Complete SRAM Level-T Haydraulics w/ Rotors
Complete SRAM Level-T Hydraulics w/ Rotors
Complete SRAM Level-T Hydraulic Brakeset -- upgrade your old cable disc brakes on the cheap!
EVERYTHING you need to go hydro: Front and rear levers, calipers, rotors, and all mounting bolts. Excellent condition. These came off of my new Kona with fewer than 200 miles on it. The rotors and pads have bedded in, but they still have their full lifespan ahead. The lever feel and modulation are a huge improvement over cable-actuated brakes!
Levers: Tooled reach adjust. Cast body and lever blade, bushing lever pivot. DOT 5.1 fluid
Calipers: 2-piece 21mm pistons and fixed hose routing. 2-piston caliper design. Top-loading, steel-backed organic pads.
Rotors: SRAM Center Line 160mm (R) 180mm (F)
$150 shipped, Paypal only.
