Surly Big Dummy Panniers
GadgetJim57
Does anyone use the Surly Big Dummy Panniers ? Reason I'm asking … Just how water proof are they ?
You could carry stuff in ziplock or dry bags inside the Dummy Bags for water protection.
derby@surlybike.com
GadgetJim57
I don't own Dummy Bags, but neither product description nor linked pdf instruction mention waterproof, instead water-resistant is mentioned twice. Knowing how this is an often exaggerated feature of bags, I deduce that Dummy Bags are not waterproof. Send your question to Surly with an email, you'll likely get an answer Monday. Also you might want to look for an answer in the Utility Cycling forum.
derby@surlybike.com
derby@surlybike.com
Clark W. Griswold
Quoted: 4461 Post(s)
Liked 4,130 Times
I am pretty sure the Surly bags aren't waterproof but luckily sea to summit makes some excellent dry bags some even with eVent in them so you can compress them without a valve and no water ingress and even do a lightweight ultra-sil one. I seem to remember seeing someone put two sets of Ortliebs on a Big Dummy or some similar long tail and it was pretty nifty however I probably wouldn't want to carry that level of cargo schlep wise.
GadgetJim57
categorically, a bag sewn together , has needle holes in it ..
I'd put dry bags inside the dummy bags if you really need to keep things dry.
I own one. No, they are not waterproof.
However, they do hold up ok in slight drizzle if you make sure you close them so no water can drip in. Also, they have drain holes at the bottom so water will not pool in them. As other have said, any items which you are worried about getting wet, use dry stuff sacks in the big dummy panniers.
Overall, the big dummy panniers were made to be able to expand to carry whatever you may want (as I have taken a hibachi grill and a bag of charcoal in them on one side and a cooler of drinks in the other for a day to the beach).
Bikes: 2017 Kona TI, 2016 Bike Friday Haul-A-Day, 2015 Bike Friday New World Tourist (for sale), 2011 Mezzo D9, 2004 Marin Mount Vision Pro - for now :)
Quoted: 103 Post(s)
Liked 5 Times
GadgetJim57
Quoted: 103 Post(s)
Liked 5 Times
They have all kinds of niggly little clasps used for closing them as I remember. They don't close very well either. I just remember it took much more time to close them up, and they just didn't close as well as the Xtracycle panniers. The X panniers are way better.
GadgetJim57
So, I'm looking for other panniers …..
GadgetJim57
These panniers look promising …. I might give them a try …..
>>> https://www.rei.com/product/118736/y...mmc=PLA_Google 404_8604 1187360001 none b8904aae-456e-4e36-928c-d6bd4415c819 pla-183690896200&lsft=cm_mmcLA_Google_LIA 404_8604 1187360001 none b8904aae-456e-4e36-928c-d6bd4415c819&kclid=b8904aae-456e-4e36-928c-d6bd4415c819&gclid=CjwKCAjwhqXbBRAREiwAucoo-6ZtL1kOMcyk16Y---XKbehcKAGfDIdfFo64rv3wecMgd4sB6o3S-BoComEQAvD_BwE
GadgetJim57
I need panniers big and long enough to secure my spotting scope, head and tripod …..
Quoted: 103 Post(s)
Liked 5 Times
Not what I’d do but depending on the horizontal diameter rack tubes you have you can put double set of panniers from any of the companies that sell those as waterproof. I kept my set from the Xtracycle when I sold it though and use them on the Bike Friday Haul A Day and they hold a lot and they are quite durable.
