Caring for an all-chrome C&V frame... what's involved?
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Let's say one comes across an all-chrome vintage frame, with minimal pitting/rust. What's the best (or reasonable) way to preserve and upkeep the finish? How about if moderate rust is present?
"elbow grease"
Best? IDK, (that's an opinion) have you looked into stuff classic car & M/C owners use on their chrome
say, meguiars chrome cleaner ? https://www.meguiars.com/#/
[ don't own a car ]
[ don't own a car ]
I work on C&V cars and I like this Quick-Glo. It does well with removing rust and then seals it with a wax to keep it from returning.....and the shine is very nice. I have no connection to the company. Just passing on a suggestion.
Quoted: 1163 Post(s)
Liked 1,845 Times
If it's in good shape I'd just wipe it down with motor oil.
Quoted: 1393 Post(s)
Liked 1,799 Times
In years gone bye, manufacturers used to clear coat the chrome, as seen on this mid seventies Sekine SHsomethingorother...
Short of that, I use automotive wax frequently. This is not a final protection and must be repeated over and over over the years.
Quoted: 915 Post(s)
Liked 516 Times
@horatio
I have a chrome frame that's 55 years old and no rust, however the original decals are yellowed and very fragile. No way I'd use anything heavy handed to "polish" it. But it's a rider, not a museum piece. I just want to preserve it for the next guy. It just gets a wipe down with Boeshield T9 when it needs it. Leaves a waxy coating but not a mirror.
If you have rust, that's where all the usual techniques come into play. Even bare steel can be polished to a high shine then waxed.
Straight car wax (not cleaner wax or a combined wax/polish) is completely non-abrasive and will leave a dry, protective coat on the frame. This would need to be applied every 3-6 months. Remove the rust first using navel jelly, oxalic acid, etc.
feros ferio
Quoted: 1407 Post(s)
Liked 1,365 Times
In my climate with its salt air, the most important thing for chrome is a good wax or other protective coating.
I had a chrome frame for 30 years. Left it out in a damp garage for several years too. All I ever did was spray WD-40 on it and wiped it down. Some spray wax too.
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
Great tips, guys. Don’t own one yet, but I’m looking.
Bikes: '92 MX Leader, 84 Colnago Mexico, 85 Recherche, 86 Panasonic ATB Pro, 88 Roberts, 80 moser... ect
Quoted: 68 Post(s)
Liked 136 Times
Barkeepers friend. The active ingredient is oxyalic acid. For the most part the same as using an OA bath which I've done with great results. Home depot, lowes, ect carry a powder form of wood bleach for decks. Again oxyalic acid diluted with water in a container large enough to hold whatever your taking the rust off of. I let the stuff I did sit for about 8-12 hours. There is quite a lot of info at the bmxmuseum regarding rust removal. Unless the rust is deep, and or structural it works extremely well.
https://youtu.be/v7TnNEBy3tI
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
For tough spots, use it with some fine bronze wool. It really takes off the rust and won't scratch. Much more manageable than aluminum foil.
I have had good results with Blue Magic also...
