Is a "tacoed wheel" a wheel that is folded in two....
Schwinn Discovery
like an Ortega taco shell?
What are the major causes of tacoed wheels?
1. hitting curbs fast?
2. running into telephone poles?
3. car accidents?
4. being overweight?
5. other?
I prefer my wheels to be straight and round like tostada shells.
When I get cold in the winter, I like to burrito up (wrap up like a mummy) under the covers while embracing an attractive partner.
Just make sure you don't get "sandwiched" between two large vehicles while riding in the streets.
3. car accidents?
5. other?
Aka Pringled.
crisps in a can.. If you don't have Tacos, there..
How is it done?
Un attended to, not all spokes equally balanced.. tension... poorly built wheel?
dropping a wheel in the trolley track slot..
How is it done?
Mad bike riding scientist
Liked 4,338 Times
3. car accidents?
5. other?
3. car accidents?
5. other?
The causes can be many. Least likely (and, frankly, a bit insulting) is being overweight. You can easily “taco” a wheel by letting it fall over in a wheel trapping bicycle rack. I always park my bike in that kind of rack with the rear wheel only because a bike can fall over and the weight of the bike can bend the rim. Impacts can cause them but it is dependent on the angle of the impact. A straight up impact probably isn’t going to taco a wheel. A side glance could.
And if you are running into telephone poles, you have other problems you neeed to address.
Having loose spokes can cause a rim to taco, especially on hard corners. A wheel build to asymmetrical spokes...spoke heads pointing in the same direction instead of being a mirror image...is more prone to bending.
Stuart Black
Stuart Black
Schwinn Discovery
Liked 83 Times
In August I was riding at night and hit a boulder that must have been chucked out into the road, or fallen off a truck. It sent me into the curb really hard. I went down, and as I hit I remember thinking how hard the impact was; it was harder than anything I had ever felt before. I had an abrasion on my chest where I landed on the stem. Both elbows and knees were badly gashed up. My left elbow had a bone chip.
The front wheel was bent such that at 0 deg and 180 deg it would rub the left brake caliper. At 90 and 270 it would rub the right brake caliper. The tire was torn open. My left shifter's little inner shift tab had a half inch snapped off it. I released the brake caliper (as if to repair a flat) and rode home on that wobbly wheel with a flat (irreparable) tire, seven miles. Well, at first I started walking but then did the math and realized I'd take more than two hours to walk home, and would wear out the shoes along the way. It got a little skittish around corners, but I made it. My gloves had blood in them from running down my elbows.
That's the closest I've come to "tacoing" a wheel. None of the spokes broke, which was pretty surprising. And in the end it was a good excuse to upgrade to a nicer wheel set. I was riding within a week, though it took a couple weeks before I could get away with not wearing gauze under my clothes.
So yes to #1 : hitting a curb at about 17 mph was enough to do it, though I suspect that it was partially the force of me landing on it, too.
I really doubt that being overweight could do it unless there was some other event to spark the tinder. Mostly it probably takes some good side force. At any rate, it's not something to worry about while riding down the road under normal conditions.
SE Wis
Liked 3,428 Times
Learned that lesson years ago and had to ride 20 miles back to the car with a brake unhooked
Disco Infiltrator
Liked 2,116 Times
It means you dropped the chalupa
Non omnino gravis
Insane Bicycle Mechanic
I have had wheels taco when brand new. It happens if you overtension the spokes.
I blame mechanical incompetence. 'Scuse me while I go slap myself silly.
Jeff Wills
Jeff Wills
Liked 4,078 Times
A spoked bicycle wheel has two stable configurations - the nice round true shape we all love and that wavy form in the pictures above, much like a potato chip; "tacoed". Taco'd wheels can often be saved by backing off the spoke tension until the rim pops back to the original shape, then re-tightened and trued like a new wheel build. If this if the case, the second try will be as good as if the tacoing never happened.
Ben
Ben
I was in a bike/car wreck that tacoed both wheels - handbuilt wheels from excel sports with power tap hubs. Got them rebuilt.
My wife and I had just come to a stop, I was off my bike, and she lost her balance as she brought her leg over her bike to dismount. Her bike fell against mine and my rear wheel tacoed. Boom. That quick and easy.
With advice from members of this forum, I was able to repair it.
I don't think the spokes were too tight. It's an early 80's Motobecane Grand Record that sat in a basement for years, it didn't have enough miles on it to ever have been repaired. But, who knows?
Here's a link to the thread about it: https://www.bikeforums.net/bicycle-m...epairable.html
I've ridden it maybe 200 miles since then. (Including a crash that took out my left rotator cuff.) Maybe I've been lucky; it's been fine. From what I've read here, it could've folded up again.
Super Moderator
Liked 942 Times
3. car accidents?
5. other?
3. car accidents?
5. other?
Liked 4,338 Times
Yes but “warped like an LP that sat in the hot sun all day long” or “shaped like the brim of a cowboy hat” or ”shaped like a formed potato chip like a Pringles” just doesn’t have the punch of “tacoed”.
Stuart Black
Stuart Black
Liked 4,338 Times
Ben
Ben
Stuart Black
Stuart Black
*How many food-metaphoric buzzwords can one squeeze into a post?
Liked 4,338 Times
"Pringled" seemed to be the buzzword of choice BITD, in the heyday of the eponymous snack. I suppose "tacoed" is preferred over the march of time. I had a front wheel tacoed when I was T-boned* by a Crown Vic in 2000. I managed to get it at least back "in the ball park", but it sat in the basement for want of an assignment, until this year. Now it, and its companion from the same bike, are the "spare set", shod with the studded tires, for my wife's winter commuter. So far so good.
Stuart Black
Stuart Black
Advocatus Diaboli
Liked 1,562 Times
The way it sounds like you ride, you really really should consider going tubeless.
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,654 Times
A bus tacoed a wheel of mine ... from the inside.
Inside the bus. One of those folding buses. And I was sitting in the folding part. The wheel i was holding got stuck during a turn.
Bizarre occurrence, and shocking at the time. But not a big deal. Bought another Sun rim and built it back up. Fortunately, it wasn't a vintage, irreplaceable rim.
bobotech
Bicycle Mechanics
7
03-21-12 12:47 PM
luderart
Bicycle Mechanics
27
10-16-10 03:11 AM
