Trek Madone 9 aero brake, adjusting bolt
ride lots be safe
If you know the new Madones you know there is no barrel adjuster; instead there are 2 tiny allen head bolts per brake (1 per arm) that are set at an odd angle and need a Bondhus head wrench... well I've managed to bung mine up and I need a replacement.
My question: Are these a standard size allen head that I can get at any hardware store? Or must I order via my LBS?
Linky to a diagram showing the bolts in question as part of a larger kit
https://www.trekbicyclesuperstore.co...-kit-17685.htm
I only need the "medium" of the 3 pictured. Trek calls them "pad width spacing bolts"
thanks
thanks
