Do you wax the frame before or after assembly?
I've always put the bike together, got the cables where I wanted them, then waxed the bike. The plan was to do the same on the white PX10 project I'm finishing. But after putting the front brake on the fork and getting grease marks all over the fork legs, and spending 15 minutes cleaning and polishing the grease off, I'm rethinking the process before I move on to final assembly.
If you were to wax the frame first, what areas would you make sure to keep wax free? Would top tube cable clamps have issues clamping firm over a coat of wax?
I use Johnson's in the yellow can, if that matters.
Old fart
Quoted: 3620 Post(s)
Liked 3,460 Times
It's much easier to thoroughly clean and polish a bare frame than one that has components installed.
Novist senior member
How do you get grease marks installing a break? What grease do you use to install brakes
Quoted: 796 Post(s)
Liked 523 Times
I usually strip the bike down to the frame as it is much easier to clean everything that way and to wax the frame and fork, I tend wipe it down with armor all wipes first and then use a Meguiars 3 step; cleaner, polish, Carnauba wax treatment on frames I really like and perhaps just turtle wax if I am in a hurry. Waxing a frame does wonders to restoring the paint and protecting it. Even really oxidized paint can come back
before
After
before
After
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3954 Post(s)
Liked 6,642 Times
If the horse won't pull the cart in the first place, there's no reason to put the horse out front.
Wait, what?
Wait, what?
Quoted: 1628 Post(s)
Liked 635 Times
Yes.
Master Parts Rearranger
Quoted: 1558 Post(s)
Liked 2,037 Times
Wax before. It makes logical sense as there is as much access to everything as possible. Additionally, once the "core" of the bike is as best it can be, it's a morale booster ("It's so beautiful! Now I want to build it up!") and mental "resting point" where you know that the innermost work is done and now one can work to hang all the jewelry onto it. Why anyone would wax after everything is installed and in the way makes no sense to me. I don't even really like cleaning a bike that's fully assembled--wheels off at minimum just to get to places (behind the cranks???) that are hard to reach. Too much hassle to wax at completion when it's immensely easier to do so when just a bare frame. And really, any bike or frame that comes into my possession gets a full disassembly and cleaning + waxing + overhaul.
Quoted: 237 Post(s)
Liked 83 Times
After, because I'm not going to strip down a frame just to apply some wax. There's nothing wrong with waxing a frame before building it up, but it's not like wax is a permanent clearcoat that gets applied once and only once.
Thanks for the advice, I'm going to wax the PX10 first this time. It seems that my worries of the wax coat causing assembly issues are unfounded. However, I am going to leave the seattube bare where my Simplex delrin front derailleur clamps on.
I wouldn’t worry about that. Just wax the whole frame. The fd clamp tightened normally provides plenty of force to prevent sliding, at least in my experience.
Are you talking front derailleur clamps in general or are you talking the Simplex delrin? To mitigate future cracking, my plan was to use the least amount of "tightness" necessary to keep the FD from sliding. And IMHO, clamping it over a coat of wax would necessitate a greater amount of tightness than clamping it on bare paint.
Bikes: old ones
Quoted: 26482 Post(s)
Liked 10,449 Times
As you can tell, I'm not a stickler for authenticity. I usually throw away the original bar, and often the stem on those too, after a near death experience one day.
good point. I learned to repack the bearings in the headset and bottom bracket before waxing other wise you get that problem.
Quoted: 796 Post(s)
Liked 523 Times
Process for re installing a Derlin FD on an old French frame:
Early 70s Motobecane Mirage
- Put Derailleur in a drawer
- Wrap downtube where you will mount FD with one layer of cloth tape to act as shim for narrower French Tube
- Install Sun Tour FD.
- Smile as you will never have to replace your cracked Derlin FD.
Man, you guys are wusses
I'm building this to catalog specs so it's getting an excellent condition Simplex Criterium up front. If it cracks in 5 years, I think I can find a spare 10 minutes to replace it.
Polymultiplié
Bikes: Yes, please.
Quoted: 2224 Post(s)
Liked 4,845 Times
Wax the frame? Should I?
Quoted: 1872 Post(s)
Liked 671 Times
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4719 Post(s)
Liked 5,989 Times
I think MTBF on old plastic Simplex Criterium derailleurs is significantly less than 5 years...
Quoted: 796 Post(s)
Liked 523 Times
My experience with re-installing a plastic Simplex front derailleur was that it cracked as I was tightening the bolt, and I was being gentle and whispering encouraging words in French as I did so.
Reuse at your own risk @MB33 and carry a length of bailing wire in your seat bag for when (not if) it cracks and you need to limp home Bon Chance
SE Wis
Quoted: 2756 Post(s)
Liked 3,427 Times
I do both. While stripped and easy, and after, usually before the cables are on.
Uh, once again, you guys are wusses
The key is to start out with an excellent condition barrel that hasn't been discolored from UV damage. And install it with a minimum of clamping force. I still say mine will last 5 years minimum.
And a rubber boot on the pushrod will keep grit out of it to prevent it from ever needing more than a minimum of cable/lever force.
Otherwise, my plan is to acquire a stack of delrin fd's and become an expert at changing them out. I'll keep a spare or two in the seat bag and everything. All you need is the barrel, then you don't even have to mess with the chain.
That way I get to enjoy the whole black on white PX10 aesthetic. Black QR's, black saddle, black seatstay caps, black curly lugs, black derailleurs, etc...
