[Brompton] Sturmey-Archer drum brake?
Quoted: 585 Post(s)
Liked 119 Times
Hello,
Has someone investigated building a Brompton front wheel with a Sturmey-Archer drum brake?
Sturmey-Archer | Products
I know Greenspeed in Australia made some — and is currently working on a new batch —, but with labor + shipping, it's a bit pricey.
So I was wondering if it's doable even without being an expert.
Thank you.
Thank you.
Quoted: 381 Post(s)
Liked 107 Times
From the picture it looks doable. I would talk to a wheel builder and get his or her opinion. I have one of those hubs and with a 16 inch rim the spokes are going to be very short. Probably as short as a rear hub using an IGH. Any custom wheel will be pricey. Roger
Quoted: 585 Post(s)
Liked 119 Times
Thanks.
According to this Sheldon Brown page, the spacing of the Brompton fork is 74mm, while S-A offers a 70mm drum brake.
I'm not technical: Isn't it possible to simply add spacers on each side to fill the gap?
As for the actual wheel building, I have access to a DIY bike co-op with a competent wheel builder for help.
I also notice the S-A brake has 36 holes while Brompton wheels only have 28. Sun has one :-)
Palmer
Quoted: 1706 Post(s)
Liked 1,900 Times
Quoted: 585 Post(s)
Liked 119 Times
I just measured: The OLD (distance between the internal side of the dropouts) is actually 70mm, so it looks like spacers wouldn't even be required.
Quoted: 381 Post(s)
Liked 107 Times
A couple of pictures from my junk bin in the basement. NOS SA drum hub and a Raleigh RSW 16 inch rear wheel. Comparing these parts as I said you would end up with maybe 125mm spokes or shorter. Could you give the reason for wanting the drum brake. I ask because I have a Winter bike that uses the drum brake and to be honest rim brakes work better in non-icy conditions. The drums work but as I said they are not a stopping improvement. It is your bike and it will be a good swap but I am not sure what your goal is for doing it. Roger
Quoted: 585 Post(s)
Liked 119 Times
The reason is that braking on the Brompton isn't very good, especially in the rain or after going off-road while touring. Besides, I have to get new wheels after barely two years.
"On the road, the first impression is of near silence compared to a caliper or V-brake. The drum is powerful, but progressive. A gentle squeeze on the lever gives a strong stop of 0.3G – 0.4G, but grab the lever in panic and brake force rarely exceeds 0.56G. In practice, this means that a drum brake is less likely to send you flying over the handlebars than a fiercer and less forgiving V-brake.The drum will also be unaffected by water, oil or mud. In extreme conditions it gets warm, but there’s no risk to the tyre, and it soon cools down. The rear caliper brake is still grinding away at the rim, of course, but we found we tended to make more use of the front drum, so rear brake life should be slightly extended too. When you come to fold the bike, the cleaner front wheel is very welcome." https://www.atob.org.uk/bicycle-acces...ton-hub-brake/
I don't mind ordering custom spokes. At £55 for the hub + £35 for a 36H Sun rim, it's still a lot cheaper than getting a custom fork with disk brake from Kinetics.
Bikes: Brompton, Time, Bianchi, Jan Janssen, Peugeot
Quoted: 598 Post(s)
Liked 5 Times
Why do you need new wheels? I’ve had my bike since 2013 and haven’t needed new anything, except brake pads. Oh, and a new tyre, caused by running well under pressure.
Yes, Greenspeed, recumbent trike manufacturer and distrubuting importer for Brompton, in Australia
has re machined SA drum brakes to fit in the narrow forks, and build wheels around for Bromptons...
they also re machine the frond drum brake hubs to be single end axle supported for their trikes
(Unless they now buy enough to have that work done in the factory.. )
More likely 24 hole rims rather than 28, since the hubs just come in 36 hole...
Or spread the fork out from 74 to 100.. use the hubs as is.
after market electric conversions already required fork spreading.
Schwinnasaur
I put a SA hub brake on a 26" touring bike front wheel and was disappointed with its breaking. YMMD.
As you are in France I'd rather think about getting a 100mm fork with disc brakes from Ben Cooper / Kinectics than to spend serious money for a drum brake on the front of the Brompton if breaking power in the wet and rim wear ist the problem that you want to solve. How many kms did you do on your Brommi in these two years?
Spreading the 74mm fork to 100mm does not sound like a good idea to me. Also in terms of electric support the fork ususally has to be spread to ~80mm on the Brompton, not to the 100mm of normal forks as this is what most motors that are used on the Brompton require.
Part-time epistemologist
Shouldn't one be worried about the extra load on the fork blade?
A narrative on bicycle driving.
YMMV indeed.. I happen to dis like the sudden all at once braking of the BB7 disc on my 20" wheel bike friday..
barely 1 finger or over the bars or off the saddle I come.
and am glad the SA drum brakes on my winter studded tire bike is so much easier to stop smoothly..
now there is a 90mm drum , even more braking surface,
might even be quite fade resistant when held on as a drag brake on long downhills..
Quoted: 585 Post(s)
Liked 119 Times
The S-A drum brake is available in 70mm, while the OLD on the Brompton is 74mm. So, a couple of 2mm spacers could fill the void.
I'm told that Shimano also has 70mm Roller Brake drum brakes, but their web site makes it hard to find infos. It looks like they have two series (BR-IMx and BR-Cx), with the latter being stronger (per an employee at HollandBikes).
At £55 for the hub + £35 for the rim + £20 for a set of spokes, it's cheaper than ordering one from Greenspeed in Australia (£150? including shipping + tariff), and much cheaper than getting a custom fork with disk brake from Kinetics (£500)
Hence the investigation.
yea, You are definitely confusing drum diameter 70 or 90 mm and the axle over lock nut distance which is 10cm .
unless as re-machined custom , which is what green speed did..
they use the inner face of the drum portion of the hubshell drilled, as the other spoke flange.
& cut down the other flange , from what I saw ... looking, 10 years ago..
putting out the money to Ben Cooper in Glasgow, would get you a disc brake front wheel ,
and an Alfine 11 speed disc rear wheel with his custom made front forks and rear portions..
Post Brexit it could cost More..
Quoted: 585 Post(s)
Liked 119 Times
I have mine on an exceptionally stiff Tange ChroMoly MTB fork, not a low cost mild steel Raleigh thimble crown .
you sure the bike pictured did not hit something and it was only from the brake?
Hole all the way thru the lower lug is probably from removing the rod brake linkage.. it likely a 50+ year old frame & fork...
Whoa!
At least it wasn't an aluminum fork!
If you were only worried about long descents and wanted a drag brake, I'd still use an ordinary fork with the drum brake.
Maybe this will be a good alternative for quick stops.
Quoted: 239 Post(s)
The stress on the fork would be very close to the same with a V-brake and a drum brake. The load comes from where the tire meets the road. I have been around a few drum brakes. None of them stopped as well as I would have liked. Try new pads on your BB-7. Mine work great---it is my favorite disc brake.
Quoted: 585 Post(s)
Liked 119 Times
I don't see what BB-7 and disk brakes have to do with Bromptons.
As for brake pads, I'm told to use soft pads, since it's easier and cheaper to change pads than getting/building a new wheel, but that doesn't solve the issue of sad braking in the rain and/or steep descents on a Brompton.
I'm also told having to buy/build a new wheel every couple of years when riding a Brompton frequently is not unusual.
Quoted: 598 Post(s)
Liked 5 Times
I would think the cobblestones in Paris, if that’s where you are cycling, are not good for your Brompton. I tried to avoid them when possible, which was a bit hard when you live on la butte.
The Brompton, as with any folding bike, does have limitations. It isn’t really suited to continuous off road work, nor to rough road surfaces, nor the potholes you find in London. If I were in Paris I’d be going the vtt route as they’re great for everything the Brompton isn’t.
Some discrepances are obvious and for a reason as Brompton has used different rims over the years, brake-pads may be diffierent as is riding style. Riding all through the year or a lot in dirty/muddy conditions fosters wearout. In general rims seem to have enhanced - with the MK2 early wear seems to have been quite common, with the later MK4 wear was something do look for but no dramatic or surprising issue and since the new double-wall rims of 2013 I did not hear from anyone yet who already needed to change the rims due to wear. This is why I am interested in the mileage you have done to your Brompton until now.
However at least one relevant thing is left to mention: Typically the rear rim wears faster due to all the dirt in that area in comparison to the front one. Thus making less use of the rear brake, especially in muddy conditons should enhance the lifetime of the rim massively. Should not be big problem as due to physics most of the brake-power is applied on the front anyway. And regarding riding style: When going downhill in the Alps (or other steep descents) I typically let it roll and do short, hard breakings rather than breaking constantly but less intensive. I would assume that this also fosters the lifetime of the rims.
Personally I did not yet manage to break through the rim of any of my Bromptons, so I seem to be a soulful breaker.
Quoted: 598 Post(s)
Liked 5 Times
Just had my rear wheel off, rim is fine. No idea of mileage, but it is a bit. Of my friends who have Brompton's, including one who does a 20 mile commute each day, they all looked at me in amazement when I asked about whether they have had to replace wheels.
Don't take what people tell you on the internet as gospel, often it isn't. Also, I've yet to find a bike whose braking gets close to that of my motor scooter. The trouble is the narrow width of the wheel, and the relatively low weight of the bike. That said, there's no harm in trying a hub or disc brake out.
