Which Road Shoe Cover/Bootie?
Quoted: 1638 Post(s)
Liked 741 Times
I am looking for a shoe cover/bootie that can get me into the 20's F for 2+ hours riding time. I have a couple of pair of insulated covers and wool socks, that an hour into a ride, my feet are numb from the cold. I have two bikes I ride with spd-sl pedals that I will use until the temps get to 20 or so. I then switch the pedals on one bike to spiked platforms with a winter shoe combo for those snow, ice, or below 20 temp rides.
I would consider a dedicated winter road shoe but for the few times a season they would be used, I can't justify the price.
TIA
TIA
nine mile skid on a ten mile ride
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Have a look at Grip Grab.
https://www.gripgrab.com/collections/road-shoe-covers
You might be interested in the Arctic or Arctic High-Vis.
I'm using the lighter Race Thermo version down to the high 20's with no cold feet. If the temps go lower then I'll use chemical warmers.
The are not available through US retailers but can be ordered through Wiggle. Size up.
-Tim-
-Tim-
Liked 741 Times
-Tim-
-Tim-
They look promising, only concern I have, without some type of closure how difficult are they to pull on over your shoes?
I watched the video, they look easy enough to pull on, though I am dealing with arthritis in both hands.
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
I would just buy a winter shoe and use a cover then you can just worry less and be warm its just money , i dont mind a few measly hundred bucks for shoes im going to use to stay on the bike .
But the cheapest option i use is two large wool socks 80% wool size 12 plus . cut a hole out for my cleat and glue emergency blanket strips in between the socks . i use a fishing line to sew the hole edges together for a clean look . cost so far is 8 bucks . but they are not waterproof yet . i do have a roll of duck tape to make them , and i plan on cuttin the backs open to install a zipper or velcro for faster on and off. But if it is raining and below 40 id just stay indoors get a better work out in the basement safe and dry.
Quoted: 800 Post(s)
Liked 218 Times
TIA
TIA
Besides two layers of thin and thick socks, I use neoprene booties with openings for cleats, and wrap around Goretex shoe covers with open soles (available at Belmont Wheelworks). I might use plastic bags inside the shoes as well.
I distinguish "booties" (tight fitting neoprene shoe covers with an open sole for clip-ons) from this wrap-around Goretex "shoe cover," with an open sole secured by elastic straps. I find they provide good rain cover, especially over booties, as well as windscreen.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
IMO, any of the higher-quality neoprene overshoes will probably do the trick. You might have a look at Wiggle; there are quite a few options available at a reasonable price. I'm using SealSkinz with thick wool socks and road shoes and doing well into the 20s for 2 hours.
I have yet to try chemical warmers, but they might be a good idea - this time of year in Wisconsin, you can get a huge handful of them at the grocery store for like $5.
Someday I might invest in winter cycling boots (and the corresponding SPD pedal system that I'll need), but it's hard to justify, especially when that investment is halfway to an entry-level fatbike.
Mad bike riding scientist
Quoted: 6296 Post(s)
Liked 4,333 Times
TIA
TIA
I would also suggest a larger size shoe for winter riding. Those wool socks are thicker and a close fitting summer shoe is just going to cut off circulation.
Stuart Black
Stuart Black
- Soli Deo Gloria -
Liked 736 Times
Any old neoprene will do but what sets different shoe covers apart are the seal and closure. Some are better than others.
One of the reasons I was drawn to the Gripgrab product was complete lack of zippers. The "Intelliseal" system at the bottom is very effective at keeping moisture and cold air out. The Kevlar hem and toe are a nice touch in terms of durability.
I'm not saying they are the best in the world and they certainly are not inexpensive but they are one of the better designed products out there.
They go on the leg before the shoe is put on and pulled down over the top of the shoe. The "X" off road versions are slightly more difficult to put on than the road version but both go on just like the video shown below.
I can't speak to how it would be with arthritis but my day will come, probably sooner rather than later.
-Tim-
Thanks for the recommendation, these never came up in my searches.
-Tim-
Shoes may just be too tight, so circulation constricted, and then the insulation,
being stretchy is not helping either.. it's pulling tight, too..
and SPD cleats can be heat sinks sucking the heat out ..
Liked 741 Times
https://www.youtube.com/watch?v=xbGIgqYLY9Q
-Tim-
-Tim-
I decided to give them a go. I ordered a pair through Bike24. Wiggle was showing size XXL as the only size available, according to their sizing chart I required a XL.
I watched the video prior to purchasing, they didn't appear that they would be too difficult to pull on.
I'll need to make sure I use them with my looser fitting shoes. I should have kept the pair of Sidi's I gave away, they were a little oversized.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 407 Times
Liked 4,333 Times
The difference in warmth and ease is night and day. I should have done it sooner. Only problem--is that they're so warm that much above freezing they're almost too warm....so if you have say a 20F commute in the morning they're perfect--but a 40F afternoon commute they're too hot.
Stuart Black
Stuart Black
Yup
Location: where the sunbeams end and the starlight begins
Bikes: Kona Unit, planet X cx bike, khs fixed gear
Quoted: 9 Post(s)
Liked 6 Times
I like these. Gore c5 insulated. They don’t look stylish, but they are very warm.
When sadness fills my days
It's time to turn away
And then tomorrow's dreams
Become reality to me
Quoted: 46 Post(s)
A little late to the convo but I wear neoprene socks over thin liner type socks. They keep my feet warm up to 2 hours before I have to start wiggling them to keep the blood moving. For shoes I wear regular running type shoes from Target that I don't mind getting dirty or we
- Soli Deo Gloria -
Liked 736 Times
Can you say more about them?
Are they waterproof or resistant? What does the bottom look like? Durability?
-Tim-
Yup
Quoted: 9 Post(s)
Liked 6 Times
I can’t comment on being waterproof, haven’t used them that much. They are supposed to be water resistant. They are warm. My commute is 1 hour. Normally I’d wear thicker socks with toe warmers for anything below -5C. With these my feet are warmer at that temperature without the warmers and with mid weight wool socks. I have the l/xl and the fit fine over my size 12 shoes. They are pricey for booties, but compared to winter shoes a good price. Really happy so far
trailmix
20
03-03-14 09:43 AM
kayakplayer
Winter Cycling
12
12-30-10 04:46 PM
