Problems fitting Tubus Tara Lowrider
Just bought this rack and I am having trouble fitting it to my Marinoni Tourismo Extreme. You can see by the attached photo that the the tubing interferes with the q.r. skewer and stops the mounting hole from lining up with the eyelet on the fork. Using a spacer to push the rack outside of the fork won't work because the rack is not wide enough. Has anyone come across this and have a solution? If this doesn't work, any other lowrider front rack suggestions?
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/1080x1920/img_20190325_205542_bb1d172e803265452cb03a0f83cf6ed12d947e80.jpg)
Mad bike riding scientist
Quoted: 6296 Post(s)
Liked 4,333 Times
Stuart Black
Stuart Black
Investigating further, the underlying problem is that the tubing on my Marinoni fork is large diameter. Compared to my 80s era 520, it's a good 5-7mm larger. Because of that, I can't get the Tubus rack to mount on top of the QR skewer like in Rick's photo. The only reason I can think of for the larger tubing is to have more welding surface for the disc brake caliper mounts.
Photo on the left is my Trek 520, on the right is the modern Marinoni. I guess I'll have to find spacers for the Tubus rack. Or, I'm thinking seriously about refurbishing my Trek and touring with it until it crumbles beneath me.
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1770/img_20190326_065440_8fe50bb8ce633c9067db8e372831798c0ede5d1e.jpg)
use of spacers will not be a problem, I've done it for decades.
Using common sense, ie bolt long enough to go all the way into the threaded part, a good solid spacer, proper tightness and a little blue loctite and you'll be good to go.
Its easy to source those solid aluminum spacers, they have diff hole sizes, so get the right one for your bolts, and then you can cut them to the right length using a hack saw.
The advantage with one spacer is less parts to lose if you have to take off the rack, and a bit easier installation.
On one of my bikes, I did have to mount my Tara using the "wrong" bottom mount on the rack (designed for fender mount I guess), but even though in theory it isnt as strong as the other holes, Ive toured extensively on that bike with a heavy ish front load on very bumpy roads in other countries and all has been fine over 4 1/2 months touring time.
if you'd like, I can take a photo of my bike that I had to do some workarounds with the Tara, to give you some ideas.
Let me know
no matter what, the Tara is a great rack, and really nice that it more or less folds up for when putting your bike in a cardboard box for air travel.
Let me know
Let me know
Let me know
![](https://www.mcmaster.com/mva/library/20161114/93655a460_male-fem%20thrded%20hex%20standoffl.gif)
quickly, regular old aluminum spacers are not threaded inside, and so you use the length of bolt that will work for what you are doing. Just slide bolt through spacer. I've seen that some have diff width holes, so best to get one that fits closely to a regular width rack bolt for standard threaded frame eyelets.
Havent ever had any issues with using them.
handy thing with using your own bolt is if you need to add on a fender stay or an extra washer or whatever, it works, but I guess these would be no different. You just want to make sure the end that goes into the frame threaded hole goes all the way in, to get the max strength out of the bolt attachement point.
@ LBS nearby there is a bin pf aluminum spacers collected from past mudguard installations ..
and stacking up plated brass Presta valve Ring nuts is another free/cheap source of spacers ..
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/800x665/tara_troll_lowrez_crop_1_2d252c2fedc7b642b1eb499a941a81db40a4e51d.jpg)
here is the Tara on my Troll, not the same specific layout as your Marinoni, but shows a spacer, also shows how I ending up using the mounting hole on the tara made for a fender mount, so technically not as strong as the beefier other part on the other side.
In the photo you also see how, thanks to a smart mechanic at a bike store I go to regularly, he suggested a piece of metal mounted on the rack bolt hole area, and reaching back a bit so the fender strut could attach to it--all because the disc caliper is in the way. Again, not the absolute best solution for strengthness, but in the end, it was the best solution because it worked, and has worked like this for three trips, including about 4500kms in Mexico etc.
which reminds me, I really have to get a spare piece of metal like that, with two holes in it, in case I lost one or it got all bent and broken in an accident or something. Been meaning to for years now.
so for you, spacers can be used, so try to look at your layout without preconceptions, and or like me, get some ideas from some good smart mechanics.
Ive used spacers like this on other bikes for front racks in the past, to move the rack out from rubbing on the fork legs and scratching the paint.
it doesnt look like you have any other choice than to use a spacer.
Again, once a bolt is in properly and solid, if it stays tight, it will be fine. Just dont let it get loose, but then without spacers this can be an issue also, so use blue loctite or thick grease, to stop vibrations loosening them over time. Check regularly--I do this when I do my once weekly bike go over on a rest day. Dont overtighen of course, but just check for slight loosening.
Quoted: 650 Post(s)
Liked 420 Times
A long bolt through an aluminum tube with plenty of slop and the smallest contact area possible. I know the disco rack spacers and the standoffs shown are a much stouter connection. They are square with the world and due to there larger diameter have a larger contact area.
I have aluminum spacers that the hole is rather tight, and I have to hand screw the bolt through, so no slop, and they match up well to the eyelet area well also.
I have never seen these neat threaded ones before, so regular aluminum ones are all I have seen and used, so they are used without problems by lots of people and for decades.
it is also handy to be able to cut a long one to the exact length you need, which with this Marinoni fellow, could be an advantage
I dont know if the internal threaded ones are easily cut, re the threading inside getting gummed up and not being to screw a bolt in afterwards.
just some more thoughts
hhk--again, another good reason to have a good friendly relationship with a good bike shop, they will not only have ideas, but nearly always a drawer full of little spacers and whatnot to improvise stuff, like those pieces of flat metal with a hole in each end that I use for my front fender stays--I really have that mechanic to thank for that--I would not have figured that out on my own.
Quoted: 3523 Post(s)
Liked 1,500 Times
My worry with using spacers is that you're applying load to a long lever (the screw), stressing the eyelets and screw itself. I think the stand-offs are better because the flange sits on the surface of the fork and spreads the load over that area and not just on the threads of the eyelet.
While I agree that you are best off without spacers or standoffs, since the front rack usually takes a much smaller load than the rear, I would expect that some spacers or a short standoff could be used. And on a Tara there is no platform, so you are talking about the weight of two panniers and nothing else. (If there was a platform, someone would likely add a 12 pack to the platform on occasion too.) The rear rack where you might have more than twice the weight is where spacers could be much worse when you are using the same diameter of bolt as the front rack
hhk, if you can source those threaded thingees, great. As long as it works and does a good job, and you dont go Jumbo heavy on your front panniers, it will all work out.
Quoted: 460 Post(s)
Liked 112 Times
I looked at the standoffs at McMaster Carr and am impressed. The fiddling around with spacers and extra washers would be eliminated.
ryansu
Classic & Vintage
11
09-09-18 02:58 PM
Road Fan
7
04-06-11 08:26 AM
