How interchangeable are vintage SunTour derailleur cages?
Quoted: 824 Post(s)
Liked 1,434 Times
I'm mulling over a Frankenstein approach to something. Has anyone ever grafted a V-GT Luxe cage onto a SunTour Cyclone to create a Cyclone GT? I have most of the part available to do this, and can purchase the rest of this project much cheaper than buying a whole Cyclone GT. Is this even possible, or have I been sniffing the Tubasti again?
Old fart
Quoted: 3617 Post(s)
Liked 3,453 Times
I haven't tried it, but it might be possible. The cage mounting nuts are different:
And you'll probably need the special two-prong SunTour cage tool to loosen the nut on the Cyclone cage.
The bolts look to be the same diameter on both, so there's a good chance they're the same thread.
Quoted: 824 Post(s)
Liked 1,434 Times
Thank you! Lots to ponder here, and your information helps!
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4707 Post(s)
Liked 5,875 Times
I haven't tried the transplant, but I did make a tool to remove the nut with a length of bar stock, a grinder, and a file.
Extraordinary Magnitude
Quoted: 2610 Post(s)
Liked 1,718 Times
I had a wild hair to try to transplant a couple of cages... a triple pulley or triple pivot MII Cyclone... In the end, there was too many differences in the way the cages mounted, and the different springs involved... Some people have done some of this stuff- but to me- it's just not worth the energy.
Here's my thread about it:
https://www.bikeforums.net/classic-v...y-project.html
Someone else did something like it- and figured out there's 2 different 3 pulley cages.
If you want to do it- I wish you luck. But I'd just look for a Cyclone GT.
Commence to jigglin’ huh?!?!
Bikes: Too many, but sometimes not enough.
Quoted: 225 Post(s)
Liked 18 Times
I don't think you will have any luck with the vx-luxe to cyclone gt change over. The Cyclone gt cage is shared with the vx gt, as well as the suntour BL gt. Where you get into trouble is the main axle it attaches to is specific to the GT - it acts as the shaft for the upper pulley too. The regular cyclone s or cyclone vt have shorter axles that just attach to the cage. You can swap cage+axle between any of the first gen cyclones, but just having the cage off a Vx gt or BL gt won't help, unless you have a donor axle from a Cyclone GT.
Quoted: 824 Post(s)
Liked 1,434 Times
Thank you all for persuading me not to attempt this. There are so many other questionable ideas I can pursue instead! Thanks again!
Quoted: 787 Post(s)
Liked 525 Times
Funny- I just last week swapped in a Vx-S cage onto a 1st gen Cyclone short cage, to make a medium cage Cyclone. It took some finessing, but works fine. I wanted a little more chain capacity without going full-bore touring/GT.
Quoted: 824 Post(s)
Liked 1,434 Times
What's your cog capacity with that arrangement? I'm thinking what I really want is to be able to run up to a 28T with the usual 42/52T up front ...
Phyllo-buster
Quoted: 2300 Post(s)
Liked 2,062 Times
Likes For clubman:
Quoted: 787 Post(s)
Liked 525 Times
It's running a 13-28 and 41/53 at the moment. There appears to be clearance for at least a 30 in the rear, and there's capacity for a smaller small ring up front.
Quoted: 3261 Post(s)
Liked 2,577 Times
I'm going to try it with a Superbe and an XC from the same time frame. It appears to be the same cage as the Superbe GT.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3931 Post(s)
Liked 6,583 Times
Liked 1,718 Times
I couldn't get a Sprint to work on a 28...
Phyllo-buster
Liked 2,062 Times
Liked 1,718 Times
I made a Superbe Pro explode across the garage shortly after this pic was taken:
SuperbePro400 by Dave The Golden Boy, on Flickr
Quoted: 225 Post(s)
Liked 18 Times
Maybe, but a lot depends on the dropout geometry and freewheel width / spacing. I've gotten the regular "S" Cyclones to work with a 28t freewheel, but just barely. Another bike maxed out at 26t. If your hanger is deeper, or the large freewheel cog is further inboard that will help. Most of the max cog improvement in the GT takes place due to the upper pulley being moved to the cage pivot (~ 1/2" lower than the V or S versions) Of course this comes at the cost of shifting precision and small cog handling .
Quoted: 787 Post(s)
Liked 525 Times
Be aware that there are two versions of the 1st gen Cyclone. One with a shorter drop in the mounting arm than the other.
Short drop:
Long drop:
I have seen examples of short-cage and GT in both versions. Not sure how the cog or chain capacity are affected. I assume it's similar to the Campy Nuovo vs Super record cage, where the pulleys are the same distance apart, but the SR guide pulley sits lower.
Short drop:
Long drop:
Phyllo-buster
Liked 2,062 Times
