Shimano ST 5700 STI brifters compatible with 9 or 11 speed derailleurs?
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Shimano 5700 is the last ten speed 105 drivetrain. Is it backwards of forward compatible? I know it must be used with a Shimano or Sram 10-speed cassette. What derailleurs can be mixed in?
Bikes: yes
Quoted: 1281 Post(s)
Liked 644 Times
9-speed shimano non-dyna sis MTB derailleurs. E.g., deore. (I ran this setup for a while so I could run an 11-36 cassette. Shifting was OK -- not great, just OK. Also the 11-36 was overkill. Also, I hated the 5700 shifters because they never shifted right even without mixing components.)
Ultegra 10-speed maybe? I think Lenard Zinn has a chart somewhere.
but NOT Tiagra 10-speed, different cable pull.
Quoted: 910 Post(s)
Liked 288 Times
aka: Dr. Cannondale
Quoted: 2163 Post(s)
Liked 3,479 Times
Likes For rccardr:
sorry to resurrect this thread. I’m looking at this too. Are we saying any 10s STI (except Tiagra 4700) will work with rear 9 speed deore XT? Or Even 10s deore for that matter? Same actuation? That’s great if so.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
You can use:
Shimano 8, 9 and 10 speed road components.
Shimano 8 and 9 speed mountain components.
Shimano changed the pull ratio for 10-speed mountain shifting, but waited until 11-speed to change the pull ratio for road shifting.
Need to check the specs of the 9 speed MTB RD that you are considering, many of the RD from the 9 speed era have lower published max low sprocket limits. Low sprockets were not as big back then, not needed since 3x was common. Not sure how much you can exceed the Shimano specs. Also, the specs for the MTB RD may have been based on the longer RD hanger of a MTB frame.
Sock Puppet
Liked 863 Times
The ST-5700 takes a RD with the 1.7 / 1 actuation ratio in the chart that was posted on your other thread. Post above, #6 is correct.
He didn't give a max sprocket desired or what type of frame it was going on.
hubcyclist
Bicycle Mechanics
13
07-30-18 12:05 PM
Rick@OCRR
Bicycle Mechanics
15
10-14-11 01:35 PM
