2 vs 4, a brake lever dilemma
With a mighty wind
Today I will be finally taking all the parts I've amassed and the frame I had powdercoated, and turning it into a bike.
I'm happy with what it'll have and hopefully it'll ride well (can't test ride a bare frame).
I've got a pair of interrupted brake levers on the workbench. I didn't pay for them, they were on my wife's bike and she hasn't touched it in at least 3 years. I don't know if I want them or not. A friend rides them and loves them. I've also read that they suck unless commuting in traffic (which this bike won't have to endure). The bike has canti brakes and 42cm low drop "gravel" bars. There is room on the handlebars for the levers but not a ton. I won't be putting a computer or bell or anything on my bars, I much prefer the GPS watch. My current plan is to ride steep unpaved roads. I also have my sights set on a few trails that are considered non technical by mountain bike standards but are still trails, not roads.
So I'm going to go into the garage to finish the wheels I laced earlier this week. I'll check back here once in a while and hopefully I'll have some sage advice before I've gotten to the cable routing part of the assembly.
Sunshine
Liked 7,741 Times
I have yet to ride a drop bar bike and want interruptor brakes.
just never found a situation where i wished for them.
a wider stance on the bars makes me more comfortable when riding gravel downhill, so interruptor brakes arent much use there.
It depends on the cyclist.
I have been riding drop bars since a young kid. I never used to ride from the hoods (vintage brakes), but have recently come to like the hoods on more modern brakes.
No matter where my hands are on the bars, I can reach the brakes almost instantly.
My Tricross came with the interrupters. Even if I am riding on the tops of the bars, I never think to reach for them. The regular brake levers just work for me.
However, the answer may lie in the types of riding you're doing. If you are doing technical riding holding the tops of the bars, then the cross levers may work well.
On the other hand, if you tend to ride on the hoods or drops for technical riding, then the cross levers would do nothing for you.
With a mighty wind
I fiddled with the levers for a while and couldn't find a spot I liked them. I thought they were in the way and it felt like my fingers would get stuck under them. I also thought they were too long, I might have sawed an inch or so off the ends to really like them. It was enough strikes against them that I chose to leave them off. They're still in my pile of stuff if I feel that I need them later.
Liked 4,078 Times
One real plus of interrupter brakes is that on really steep descents, you can get your weight further back. If you are going to see steep gravel, that might make them worthwhile. Drawbacks are very few, I have them on one bike set up as a gravel rig. One nice place to use them from is right out at the bend, using two fingers on the end of the lever. That leaves a lot of real estate for additional clamps on either side of the interrupters.
When I am not using them, I am completely unaware of their presence. On the regular levers, I feel no difference at all. (Edit: I set them up so they are hidden behind the bars when I ride. If I cannot see them, they don't slow me down. The well documented corollary to the placebo effect.
Ben
![Smilie](images/smilies/smile.gif)
Ben
like we used to say
I like them when I'm on the bar tops and drinking from the water bottle. For some reason, I tend to pull from the bottle when I'm coming to a stop for an intersection. My new bike doesn't have them, so I've learned to drink at a different time.
Sunshine
Liked 7,741 Times
with those inclusive disclaimers out of the way, I'm surprised interruptor levers are appreciated during steep gravel descents as that places the hands at a relatively narrow width.
for steep gravel descents, I like my hands wide apart for control as it slows down the steering. It's a big reason why flared drop bars are popular on gravel bikes- a wide stance slows and stabilizes steering on sketchy descents.
to each their own though. Clearly there is appreciation for narrow hand positioning on loose rock descents since more than a few in this thread have said they like it.
I know the near-consensus is they suck and are bad to have. I think some of that comes from ancient road bikes that had suicide levers, good interrupter brakes actually do work, they'll stop the bike when you pull them.
I haven't had these for about 10 years, and haven't missed them. But I used to have a CX bike that had them. And I used them when they were available. Sometimes taking a more upright position makes you more visible in traffic and they were great for that, but I also used the tops more as a hand position because I could reach the brakes more quickly.
Liked 4,078 Times
to each their own, everyone rides different, etc etc.
Ben
I have 1 bike with Cross, top mounted , interrupter brake levers ,
it's a Cyclocross type bike..
your Gravel competitors seem to like Cyclocross bikes ..
I have 2, that do not, My Road, and Drop bar touring bike..
YMMV
(I changed from a 2 finger to a 4 finger brake lever
on my V brake Folding bike, now the lever is under my fingertips)
YMMV
atalamark
Classic & Vintage
6
06-14-16 09:26 PM
Heatherbikes
Bicycle Mechanics
2
09-30-12 06:41 AM
