Maintenance for Alfine 8spd S501?
Hi,
I'm going to rebuild my rear Alfine wheel to replace a broken rim. Since I'll have the hub off, is there any (preventative) maintenance I should do on it? I don't have any big issues as far as I know. The wheel does skip now and then which is very annoying and slightly dangerous. I have the yellow lines aligned so I'm not sure if there is anything else I can do about it. I have somewhere between 6000 and 8000 km on the hub I think.
thanks
thanks
Liked 596 Times
IIRC, the 8-speed Alfine is similar to the 8-speed Nexus. It wouldn't hurt to dip the internals in gear oil (some use ATF; I use gear oil on 2 Nexus hubs and my Alfine 11) and re-lube the bearings with grease. This can be done without disassembly of the gear cluster.
Steve
Thanks for the link and the reply.
Reading up on it, it seems some people have good success with oil immersion with the 8spd while others find that the seals leak a bit with oil. I wonder what the alternative is, if I don't do an oil immersion? I don't want to disassemble the whole thing.
Liked 596 Times
The oil dip is much easier. I have found that gear oil (I use Royal Purple 75W-140, which has similar properties to the Shimano Alfine oil and is 20-25% of the cost) has less of a tendency to run off than ATF. After the dip, I let the cluster drip for a half hour before reinstallation in the hub. Even though my Nexus hubs have relatively poor seals, I have not had a significant leakage problem.
I pack the bearings with the regular Nexus grease, which theoretically helps with keeping the oil inside the hub.
Speaking of Nexus grease, when I started looking inside Nexus hubs, the "official" grease was a black paste which looks like it contains molybdenum disulfide. My first Nexus 8-speed hub used the same grease, seemingly. My second N-8, a "red band", had a white grease, like lithium grease. I use the black stuff on all these hubs, partly because I bought two tubes of it and partly because the black stuff is easier to clean off the parts.
If you haven't seen Aaron's Bicycle Repair, they have some good pictures: Internal Gear Hub Service.
Steve
EDIT: More on this thread: https://www.bikeforums.net/bicycle-me...nexus-igh.html
I think the only good alternative to the "dip" is grease, which pretty much requires disassembly. The gears are in sub-assemblies that aren't too difficult to get off the cluster or put back. The sub-units only need disassembly for a really thorough cleaning and (IMO) can be left intact for re-greasing.
Steve
Steve
BTW, if you are going to strip the hub down to the axle, it is easiest to clean the parts with diesel fuel, as you don't need to strip it off when you are done cleaning...which is prohibitively difficult, if you don't have all the tools to re-assemble the internal assembly.
Liked 596 Times
Steve
Liked 596 Times
IIRC, the drive-side seal requires a large pliers or a purpose-made tool. The locknut and cone are removed with standard bike tools.
Steve
See Dan Burkart's instructional video here: https://www.bikeforums.net/19692927-post9.html
Steve
Steve
Liked 596 Times
In order to open the driver, a special drift is required that punches the driver body off the cone. A separate drift is used to reinstall the cone properly. Theoretically, you could do without this tools, but you'd have no idea if you put it together properly, and it is considered a critical dimension (ie, the hub won't work properly if you get it wrong).
Having said that, I don't recall seeing anything in Dan's video about these drifts, and I went to the Shimano "Tech Docs" site and couldn't find this information there either. Do you have a link to something about this? (I'm just curious... no Alfine purchases in my foreseeable future!)
So... I guess I'd advise the OP to proceed with caution and look for as much (authoritative) help as you can find!
Steve
Well, this is where i admit that I have no experience with open-hub maintenance on Alfine hubs. My 8-speed hubs are Nexus; I have been under the impression that maintenance procedures on Alfine and Nexus hubs (8-speeds anyway) were similar.
Steve
Steve
Basically, you remove the internal assembly, remove the e-clip from the left side, and pull the planetaries.
Remove the RH locknut, and place the split drift over the axle (how, will be obvious, when you see the tool and assembly in your hands). Cradling the axle assembly in one hand/carefully supported over the open throat of a vise, drive the drift down, popping the axle free.
At this point, the assembly will spring open, allowing you to remove the driver/access the RH wheel bearing.
After aligning the parts, you place the cone in the proper orientation, and use the installation drift to put the cone in at the proper depth. Install the locknut, and assemble the rest of the internals as normal. It is extremely important to make careful note of the orientation of every part, as almost none are bi-directional.
Shimano publishes a service manual for the above procedure, but it is only available to dealers. You might try calling them, but I wouldn't count on then making it available to you.
I also would not undertake the above without also buying new RH axle seals, as these are typically damaged by removal.
Liked 596 Times
You can see the tools referenced in the upper right corner at Manuals & Tech doc
Of course, the Alfine-11 is even easier: nothing but oil changes!
I just watched Dan's video again... there were no drifts or special tools used. I think the drifts are needed for a level of disassembly above and beyond what it takes to simply lubricate the hub. I learned the hard way not to take the axle unit apart on a 7-speed Nexus hub... it's still my "rainy day challenge" project.
![Big Grin](images/smilies/biggrin.gif)
Steve
I, also, find that the A11 is the easiest of all. I had initially opened my hub to grease the outside bearings, but upon my last total teardown, discovered that the grease had been displaced, and a fine film of oil was coating all the bearings (even those farthest from the hub shell's center, in the driver assembly). It would seem that grease is entirely unnecessary for the A11, in any capacity.
Aside from the peculiarity with the pressed on RH cone, the overhaul procedure is quite similar between the Nexus/Alfine family.
Senior member
Thanks! Now I'm *really* happy my hubs are Nexus! They're a snap to overhaul compared to the Alfine it would seem.
I just watched Dan's video again... there were no drifts or special tools used. I think the drifts are needed for a level of disassembly above and beyond what it takes to simply lubricate the hub. I learned the hard way not to take the axle unit apart on a 7-speed Nexus hub... it's still my "rainy day challenge" project.![Big Grin](images/smilies/biggrin.gif)
Steve
Steve
Liked 596 Times
Thanks, Dan! That's more disassembly than I plan to get involved with. Dipping the gear cluster (Nexus; no disassembly) and greasing the bearings seems to work very well.
Off topic, I enjoyed some of your other videos documenting overhaul of some dynohubs. About 6 years ago, I submitted a protocol for servicing the Dahon Joule (early model) to Hubstripping. It was pretty basic; I like your video documentation better. (https://hubstripping.wordpress.com/2...le-dynamo-hub/)
Cheers,
Steve
Cheers,
Steve
Senior member
Cheers,
Steve
Cheers,
Steve
I will go through it when I can, it looks very interesting.
The white grease is slightly runnier than the moly grease, which Shimano now specifies for their coaster brake hubs. It also mixes readily with the nexus oil, which I suspect is the bigger plus to it; after servicing one, riding around the block, and opening it up to satisfy my curiosity, the internals were a pretty uniform blue-ish white, with no distinguishable grease or oil, just the amalgam of the two.
I finally got the hub apart and it looks to be in great condition. There is still quite a bit of white grease inside.
Senior member
I have a tub of green Park Polylube 1000. Any ideas on whether or not this grease would be ok? I don't plan on doing an oil bath since my hub won't seal oil in.
Shimano's special Nexus grease is the best stuff to use unless you switch to oil bath lube.
Thanks Dan. Your videos have been helpful too, BTW. I wonder if I can get the grease locally in Vancouver.
So for the oil dip: dip in gear oil or maybe ATF, or Shimano oil if you're rich. Let drip. Grease gears with shimano grease. Maybe put some Phil's Tenacious Oil (pictures of that on Aaron's Bicycle Repair and mention on sheldonbrown.com), and use marine grease for the outer bearings (I think my Park polylube would be good for the outer bearings too).
Senior member
However, for my current commuter bike, equipped with an Alfine 501 series, I chose to stick with the Nexus grease.
I did apply the grease to some of the deep down parts that didn't seem to get much from the factory.
Greasing the moving parts in the shift spring assembly as well as the pawls and actuation arm definitely improves the function.
If you go the oil route, I suggest keeping the recipe simple. Use one type of oil exclusively to avoid the possibility of non compatible additives, and use grease on the outer bearings.
I've done the ATF dip on several hubs both Shimano and Sturmey Archer, and apart from sometimes being a bit messy, in every case hub performance was enhanced.
Liked 596 Times
Steve
Passista
Bikes: 1998 Pinarello Asolo, 1992 KHS Montaņa pro, 1980 Raleigh DL-1, IGH Hybrid, IGH Utility
Liked 756 Times
I drilled and tapped my Nexus 8 for an oil port and use 15 ml ATF, changed about every 5000kms/1 year. 30000kms so far, not a problem, no skipping, no play, so I can't be sure ATF is the best, but certainly it doesn't do any harm.
Liked 596 Times
To your question: I was using ATF on my Nexus hubs, plus Nexus grease on the bearings, but I would get a little leakage if the bike was stored drive-side down. I switched to the RP gear oil because it is more viscous. After about a 10-minute draining period I reinstall the gear cluster, and I have not had any oil leaks. Because the oil is moderately expensive (~ $25/liter) I use the same oil for dipping. Between dips, any sediment settles to the bottom of the container.
Steve
Passista
Liked 756 Times
I used grease on the bearings when I disassembled the hub at about 6000kms, but probably the ATF has washed it away by now. There is a very small leakage at both sides, but I just clean it with a rag when there is some dust stuck. My bike is always on its kickstand, but it fell once and there was a puddle under the left dropout. I understand the seals are not designed for keeping oil in, but when I replace the ATF about once a year, there is still plenty of it inside.
