You ever have a rattle you can't find?
Liked 237 Times
I don't need help. I'm just venting.
You ever have a rattle you can't find? When I ride I hear a rattle. It's clearly metal on metal. It's a very distinctive sound. It sounds like a loose bolt with a washer rattling between the bolt and the frame.
BUT I CAN'T FIND IT!!!!
I can't pinpoint where it's coming from with my ears when riding and I can't recreate it at home on the rack.
I've tightened every both.
I've looked at every place 2 parts meet on the bike. Bolts, fork, wheels, handlebars, you name it.
I've taken the bike apart and put it back together.
And the rattle is still there.
It's not loud. It's not annoying. It's not interfering with the safe operation of the bike.
It's just cheesing me off that I can't figure out what it is!
Thank you for listening. I feel better.
Liked 3,612 Times
it wasn't uncommon for one of my wing nuts that held my rear rack to loosen. but when I moved it to another bike I changed the hardware. so when a new rattle became obvious it took a while to find, but I found it. a diff. wing nut on the bottom of the rack was tapping the top of the rear fender. so I glued a small square of foam rubber door sweep/insulation at the contact spot
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/833x482/wing_nut_tapping_89bbaf5c6fbd52ac7327af783bbaa229544bef1f.jpg)
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/1101x768/80-p1120656_ea3e3e885c74dcbd565206403d2be74a6435aa1d.jpg)
waiting for the next rattle to appear ...
![Roll Eyes (Sarcastic)](images/smilies/rolleyes.gif)
I used to ride with a crew, and one of the guys had a press-fit BB that creaked on each pedal stroke. I could barely stand to ride near him. I can't abide a noisy bike.
![lol](images/smilies/lol.gif)
(It was a crappy gas pipe SS conversion in the first place and I sold it to a college kid for like $60.)
Liked 237 Times
The noise doesn't bather me at all.
The fact that I can't figure out what the noise is bothers the hell out of me!!! hahahaha
Bikes are okay, I guess.
Liked 2,452 Times
I actually did this to myself while overhauling a headset, dropped one ball and it went past the upper cup and into the vent hole in the head tube into the top tube. What are the odds? Could not do that again on a bet. Didn't worry about it until the first ride and decided it would drive me crazy so made sure the ball rolled to both ends of the top tube and then pulled the seatpost and dribbled some Elmer's glue into the back of the top tube through the hole in the seat tube, tilted the bike back so the ball rolled into the glue and left it like that overnight to set up. Problem solved.
Perhaps there's a bit of weld flux or small debris inside the rim. If you have another bike with the same wheel size, swap them out and see if the noise persists.
Liked 620 Times
On my Davidson the chain stay internal cable routing tube was loose, only rattled under bumpy conditions. Took forever to find but a shot of foam insulation through the BB has fixed it for the past four years.
Liked 1,099 Times
+1 . I had a Mavic rim with a scrap of metal inside, probably a leftover from when the spoke or valve holes were punched. At low speed the rattle was annoying. It was hard to trace since it disappeared at higher speed when the centrifugal force (yes Physic Majors, I know that's not technically the correct concept.) would pin the scrap in place and quiet everything down until I slowed down.
I had a clicking metallic noise for a few hours on ride before. It did not follow any other typical pattern of any other random noise I had before. Eventually narrowed it down to intermittent only when I sitting, going at slow speed and only when pedaling with decent power on the down stroke of my right leg. Turned out to be the hard plastic aglet from my shorts string hitting my aluminum top tube.
I believe any noise on a bike is a bad noise and for most people myself included, good or bad... it circulates in your mind often with the highest priority and frustration.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Liked 2,038 Times
I had a clicking noise on each pedal rotation. The shop owner helped me find the source, I had a cracked chain stay.
Liked 4,081 Times
I rode several years with the head of a nipple rattling inside my rim. I knew what it was, Had I been home when I replaced the nipple, I"d have pulled the tire and fished it out, but I was on an organized ride and wanted to get back to it. The rattle would come and go depending on where the nipple was, how fast I was going and how rough the road.
Ben
Ben
Liked 2,631 Times
I've had a weird ping noise that correlated roughly with my pedaling cadence. It was hard to pinpoint. It turned out that the waist drawstring on my jacket had a little plastic ball on the end, and it was bouncing on the top tube of the bike.
Liked 2,807 Times
Oh, yeah.
Seems trickier on my frames with oval tubing. Something about it transmits noises away from the actual source. On my conventional frame Centurion the noises seem readily apparent. But on the Univega with that spiffy Bi-Axial Power Oval frame, the oval top tube is thin, pingy and resonant, almost like a chime. So it's tricky to track down noises -- everything resonates in the top tube.
Recently chased down a squeak that finally motivated me to redo the bottom bracket. Turned out to be a dork disk I'd forgotten to remove when I'd swapped out the 7-speed cassette for 8-speed. The 32T big cog hid the smallish dork disk so I forgot it was there. On the plus side, it did motivate me to redo that BB, so... not completely a bad thing.
Intermittent squeaks that turned out to be my shoes rubbing against the crank arms.
And the thing [MENTION=152773]noglider[/MENTION] mentioned -- clothing or other stuff pinging against the bike.
Shoes catching an overlong bit of cable on the front derailleur, causing it to snap back and ping the frame.
And, once or twice, an actual mechanical issue that needed attention, mostly because I stupidly sold my torque wrench several years ago thinking I'd never need it again and now resort to guesstorquing. Like a slightly loose crank arm on a square taper BB. A retaining ring on a new cassette that needed tightening. Or trying to adequately tighten a chainring bolt without the little nut wrench to keep it from spinning uselessly.
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Liked 270 Times
Step 1: Tighten both of your hubs' quick releases
Step 2: Get a mechanic's stethoscope from an autoparts place for less than $15
I had a creak I could not find. Sounded like the bottom bracket to me:
~I tightened all the chainring mount bolts, still squeaked.
~Removed, cleaned and reinstalled the chainring bolts to the correct torque, using a star pattern. Still squeaked.
~Removed clean chainring bolts, applied some light threadlock on each and torqued them back on in a star pattern. Still squeaked.
~Removed crank mount bolt, reinstalled it and the lockbolts to the correct torque, alternating in stages as recommended by Shimano manual. Still squeaked.
~Removed entire crank, cleaned, regreased and reinstalled using correct torques, and alternating... Still squeaked.
~Removed clean crank, tightened bottom bracket to correct torque. Reinstalled everything... torques and alternating... Still squeaked.
~Removed crank and bottom bracket. Applied teflon tape to bottom bracket threads Reinstalled...torques, alternating... Still squeaked.
~Bought new bottom bracket. Torqued on new BB correctly with teflon tape on threads...torques, alternating... Still squeaked.
~Rode with squeak for several weeks, endured ribbing from friends. Also twisted feverish dreams about mice, about biting pieces of metal off my bike and chewing them slowly as my teeth broke, filling my mouth with a bloody, squeaky mash of broken teeth and aluminum. And still the bike squeaked.
~Remembered that I had a mechanic's stethoscope in my motorcycle tools. Asked my neighbor George to use it at several points on my bicycle while I reproduced the maddening squeak on my rollers. He isolated it to my rear hub. I tightened the quick release and the g0dd@mn bike at last stopped squeaking.
Liked 2,631 Times
Good story, [MENTION=100027]calamarichris[/MENTION]. We should learn from that.
Another hard-to-find creak for me turned out to be a saddle. I dropped plenty of oil where the rails met the plastic shell, but I never got the creak out. My wife happens to like the saddle, and the creak doesn't bother her, so problem solved.
