Cyclocross FD adapter
Hey folks, planning to do a cyclocross project in the spring, and currently the frame I have in mind for it only has a top pull FD cable routing, hence rendering it incompatible with my road down pull FD and shifters. However, I've recently found out that one could use a "cable pulley adapter" to solve this issue. Have any of you folks got any experience with these things?
Quoted: 1441 Post(s)
Liked 1,095 Times
I do not have personal experience but I understand that this is commonly done, presumably successfully. A pulley is not a new or high-tech piece of machinery. Here's a nice one from Problem Solvers: https://problemsolversbike.com/produ..._clamp_-_17312
Keith Bontrager made his Cyclocross race frames including one as standard kit.
You could add a housing stop on the down tube, another clamp band, & the plastic guide under the bb
and have the cable run under the BB as well ..
I Own an Italian , steel CX frame with top tube rear, down tube front shifter routing..
of course 1 by , a 42t chainring & double chainguards in CX has a long history.. No FD needed..
Quoted: 4239 Post(s)
Liked 3,974 Times
Many thousands of bikes have gone for millions of miles with these ft der cable rerouting pulleys. But they do add one more part to deal with. The first issue I think of is that they are usually in the direct line of fire from the road crap flying off the rear tire, so cleaning and the bushing/bearing maintenance can be important in bad conditions. The next is that one can route the cable one of two different ways around the pulley (as in clockwise or anti clockwise). One way will likely also route the cable to better actuate the der through its arc. Andy
Liked 3,974 Times
I think the NL made Empella CX frames included them..
that was before 3D printers.. so now.. make your own.. add O ring/gaskets around the cables..
By the way you have a week between races on the weekend to prep for the next one..
Quoted: 18451 Post(s)
Liked 4,562 Times
I have a frame that has just an extra braze-on boss for one of those reversing pulleys. Actually, one bike uses it, and I never think about it, although cable routing seems to be best if I give the cable a twist when going around the pulley. It still works fine.
However, the CX70 is also a top-pull derailleur which is worth considering. No need for the reversing pulley.
Thanks for the replies. I did some research and found a "Sturmey Archer Shift Cable Pulley" on Amazon. Would this work for what I need? And also to reply the comment about discerning whether it is top or bottom pull; it is generally mentioned on the manual and generally, road front derailleurs (sti shifters and derailleurs) are exclusively bottom pull.
Quoted: 239 Post(s)
Liked 7 Times
Don't bother with a clunky pulley
just buy a different derailer.
Plenty of Shimano's offerings come in top/down/multi pull variants for the same derailer cage.
Liked 4,562 Times
However, the CX70 derailleur should work... or at least would be worth trying.
Bikes: Numerous
Quoted: 1684 Post(s)
Liked 3,182 Times
My first cross bike I made my own with a grooved plastic disc from the hardware store and a bottle cage bolt. Worked fine. I “upgraded” to a real one with a cover on it. They’re not that clunky and gunk isn’t really an issue, by the time you get enough mud and gunk on that part, your FD, RD and everything else is covered too. I’ve never given the piece a second thought. As long as the bolt fitting is on there, just buy the part ($10 maybe?) , install, and ride.
more than one bike will too.. bike swaps mid race is allowed in CX..
IDK what your course terrain is .. some course's sections and conditions, running is faster than gearing down..
and shortest lap time, done repeatedly , wins..
Bikes: yes
Quoted: 1281 Post(s)
Liked 644 Times
I know folks who would cut a throat for a top-pull CX70. Fantastic derailleur, in my experience. (PS it even works with Campy shifters, even though they'll swear up and down that it won't.)
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 198 Times
jtm54
9
09-29-13 09:08 AM
sternforprez
Bicycle Mechanics
4
03-24-13 09:53 AM
RFC
Bicycle Mechanics
5
02-12-10 03:03 PM
