How Big a Cassette Can My Setup Handle In *Practice*
Hi,
I had a touring bike (Fuji Touring 2009). It has Deore MTB RD and a triple 52/42/30. I currently have a 11-32 cassette. The capacity of the RD is 39.
I want to keep the triple but wanted to increase the largest gear in the cassette to have a bail out gear when climbing. It's a SRAM cassette (https://www.sram.com/sram/mountain/p...ur8g12oirsm56k)
What's the largest rear cog I could go to *in practice*? I'm not concerned that there will be a jump b/w the largest and 2nd largest gear.
Liked 2,207 Times
Personally I’d get a touring crank, 24-36-48
working on my sandal tan
Liked 2,579 Times
You're already exceeding the capacity of your RD, so hopefully you're sizing your chain by the big-big+1" method...
Do you know what the model number of your RD (should be stamped somewhere on the back)? I'm finding a max cog of 34T and capacity of 45T for the M591 Deore RD: Shimano Deore RD-M591 Rear Derailleur | Jenson USA
I think this idea has a lot of merit. If you're not using that 52/11 top gear (!), you might be happy bringing down the whole range of gears with a more suitable crankset.
I thought about this, but the bike is perfectly geared for my likings ... except ... sometimes when at the end of a really really long climb, I'd like to just spin at 5mph! This happens very rarely (on climbs more than 1 mile) and changing my crankset (which is fine the other 99% of the time) seems drastic. I'd rather just replace the 32t cog with a 40t or as big as possible as a bailout gear.
Occam's Rotor
My medium-cage Ultegra rear derailleur can handle 11-36, with a 46/30 double crank. Your mtn bike derailleur should be able to cope with something significantly bigger. You can adjust the B-screw if needed. At worst, you have to avoid using the big chain-ring with the lowest cog.
Liked 1,099 Times
What model crank do you have? If it has a separate 74 mm bolt circle for the granny chainring, you could replace the 30T granny with as small as a 24T. That should provide a much lower low gear without altering the upper range of gears.
Liked 4,008 Times
+1. I have done this very swap on many bikes for me, friends and customers. My usual suggestion is going to a 26T granny. Andy
Yes 74mn bcd
How did you get the 24t min?
Cass diff = 32-11 = 21
Crank dif = 52-24 = 28
Capacity = 49
But i won't do that. For the tours I ride the bike is oerfect. I just want a bail out cog. Changing the front ring would mean I wouldn't use many of those gears.
Capacity = 49
Bikes: Surly Disc Trucker, Ribble Nero Corsa, Surly Karate Monkey, Surly Ice Cream Truck, Cannondale MT800, Evil Insurgent
you'd probably be shocked at what 48-36-26 offers for range
You can probably run a 36t large cog with a longer chain and probably clear the cog. You may need a longer b tension screw or turn the existing screw backwards. Your chain will probably run slack in the small small.
I agree that a smaller small chainring or a touring crankset are better ideas. Also you seriously don't need a 52-11 high gear. Consider a cassette with a 12t small cog to keep your gear spacing more reasonable.
I was looking at cassettes and gear ranges a couple of days ago. Assuming you're changing more parts than just the cassette.
The crankset I chose was a 53/39/30, although perhaps there would be an advantage of going with the 48x24 as above, but I like the vintage Dura Ace triplized crank... I think... I hope...
Some will depend on the shifters and derailleurs one chooses.
What I found for derailleurs is the GS is the typical "medium/long" cage. "SGS" is the longer cage.
So, I'm hoping to friction shift an M8000 SGS derailleur with my setup. I think it is rated for a 47T total capacity with a max rear sprocket of 46T.
Shimano has messed around with pull ratios and different derailleurs, so friction seems to be a good, cheap alternative.
If your front chainrings have a 22T difference, then that should leave you 25T + 11T = 37T for the rear... hopefully a little conservative.
But, if you're using the front 30T as an escape, then hopefully you will also avoid cross-chaining 30T x 11T.
Anyway, if not cross-chaining your small/small, one should be able to reach 40T on the rear, or even slightly more.
Perhaps there are other derailleurs with a larger capacity, but this seemed quite large.
I'll let you know how it goes together once the parts arrive.
Also, CliffordK, I definitely haven't tried it out, but there's some chance you won't be able to friction shift through an M8000 derailleur. 11 speed dynasys requires a lot of cable to be pulled for each shift, and its possible the total cable pull of your shifter won't be enough. I'd be curious to see how it works.
