Just bought an inversion table
Liked 1,354 Times
I found a really good deal on a Teeter EP 860. Waiting for delivery. Anyone have any experiences with inversion tables or advise?
I have had a teeter inversion table for 15 years. I worked for ups for 30+ years and in that time I hurt my back. If it had not been for the inversion table I would not have been able to make retirement. They work. All humans should have an inversion table imho.
Interocitor Command
I had an inversion table for a few years. Unfortunately, my lower back is so messed up that it only helped temporarily. If my back weren't so messed up I would still have it and still be using it today. I think they're a good thing to use, even for healthy non-injured backs.
He drop me
I've had a Teeter inversion table since my back issue in 2010. My spinal surgeon said that it was the only thing that kept me off of his operating table for 6 months.
I don't use it regularly anymore as the above referenced surgeon did a great job but I do use it from time to time.
Not much to it really. Hang for several (2-3) sets of 2-5 min with a min break in between to let the blood flow back out of your brain. If your back was as jacked up as mine you'll feel this amazing pop and rush of...don't know how to describe it...but you'll know it if it happens.
The views expressed by this poster do not reflect the views of BikeForums.net.
I think my Teeter saved both my husband and I.
Because of work, I have two herniated disks in my back and was paralyzed for 6 months. Went to the Chiro 2-3 times a week for a few years.
Decided to invest in this and it allowed me to go on it whenever I need to. And just to make a point, I have not needed to be on mine for over 3 months.
Liked 1,354 Times
I got it from COSTCO on-line. It was $330 or so. That included shipping. They advertise the unit at $299. This is new but last year's model. I think they are discounted by about $100 from original list.
Liked 1,354 Times
Still waiting for delivery. Should be here on Monday. My motivation for getting a table is loss of height and stiffness in my lower back. I don't expect to get height back but am concerned that the spinal compression could lead to nerve impact.
BIG TIP!
Remember that it's your arms that make it balance! Bring your arms slowly to your chest and it will start to lay back. Whatever you do, don't do it fast or you will freak yourself out!! My brother in law did it and he will never go on it again LOL
Liked 1,354 Times
Jeeezus....so much cardboard, foam and plastic packing. About to put it together but I have to run down to meet moto friends in New Haven for pizza at Pepe's and cigars and whiskey at the Owl Shop near Yale.
![Smilie](images/smilies/smile.gif)
Liked 1,354 Times
So, put my new Teeter inversion table together and tried it out. Full disclosure......while I make no claims to tech/mechanical genius, I do have a certification to teach Industrial Technology (aka: SHOP). The quality of the materials used is quite good. This is a piece that should last for many years. Probably a lot longer than I will. I decided I would abandon my usual approach and actually read the directions. The first sheet said I should insert the 'bridge" onto the table. So, what's a bridge? It turns out it's a piece of flat plastic and can actually be bent and inserted onto the table to form a support for the hollow of your back. Not obvious and several views and readings of the directions were needed to identify the part and install it. Installation was simple. There were a couple other similar issues but the actual construction of the table (in retrospect) was not difficult.
Use: After a few misadventures it occurred to me that the basis for successful use was in the balance of body weight over the pivot point of the table. Once I established that fact I was able to get my body into a proper position. Then I tried it out for a few minutes and I found it to be comfortable. I'm looking forward to longer sessions to see how it actually affects my body. I'm optimistic.
![Frown](images/smilies/frown.gif)
Liked 1,354 Times
What I failed to realize initially was that I had to get my body into a neutral weight distribution before the arms would be helpful. Using the Teeter scale vis a vis height was not quite accurate. A lot of my weight is through my chest and shoulders. So, I had to play with the settings.
Liked 1,354 Times
I wish I could give a better update but I haven't been able to use the table consistently. Since Thanksgiving I've been sick several times with something that lasts for 3 weeks each time. A consequence of running into people who declined to stay home when they were sick. Thus, spreading their illnesses to the rest of us. The limited time I've had has been positive. I'll try to get back into a groove and post.
Looking forward to the results when you have time.
I tried some inversion therapy using just a sheet and rope like this ;
Worked great and comfortable as doesn't dig in to the body. Great hearing the back joints click. Any old strong sheet works.
I did however get a bad ear infection shortly after so stopped doing it as read inversion can cause this.
![](https://www.crossfitironmill.com.au/wp-content/uploads/2014/04/IMG_2941-1024x768.jpg)
Liked 1,354 Times
So, I have had some time with the table. Basically, once you set it up for your height/weight distribution, it is easy to use. (Setup is very important) You are supposed to use it for 5-10 minutes a session about 3 times a day. I use it with some music in the background and I find it relaxing. It does stretch you out and I have had occasion to use it when my lower back felt tight and achy. I found that it helped significantly. Happy I have it.
