First fixed gear!
First fixed gear!
Looking to get my first fixed gear after years of road and mountain biking. I am debating on building a state 4130 frame up with some miscellaneous parts I have lying around plus a Mavic wheelset from velomine or just buying a Surly Steamroller complete. Anyone have any insight? Both frames look to be 4130. After pricing everything out it looks like the State build would be about 300 bucks cheaper with all of the parts that I have.
Dave
Liked 2,962 Times
Building or buying is strictly up to you.
However, give some though to the rear triangle. First of all, you want horizontal dropouts because you want to be able to move the wheel forward and back. Then you might want narrower rear rear axle width. Tyical road frames are wider than needed for SS use, and while you can get a wider hub and still have decent chainline, it's easier with a narrower frame.
FB
Chain-L site
FB
Chain-L site
Some of State's frames are indeed 4130, but they are nowhere near the same quality as Surly. If you can afford the Steamroller, and you know that you are going to love owning a fixed gear, go for it! Also, I think the State has much less room for wide tires. Do you plan to do mostly road riding, or will this bike ever become a SS/FG gravel/winter bike? From what I've ridden from State, I would totally use one of their frames, but probably only if I was willing to upgrade components. Again, not the same caliber as a Steamroller.
hannhann00
Singlespeed & Fixed Gear
61
06-26-15 10:30 AM
jonny4947
22
10-28-13 12:28 AM
