Re building a wheel, but my spokes are too long.
I am trying to teach myself wheel building and I was practicing on an old wheel I have. I took the wheel apart and put it back together but the spokes were too long, I tried again following the directions on Sheldon brown carefully but the spokes are still too long. The front wheel of the bike is a 36 spoke 3 cross wheel. The rear wheel is 36 spokes and I think it is 3 cross but I may be wrong. When I tried to lace it 4 cross the spokes were much too short. Any ideas?
the wheel is a weinmann 519 36 hole 26in, the bike is a 1999 specialized hard rock FS
Really Old Senior Member
Did you get the spokes mixed up?
Front spokes are the same length.
Rear DS will be 1-2 mm shorter than the NDS spoke.
Front will be about 2mm longer than rear DS.
Liked 3,992 Times
Liked 644 Times
I'm betting that only half of the spokes are too long.
It's fairly common to get the cross pattern right on both sides but to have the two sides off by one spoke hole. When that happens you'll get a pattern going around the rim of 2 long spokes followed by 2 short spokes. Don't ask me how I know, but I've seen it happen more than just once. If that's the case, you'll have to unlace and redo at lease one of the flanges.
"Good judgement comes from experience and experience comes from bad judgement." Mark Twain. one of my favorite Missourians.
I made sure to keep the DS and non DS separate, thought that this was the problem the sorts time so the second time I am sure they were separate
Mad bike riding scientist
Liked 4,336 Times
Stuart Black
Stuart Black
Liked 3,992 Times
I have done the second flange spokes off by 1 hole thing more times then I should admit. I would have suggested this earlier but no mention of their being pairs of long and short spokes was made, or how long or short the spokes seemed to be. In hind sight and with more data this, one spoke hole off on second flange, seems to be the likely issue. Andy
AndrewRStewart
AndrewRStewart
I tried moving all the spokes on the drive side to the right one hole on the hub then put them in the same holes on the rim. I still see the two long and two short spokes.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Liked 7 Times
Nigel
Liked 7 Times
Remove all but the first 9 spokes (following Sheldon's process); redo the next 9 making sure that the go into the correct holes. with just the 18 spokes, you can twist the hub relative to the rim to make the hub be centered, and verify that all the spokes are in the correct holes in the rim. Add the 1st of the 3rd nine, and check everything for lining up, then continue if good, back up and fix if not.
Liked 3,992 Times
The way I deal with this is to take apart one side, one flange's spokes. I place the wheel with the remaining laced side down, flat on my lap and work bench edge. I place the valve hole at my lap. Looking at the spoke to the right, counter clockwise, to the hole I note which way is radiates around the flange. (It "should" radiate counter clockwise as to keep the valve hole access as open as possible). I then look at the rim's next valve hole, second from the valve hole (the first has that initial spoke you looked at), and running parallel to that first spoke track which hole on the second (yet to have spokes at this point) flange matches up. remember a couple of things, the rim has, say, 36 holes. The hub also has 36 holes but distributed between two flanges. The two flanges have their holes off set from each other so when you look across the two flanges you see a near flange hole then a far flange hole then a near flange's hole and again the far flange's hole... So the hole at the rim that is one to the counter clockwise direction from the first spoke's will also be one, off set on the near flange, hole counter clockwise to that first spoke's hole on the far flange. I call this first spoke on the second flange the reference spoke. getting this spoke in the correct hub and rim holes sets up the rest of that flange's spokes. That far flange's first spoke and this near flange's first/reference spoke will run nearly parallel with each other. Sometimes I'll drop the reference spoke through it's hub hole and have it parallel to the hub barrel/axle and see which two holes it lines up with on the already laced far flange just to make sure of my understanding on the off setness of flange holes.
Once this reference spoke is determined then one can decide on whether the second flange's spokes will mirror the far flanges pattern WRT spoke heads in or out. But that's a different topic Andy
AndrewRStewart
AndrewRStewart
Bikes: Lynskey Backroad; Lynkey Cooper CX
Liked 18 Times
Just built my first wheel
There is also a You Tube video showing him lacing a wheel.
Well worth the money for me.
Good of luck on your wheel building journey.
On Holiday
Bikes: A bunch of old steel bikes
Liked 15 Times
I suspect that you may be off on the count or you may have made a mistake in the second round of spokes and placed that spoke out of place. Take the wheel apart and start over. I would suggest you follow the link in this article to Eric Hjertberg's old Bicycling magazine article. I've used it to build since it was publish and the instructions are clearer than Sheldon Browns...similar but clearer. You can ignore the first article about component selection as it is dated. But the other 3 articles are very good and have clear instructions.
Good luck
