New to ebike building. Need Help!
Hey guys, Im new to this forum and ebike building...
Im thinking about building an ebike to commute to my local train station before and after work. Its around 4 miles in total, each day.
For the bike, im thinking of buying this: argosDOTcoDOTuk/product/6007870
For the conversion kit, im thinking of getting this one: ebayDOTcoDOTuk/itm/323199246084
Im not sure what battery to get?
Maybe this one? amazonDOTcoDOTuk/Downtube-Battery-Lithium-SAMSUNG-charger/dp/B01JPM58PU
It uses Samsung cells, so no chinese batteries.
So i guess my questions are, is the battery ok? If not, can you suggest one please.
Also, is the voltage ok too?
Also, in terms of the wiring, will the battery connect to the hub motor with no issues?
Im not allowed to post URLs, so replace DOT with an actual dot.
Thanks
Thanks
Liked 283 Times
Here you go.
https://www.ebay.co.uk/itm/323199246084
https://www.amazon.co.uk/Downtube-Ba.../dp/B01JPM58PU
Your motor is a direct drive (gearless) unit. Good for speed,.Quiet. Simpler. Less good for hills, Needs a bigger battery to do well. I personally like geared motors. Less drag for pedaling, if you like to do that. The battery is a better fit for a lower power motor.
Here is where UK experts hang out.
https://www.pedelecs.co.uk/forum/for...discussion.42/
Bikes: A little of everything
Forgive me for the question, But why an e-bike for a 2 mile trip? You're looking at building a $600, 40lb boat anchor of a bike that you need to recharge. I'd suggest just going to a bicycle shop, spend that much money on a lightweight, higher quality bike (that also takes fit/size and geometry into account instead of something one-size-fits-all).
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Liked 7 Times
Even my very out of shape self chooses a non-ebike for 2 miles to the light rail, light rail ride and 2 miles to work. For the least amount of commute time (10 miles each way); my ebike is faster than the regular bike train combo or driving. In the afternoon the light rail + non ebike takes less time than driving.
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Liked 66 Times
Guys, you forget that a self-built e-bike is its own game. If that is the game he wants to play, then great!
It beats playing video games and may keep the OP from driving that distance.
Back to the point, I would not recommend a direct drive hub for most applications. Geared hubs are both smaller and weigh less.
Yes, its the OPs prerogative; it just seems lile a lot of expense for negligible benefit and it comes with extra issues. The only way this project makes sense us if the OP can't physically pedal 2 miles at a time. And if they're in that condition, I hope they don't have to carry this bike up any stairs.
Just to answer a question: I don't know if your particular battery and motor will connect directly together, but even if they don't, there should(?) just be two wires, you can cut, strip and connect them together yourself. I had to do it to the parts that I bought, but I do have a very different setup.
Bikes: K2 (Marzocchi/Fox), Trek 6000 (red) MARS Elite up front, Specialized Hardrock Sport -> eBike (R7 Elite up front), lastly TREK 820 loaner. Recently sold Peugeot du Monde Record and 1956 Schwinn (owned since new).
Maybe he has headwinds to contend with ... Maybe he needs to show up w/o sweat stains ...
