I would try a different cup and if that didn't work then I'd shim it. Aluminum foil would probably work best. However if you want to do a 3-piece conversion then I would go that route.
Liked 2,631 Times
Aluminum foil might be too thin. Try a soda can. Whatever works, I would trust it. These bearings are not precise.
Old fart
Liked 3,471 Times
I have encountered this problem before on U.S. made Schwinn bikes. One side a bit loose, the other tight. After tightening the left hand cone and locknut, never had a problem with anything loosening up.
Liked 2,133 Times
