3 different approaches to ride comfort: which will be best for gravel?
4 different approaches to ride comfort: which will be best for gravel?
Panaracer Gravelking SK 700x43 tire in each case. By comfort I mean: both dampening bigger bumps and killing road buzz. The contenders are:
1. Canyon Grail with carbon frame vcls seatpost and hover bar to add comfort when ridding on tops. Tires set tubless.
2. Specialized Diverge E5 comp Alu frame with vcls seatpost and future shock adding suspension regardless of your hand position. No tubless due to Specialized rims.
3. Giant Revolt 2019. Carbon frame and D-fuse seatpost and handlebar that works when you are on hoods or even better on drops. Tires set tubless.
I would rule out bikes like Revolt and Canyon because they are limited to give comfort only in particular situation. Diverge is an interesting solution but very expensive for what it offers. I have steel Jamis Renegade with VCLS 2.0 seat post so I believe that there is no bike with more comfort at the rear end. Problem for me is front of the bike but I think that Shockstop stem will solve that and in the end I will get the bike that beats all of above bikes in terms of comfort. Hopefully
If not, there is always a possibility to run a bigger 50c tire in the front which I am also considering (but I would need to change rim to do that properly).
![Smilie](images/smilies/smile.gif)
- Soli Deo Gloria -
Liked 736 Times
The hover bar is for riding in the drops, not the tops and has nothing to do with dampening bumps or vibration.
-Tim-
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/624x330/screen_shot_2018_09_25_at_6_29_11_pm_13991a2dad7791e113fba34542dbc59426d95321.png)
I love my Grail. I thought the bar was hideous... 'til I rode it. The bike is really (!) comfortable. Granted, my road bike is a Scott Foil with about 6" of drop from saddle to bar, so hopping on the Grail is a big jump in relative comfort. AND, it's the only gravel bike I've ridden.
Flounce
12
09-17-17 03:58 PM
hunti
25
10-05-16 09:34 AM
Jarrett2
29
08-12-14 11:59 PM
