Tires too big
Tires too big
Hi there,
I bought new tires for my fixed gear, but they are too big... can't return them so do you guys have an idea how to fit them on my bike? Maybe polish the frame till there is a pit or something like that. Pretty desperate so any help is welcome!
Thanks
Thanks
Whether this is possible, let alone a good idea, let alone one worth spending your time on, depends on so many things. For one, how much clearance do you need? You're almost certainly better off just buying the correct size tires.
Quoted: 4895 Post(s)
Liked 4,067 Times
Ben
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4383 Post(s)
Liked 3,054 Times
If it's the brake bridge that's in the way - saw it off!
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times
Just install them and ride it. Either your frame will wear in to fit the tires or the tires will explode and you can buy new ones when you get out of the hospital.
52psi
Quoted: 790 Post(s)
Liked 803 Times
working on my sandal tan
Quoted: 3874 Post(s)
Liked 2,577 Times
Get over your fear of confrontation and just about anything is possible.
Liked 2,577 Times
There's something zen about low-information OPs. In the expert's mind, there are few possibilities. But to the beginner's mind, there are many.
Quoted: 5234 Post(s)
Liked 3,609 Times
once broke a tooth on a pit so I vote for not polishing the bike
pro in someone's theory
Bikes: FTP
Quoted: 73 Post(s)
I bought a Tesla but my gas station only carries gas and not electricity. Is there some mod I can do to make the thing run on gas?
Quoted: 278 Post(s)
Liked 122 Times
Could use a gas generator to charge it. Not the fastest but would work. Most of our electricity still comes from burning fossil fuels of some sort.
Bikes: FTP
Quoted: 73 Post(s)
Should I just stick the generator in the passenger seat and run a cable out to the charging plug or rig some sort of harness to attach it to the outside?
Quoted: 278 Post(s)
Liked 122 Times
Passenger seat works and maybe another in the backseat so you can run them in parallel.
Quoted: 278 Post(s)
Liked 122 Times
Run them with the windows up, will help keep you warm during the winter, but roll them back down if you black out.
Last edited by REDMASTA; 02-12-18 at 04:45 PM. Reason: Obviously joking carbon monoxide is bad mkay
Calamari Marionette Ph.D
