Regenerative, revitalizant grease for bicycle?
Bikes: CIty bike NEXUS 7
Quoted: 26 Post(s)
I was looking for best grease to use in bicycles primarelly for ball bearings and discovered interesting XADO revitalisant grease that can actually regenerate wear in ball bearings. It was developed by ukrainians and I didn't find any other greases that can do that so I'm a bit sceptical if they would work. I asked manufacturer if they could be in bicycle and they told me that do to low revolutions and friction effect would be little. Although as daiy commuter friction and wear is more significant but at extended time, so I'm not sure if heat for example is important for regeneration. Currently I'm using graphite grease which I do not like because it is so dirty and hard to clean away. I plan to get either PTFE, lithium or XADO grease. Which would fit best? Here is XADO video where on purpose damaged ball bearing race is regenerated using lubricant:
You are dealing with minimum loads and speeds so any good auto grease should be fine. I use Lubriplate EMB. https://bike.bikegremlin.com/2015/06...earing-grease/
Quoted: 2405 Post(s)
Liked 2,995 Times
If you can get it, just a tube of Phil's and unless you are refurbishing hundreds of bike you are good for years. Most people use way too much grease anyway
Life is too short not to ride the best bike you have, as much as you can.
Quoted: 18459 Post(s)
Liked 4,564 Times
Anyway, this super grease might be worth trying if it can reduce wear and damage.
Quoted: 2027 Post(s)
Liked 1,099 Times
Generally bewildered
Quoted: 1152 Post(s)
Liked 342 Times
No flippin' way. You might get better performance out of shot bearings by cleaning and using this grease. But you'd get that from any grease. Plus, you have to replace bearings every what? 3 years? The cost of new bearings is not bad, and I don't care how revitalizant this grease is, it ain't gonna fix bearings to be as good as new bearings.
Plus, at 15 bucks for a 15 ml syringe, you're paying a pretty high unit price. Why pay that much to get a dubiously revitalizanted old clapped-out bearing, when you get a new bearing for just a little more?
Bikes: old ones
Quoted: 26482 Post(s)
Liked 10,449 Times
Quoted: 26 Post(s)
Liked 1,099 Times
I'm going to use grease for internal hub and generator hub ball bearing cup and cone lubrication for parts to last as long as possible because they are expensive to replace unlike in ordinary bicycle ball cup and cones. Although ball bearings themselves are standard and pretty cheap.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
I'm going to use grease for internal hub and generator hub ball bearing cup and cone lubrication for parts to last as long as possible because they are expensive to replace unlike in ordinary bicycle ball cup and cones. Although ball bearings themselves are standart and pretty cheap.
Mechanic/Tourist
Sturmey Archer 3 speed hubs have lasted for decades using just plain ol' oil.
Quoted: 111 Post(s)
Liked 5 Times
So the solution is to just change the oil/grease once a year, or maybe every 6 months if you're really cautious.
Even the cheapo lithium grease at wal-mart is good if you just remember to change it before it spoils.
Quoted: 26 Post(s)
I found one XADO patent describing process of revitalisation. XADO patent
I do not understanding all technical terms but in Wikipedia it is explained simply as treatment forming a protective cermet or ceramic-metal coating on the friction metal parts of the mechanisms directly during the process of their operation. Revitalizant
XADO patent also mentions use of "roller nanobearings" which further reduce friction. I actually remember hearing once about revitalising car engine additive that forms metal ceramic coating on friction surfaces. What is not clear to me are conditions of this protective layer formation. If I'm correctly understanding there are mentioned conditions for revitalizant nanostructure to form - optimal temperature (700-1,200° C.) and time (1-3 hours) conditions. Since bicycles are so much more efficient than engines, have lower friction and temperatures in bearings how well revitalisation would work out.
