Miyata 1000 questions
I came by a 1981 Miyata 1000 in my size (!). Kind of scuffy on the outside but pristine on the inside. I’m thinking that some woman received the bike from her man in hopes that she’d enthusiastically join him in serious touring. From the many chips on the chainstay, my story is that she was not initially skilled in handling the shifting and had a lot of chain-chainstay contact. My story continues with her telling her man where he could put that bike. It’s since been subject to banging around storage areas, judging from the many chips on the royal blue paint. (I intend to celebrate the beausage with some light steel wool application and then clear coat over the bare metal bits.). Now for the questions:
I want to switch the crankset from the half-step plus granny SR Apex original to a Sugino AT that I have in my parts bin. Sheldon Brown’s comparability chart indicates that the original bottom bracket spindle should work @127.5mm. Does anyone have experience with this? It looks as if it should have plenty of clearance from eyeball measurement.
The original wheels are REALLY heavy! Even after removing what I suspect were the original tires and tubes. What do most people do with wheels on these bikes? Enjoy the sturdiness of the original design? Replace with lighter rims and spokes? I kind of like the robustness of them, but wonder how they affect performance ...
More questions (and pics) to come.
Likes For Honusms:
Liked 3,703 Times
Nice bike. I'd want to find a paint to touch up the frame with and then wax it.
The BB should work fine but the best way is just trial and error.
There's nothing wrong with half step gearing (and if you have only 5 or 6 on the back, there is something to be said for half step gearing) but crossover is easier to figure out. So I think the crank change is a good idea. You can always sell the SR apex.
The wheels are designed for touring. Personally I'd ride the original wheels and just get new tires. It's not as if this is a lightweight bike.
Definitely a nice bike.
Personally I would scrap the original parts and build a new bike up from the frame. If you want to do this on a budget, swap out one part at a time.
The Miyata 1000 was a great bang for buck, but like a lot of (all...) bike companies, Miyata would try to save money here or there by skimping on parts most people wouldn't notice. The frame itself is Tange #2 and functionally it will be equivalent to any top end euro touring frame. Actually, I like them better than most. They had a sporty ride for a touring frame. What I'm trying to say awkwardly is that it's not inappropriate to hang some top shelf parts on that thing. It actually can be a lightweight bike, if the components on it are lightweight.
Anyway, I agree that the best approach for the crank is try and fit. Maybe it will work. If not, buy a new cartridge sealed BB and be happier.
IMO there was a tendency to go way way too heavy on touring wheels. BITD I had the UV version of this bike, I followed the common wisdom of the time and dutifully built up some heavy 27" wheels. Then I decided it was ridiculous. I read in Sloane that people used to tour on sew ups, so I borrowed some training sew up wheels from my race bike. I then went on a 3 week loaded tour, and had zero problems. If you ride with finesse, basic road wheels work just fine. Consider building up new wheels. I suggest something like TB14 36h rims, modern butted spokes, and whatever hubs you like.
If it were mine I'd powder coat, as IME the original paint on these wasn't that good. Just my opinion though. I can understand you wanting to preserve the beausage for sure. I'd put wax on it for some protection.
Thanks for the replies. My concept for this bike is to have a lovely rider that I don’t hesitate to lock up to a bike rack outside a restaurant or the grocery store. I have others that are terrific fun, but are too pretty to risk banging around with other parked bikes. Touch up paint in strategic spots may just be the ticket. (And a good wax job after some rubbing compound.)
It came with Suntour Cyclone derailleurs - GT in the rear, which is a real plus! The Suntour Pro Compe cluster is also nice (not much evidence that it ever was used) although I have a NOS Perfect one that’s a little wider range.
Has anyone had trouble with cantilever brake reach with 700C wheels? I really don’t mind the 27s - am tempted to try the Swift Tire 27X35 with them. The old tires - when I could finally pry them loose - were pretty hefty. Lots of steel in them.
Any further observations and suggestions are welcome!
Master Parts Rearranger
Liked 2,040 Times
Former 1982 Miyata 1000 owner here. 27" to 700C wheel conversion was easy to do. I had Dia Compe 960 cantis--ones that could adjust angle to braking surface as well as toe-in. That's crucial: to be able to "lay out" the canti arms and angle in the pad/post combo. That get's you the 4mm drop. Works well, too. 1000s definitely have a regality to the way they ride, which is a standout feature. Their top tubes, at least in 63.5cm form, are a touch shorter than normal. So the combination of longer stem/bar/lever reach with higher geometric trail (59mm or so), slack head tube angle, and simply being well-made and of good steel, made for great steering. My '90 Cannondale ST has some of those traits, but it's a strong frame that's happier carrying more (and more easily) and thus less supple in that regard (unloaded or very lightly loaded). All that blather to say that you will likely enjoy riding your 1000, even if it's just for short jaunts. They are special!
Liked 477 Times
My Sugino AT crank has a near perfect chainline and decently low Q-Factor with a 127mm BB plus spacers to create the desired asymmetry. So your existing 127.5 should do very nicely.
I had a lovely ride on [MENTION=401497]RiddleOfSteel[/MENTION]’s Miyata 1000 before he sent it on its way. It was/is a lovely bike, more nimble and fun than many tourers, much more sports tourer than loaded touring, but many report that it’s one of the best with a load, too. Congratulations! It will build up well with just about anything,
Señor Member
Liked 1,143 Times
I'm in the process of renewing the 1981 Miyata that I picked up for my wife a couple years back. Some rust had snuck in - to the point where repainting seemed the best solution. In the process, am making it shinier and a bit more functional. Everything worked, but I decided to go with 700c wheels (have the rims. getting the hubs), new brakes and front derailleur. It isn't finished yet, but I am confident it will come together nicely.
I used to own a 210, and from the little bit I rode the 1000, the 1000 rides notably more like a sport bike than the 210 did. Hard to go wrong with something this versatile.
Liked 2,040 Times
Or just really crummy roads or bumps that were unavoidable. It's the reason chain stay protectors exist!
OP: Stealth bike - I get it. Maybe wrap up the right chainstay with cotton tape after doing some touch up to protect the steel. Add a few stickers here and there to cover up the worst bits, and make the bike look cheaper. I'd still go for some nice wheels. As we used to say, wheels and tires are half the bike. The Swift tires are a good idea. Those alone may be enough.
700c isn't a problem as you can see from RofS's post above, should you want to go this route. We were just discussing this in another thread. You will need vintage or vintagey cantis. GC960 adjusted out will work. Dia Compe 988 are still in production, and may work even better since they have some vertical adjustment.
ambulatory senior
Liked 3,681 Times
I have an 81 1000 as well. Its a bigger frame but had similar components and heavy wheels. I built 700c wheels for it with a 126mm hub. I used a different crank as well because i wanted a lower low gear. The frameset is very comfortable. Lots of give and a good all day rider in my exp. I even had it setup for a while with a 3 speed hub. Great frame.
Liked 636 Times
My '81 has the original wheels, and yeah, it feels a little heavy. I swapped wheels back and forth a few times with the Wolbers on my newer ('88) Voyageur, and didn't really notice that much difference. Overall, the bike feels stable and comfy, but not exactly sprightly.
I should try one of my more modern wheel sets on it and see if that makes any difference. [MENTION=474190]Honusms[/MENTION], your frame looks pretty much exactly like a'81 Miata 1000 I sold on eBay a couple years back - same size, same color, same patina. But mine went out as just a frame and brake calipers, so no. And if you're riding a bike that is that small, I'm guessing you weigh a lot less than me and can get by fine with a lighter wheel set if you want. Plenty of choices out there.
Liked 2,040 Times
My '81 has the original wheels, and yeah, it feels a little heavy. I swapped wheels back and forth a few times with the Wolbers on my newer ('88) Voyageur, and didn't really notice that much difference. Oral, the bike feels stable and comfy, but not exactly sprightly.
Since I’m female and about 125#, weight-bearing is not a big issue. I built up some CR-18 rims (27”) with Normandy Luxe hubs for my Moto Grand Record and they are nice and light. I also have a 700C set with campy record hubs from another build that I’ll try with the current canti brakes after I’ve polished and re-installed them. Maybe I’ll go one of those ways eventually, but for now I think I’ll stick with the originals to see how they feel.
The original tires were a bear to remove - sort of welded to the rims. Also bonded with the tubes in some places. Can’t wait to try the Swift Tires/Panaracer 35mms.
Thanks for the derailleur hanger alighnment reminder!
ambulatory senior
Liked 3,681 Times
Extraordinary Magnitude
Liked 1,744 Times
Hi and welcome to the Miyata 1000 Owners' Club! Your membership card and the passcode to the secret clubhouse are in the mail and once you're in, we'll show you the secret handshake.
Granted- my Miyata 1000LT is a 1990 model- a lot of the same things apply- this was a top tier touring bike- before mountain bikes ruled- "touring" was the buzz word. You'll still see all kinds of bikes referred to as "touring bikes." As such, a lot of companies made their top tier touring bikes the flagship representative of the company.
Keep in mind, the concept of the flagship touring bike up until sometime after 1985 was a bike with all-day, long distance, stable, load bearing geometry, Class A or B components, and tubing that was strong but lightweight- and prestigious enough to brag about. So what constituted a world class touring bike back then would be more like a light tourer now with the expedition type bikes these days. I think it's neat to see the evolution of the touring bike from "a bike with a rack" in the mid 70s to a specialized machine by the mid 80s into a more burly and a little less glamorous bike to the beastly expedition machines of today. The 80s bikes were sturdy for their time, but the prestige of quality tubing and light weight took precedence over stiffness. The reputation of the Miyata 1000 has really benefitted from Sheldon Brown's recommendation, and because of that the bikes go for a premium, regardless of the year.
What I love about old touring bikes is that smooth, stable ride. I liken it to a 1972 Cadillac Eldorado. The long chainstays, the somewhat burly, yet still flexible wheelbase make for a great ride. It's not quick, not exactly "responsive," but it is smooth. The components have a certain elegance of being both pretty and badass at the same time. It's a cruiser without being 60 pounds. My 1990 Miyata 1000LT is much more stiff than any of my other tourers- but it's a much later bike and it still has that smooth long wheelbase ride. To me, a flagship level touring bike is totally worthy of hanging the best quality, prettiest and appropriate parts on it. With your bike, 81 is a little early for a lot of ATB/MTB parts- but you get to make the rules for what you put on there. I used to be much more of a "period correct" person (actually more "period-ish"- old parts that someone may have upgraded to at a later time) but after changing one bike to 10 speed... it's "game on." As long as it fits my own particular... ...idiom- and it works great and is pretty- it's a go, regardless of the year it was made. With my Miyata, it was mostly built with Deore/Deore DX parts (2nd from top of the line), so I built it up with some stock parts and some upgraded period-ish XT and XTR stuff.
Again, you get to make the rules for your build... If you're going for a period-ish, lightweight, yet "business" build- That Sugino AT is probably the all time best triple crank... then something like Cyclone GT/Cyclone MII derailleurs, Suntour Barcons, DiaCompe 981 cantis, GranCompe brake levers...
Good luck and looking forward to more pix as you go!!
Commence to jigglin’ huh?!?!
Progress
First pass at making it rideable:
- Frame cleaned, buffed and waxed
- Hubs, bottom bracket, pedals and headset serviced. (Broke 2 reflectors on pedals, may or may not replace).
- Sugino AT crankset installed with original bottom bracket spindle. Perfect chainline!!!!!!!
- Original freewheel retained for now as it has no wear. Aluminum dork disc stays.
- Original canti brakes retained. Still need to install new Kool-stops, although stopping is robust (but noisy) with the 38 year old pads.
- Suntour Cyclone GT rear derailleur and Cyclone front derailleur retained
- Original Suntour ratchet shifters retained. These are my favorite downtube shifters. I have a pair of barcons that I could use, but maybe later.
- Cable housings replaced with Velo Orange metallic braid ones. Very stiff but so pretty!
- Original Dia Compe brake levers retained.
- Brooks leather bar tape installed.
- Puffy Trek saddle replace with Brooks Professional S
- SwiftTire Sand Canyon 35 tires installed on original rims, which are not really heavy once the old tires were scraped off.
It’s everything The Golden Boy claims. A smoooooth rider. Not agile in the corners, but so stable. Not a heavyweight by any means, especially with its new tires. Next up: fenders and racks!
Phyllo-buster
Liked 2,069 Times
Not sure what was stock but nice choices on the build, especially the Mighty power shifters. They're dependable and bombproof. Hoods for the brake levers, your racks and maybe mudguards would round it out.
Liked 2,040 Times
Lovely 1000! Glad the ride quality matches what the rest of us have experienced as it means you get to experience it too!
Liked 1,744 Times
- Aluminum dork disc stays.
Good call on everything- I think the slotted Suntour dork disk looks classy.
Hoods should be easily available- either the vintage DC ones with the fun cutout for turkey lever, or some of the new DC 204, Cane Creek or Rustines...
I’ve had good luck with the Kool Stop Cross Pads- the shoes look nice, and the pads are replaceable. I don’t think you’ll have length problems with the 960s.
Liked 523 Times
Hey now!!!
Hey now, I know that bike!
You've gotta remember that that is an '81.. BEFORE most of the mid-'80's touring-bike improvements! As an early '80s 'period' piece, it IS the 'creme-de-la-creme', but even a few years later, a 'mid-grade' Miyata 610/Univega Gran Tourismo was specced out better! Frame/fork? - Frames being double-/triple-butted-/STB, they are the same other than fork material, just a few more braze-ons. That '81's frame size/geometry and construction is never going to be 'sprightly!' It was never intended to be!!! It is a TOURING bike, not a canyon-carver!!!!
Liked 2,040 Times
All that and no mention of the rear bag!? Don't leave us, or at least me, in suspense. Do tell!
