Any aerobar users here?
Quoted: 1872 Post(s)
Liked 671 Times
Looking to discuss comfort aerobar installation and setup.
just another gosling
Quoted: 3920 Post(s)
Liked 1,988 Times
Yup. Used them since my first double ~1998. I bolted a set of Syntace C2 bars on my regular road setup, didn't change anything. Have had them on my bikes ever since. Both I and Stoker have them on our tandem. One of my Trek's rando configurations: Goes right along, it does.
Results matter
Results matter
Quoted: 1072 Post(s)
Liked 807 Times
R U talking about clip/bolt on aerobars or actual aerobars?.... https://www.pro-bikegear.com/global/..._VIBEAERO.html
Liked 671 Times
I would probably start with bolt-on, most likely Profile Design. I'm nowhere near buying a tri-bike or setting up a dedicated rando bike, beyond what I have now.
Based on your link, I currently have some conventional bars on a road bike. I would add a set of clip-ons to that bike. My overall interest is to reduce wrist pain while my fracture rehab goes on, and to discuss fitting requirements related to that.
Beyond that, metric century in July!
Liked 671 Times
Liked 1,988 Times
IME low works just fine for brevets, though some RAAM riders have multiple heights, low for headwinds, up for resting with no wind or tailwinds on the flat.
An advantage of the riser blocks with Syntace bars is that then your hands will fit on the bar tops under the pads. Their pads don't pivot up.
Results matter
Results matter
Quoted: 182 Post(s)
I use profile design bolt-on aero bars, not for aerodynamics but for an additional arm position on long rides. My handlebars are high, upright fit. Aero bars, properly used, require a different (aero) fit but I use them with a standard road fit and adjust them appropriately (shifted more rearward). My elbows are at around 90 degree angles when in the aero bars.
I like them, but they interfere with traditional front rack/decaileur/ bag set up.
Quoted: 1228 Post(s)
Liked 643 Times
Another profile design aero bar user. Just bolted the cheapie ones to my drops. Gives me two extra hand holds - the aero position and grabbing the pads I can sit completely upright. The downside is I've lost use of the flats, kind of, I never really used them anyway. I may eventually buy the aero bars with pads that are spring loaded and move out of the way.
It's nice for windy conditions or if I want to stretch out a little.
Randomhead
Liked 3,802 Times
I was thinking about it on Saturday's 300k, we had a headwind for 190 miles. Recent threads about aerobars:
https://www.bikeforums.net/long-dist...aero-bars.html
https://www.bikeforums.net/long-dist...bars-both.html
Wouldn't be without my bolt-on aerobars for anything longer than six hours, even with no wind. Used to suffer with palm and wrist numbness before I started using them, not any more. I'm probably in the aerobars 70% of the time I'm not drafting someone. It's not even an especially "aero" position, it just feels super comfy and efficient.
The problem with Syntace aerobars, (unless they've changed their design) is that there isn't any way to adjust the pads fore/aft... an adjustment that is almost always needed when mounting aerobars on a road/endurance bike.
Warehouse Monkey
Quoted: 305 Post(s)
Liked 7 Times
'10 Specialized Hardrock
Randomhead
Liked 3,802 Times
can you use the tops with that setup?
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 225 Post(s)
Liked 164 Times
Quoted: 2236 Post(s)
Liked 1,315 Times
It's ok but I think there are also better choices out there. This one has some padding that takes up interior room and the clear plastic (meant for a cell phone) is small and opens at the top, so that rain can enter and flood it (poor design). On the plus side it holds my phone, camera and/or food and has small mesh pouches on the side to fit two clif bars in for easy access.
Stevoo
Yes, absolutely when doing anything 100mi or more.
Being able to grind along while upper body, arms etc are snoozong is awesome.
Aero is also a nice benefit.
If you have never used them before you are in for a treat.
Good luck.
Good luck.
Kamen Rider
Bikes: Fuji Transonic Elite, Marechal Soul Ultimate, Dahon Dash Altena
Quoted: 351 Post(s)
Liked 277 Times
I've been thinking of installing a pair, but worried if I get too used to them, it would be a pain to get un-used to them for brevets that do not allow them.
Liked 1,988 Times
In my case, they fit perfectly. My opinion is that if your reach is dialed in the way I advocate - elbows forward of knees when on the hoods with horizontal forearms - and if one buys the correct length, they'll work fine. I like the shape, sturdiness, and adjustable width pads, which are replaceable. I've worn out 2 sets of pads.
Results matter
Results matter
Liked 1,988 Times
No, those are battery. I was only doing 400s or less and battery worked great for only having to ride in the dark for a couple house, if at all. Lighter, simpler, cheaper.
Results matter
Results matter
Liked 1,988 Times
socalrider
Tandem Cycling
9
06-19-17 11:12 AM
TrekCommuter
9
07-08-14 09:02 PM
