What do you figure is my minimum tire pressure?
Bikes: 2015 CAAD 10; 2016 Felt Z85
Quoted: 156 Post(s)
Liked 5 Times
In order to get a more "cushy" ride on my 2 aluminum bikes, I'm considering lowering my tire pressures...but I don't want to go so low as to make the ride seem sluggish...or get pinch flats.
My tires are Continental GP4000 700x25.
I weigh about 155 lbs...will get down to about 145 during the summer.
What do you all think?
I used to put the pressure up near 100 psi.
Now I have them around 85.
How low can I go?
How low can I go?
![foo](vb/cache//ds.jpg)
How low can I go?![foo](vb/cache//ds.jpg)
How low can I go?
Adjust maybe 10 psi for your weight? I'm not sure I would try anything below 80/70. I think you're at a pretty good pressure right now...wouldn't change it drastically unless you get a bigger tire, but I'm assuming you're maxed with your clearance already?
Quoted: 20810 Post(s)
Liked 9,456 Times
Lower it by 5 psi and try it out for a week. If all seems well, rinse and repeat. If you get a pinch or if it starts to feel bouncy even when pedaling relatively smoothly, go back to the previous week's pressure.
Quoted: 6392 Post(s)
Liked 4,988 Times
Record your stats for 200 rides and post them. Make sure to record your tire pressures for each ride and post that as well. When you are finished, well get back together here and argue about it.
working on my sandal tan
Quoted: 3874 Post(s)
Liked 2,579 Times
How low can I go?
![Thumbs Up](images/smilies/thumb.gif)
![Embarrassment](images/smilies/redface.gif)
Veteran, Pacifist
Quoted: 3949 Post(s)
Liked 4,954 Times
Why go below 85psi?
Do you want squishy handling? Lower mileage tire life?
If you want a softer ride go with a fatter tire than 25mm.
For a cushier ride = suspension seatpost or a big, big fluffy sheepskin saddle cover.
Liked 2,579 Times
I weighed about 147 lbs after completing PBP. It's probably the closest I've ever come to resembling a pro cyclist.
![lol](images/smilies/lol.gif)
Hop on the bike, look down at the tire. I try to shoot for approx. 2mm of deformation/spread.
Should Be More Popular
Quoted: 22771 Post(s)
Liked 9,169 Times
![Big Grin](images/smilies/biggrin.gif)
Bikes: Trek Emonda SL6, Santa Cruz Tallboy 27.5+
Quoted: 37 Post(s)
Liked 9 Times
My bike and I weigh 190# and use the same tire. Scale indicates about 40%/60% of the weight F/R. Presently pump 70/85 psig F/R. Every ride gets logged. I don't seem any faster at 20 psig more. But I do suffer fewer flats or tires destroyed by cuts using lower pressures. No idea what minimum pressure is/not willing to make that experiment either. (I do not race).
Quoted: 63 Post(s)
I weigh in the high 150's in season and run 75 and 82 with 25's and our roads here are terrible. Have no problem keeping up and outriding geniuses who think that riding 120psi makes them faster.
Liked 9,169 Times
I know, right? Common newbie and/or know-it-all mistake is that "max" pressure printed on sidewall is best.
Veteran, Pacifist
Liked 4,954 Times
Handling at speed suffers. Maybe not "squishy" at 155# but not ideal.
For just riding the smooth paved bike trails, the OP could probably run 40-50psi, if that's the style of riding.
Softer ride = wider tires designed for lower pressures. Or suspension post, sprung saddle, etc.
YMMV
Quoted: 18596 Post(s)
Liked 16,098 Times
Sound like the OP needs a carpet fiber bike for maximum comfort.
Quoted: 63 Post(s)
YMMV
YMMV
Veteran, Pacifist
Liked 4,954 Times
The question was How Low? I wouldn't run a 25mm tire below 80-85psi, unless the style of riding was trails and/or moderate speeds. In post #16 I stated OP could likely run 40-50 for some rides. To what purpose, slick road, soft surface? Surely not better tire performance (or a criterium race???).
On any ride I may hit 35 - 40 mph on a downhill run, there may be irregularities or bumps in the road at speed, or a pothole to jump/dodge. For this type of regular riding I prefer to run a tire inflated near it's designed range - for performance and tire life.
If I want a cushier ride I ride a larger tire designed to perform at a lower pressure.
Simple as that.
edit: I'm running tire widths from 22mm (25, 26, 28, 30) to 32s with small knobs. All tubulars and my pressures run from 40 - 110psi. Then there's the mtb with 26" wheels (for where my 700c roadies prefer not to go) on which I vary the clincher tires and pressures based on terrain type.
Simple as that.
Quoted: 4655 Post(s)
Liked 1,794 Times
Not sure why anyone is arguing about the subject:
![](https://www.biketinker.com/wp-content/uploads/2010/08/BQ_berto_inflationgraph_2.jpg)
This is based on weight per wheel. Going under these pressures increases the risk of pinch flats.
Liked 9,456 Times
This may have been the prevailing wisdom a handful of years ago, but not any longer.
![Mad](images/smilies/mad.gif)
I'm 190 # plus the bike/gear and am on 28mm GP4000s. Kinda wondering how much below 80 psi I can go
![Smilie](images/smilies/smile.gif)
