Hop after roadside flat - that fixes itself!
Hi all,
I have a new (to me) issue that I haven't seen before on my other bikes. My current rim / tire combination (Krylion 2 700x28 / Alex DM18) seems to seat off-center after roadside fixes. The symptom is that the rear tire has a hop, as if the rim was out of true, and inspecting the bead shows one section that is seated a little deeper than the rest. In the past I've fixed this by deflating and reseating the tire at home. Today, I had a flat about 20 miles before the end of the ride, so I had no choice but to ride it out. After about 10 miles, the hop went away. Inspecting the bead confirms that it is seated OK all the way around. Has anyone had this kind of issue, and am I OK without reseating it later on?
Hi all,
As for whether it's safe to ride a tire like this...now that it's seated, it's probably fine. As to whether it was safe to ride it while it wasn't seated, I don't know. I probably wouldn't risk it with a tubeless, but for a tubed tire I don't see how having the bead seat too deep would increase the risk of blowoff. After all, in order for the bead to depart from the rim, it would have to slide upward over the rim wall, but the hook would catch and seat it before that could happen. With tubeless, not having the bead seated properly could cause the tire to burp and deflate which would be more dangerous.
Old fart
Quoted: 3617 Post(s)
Liked 3,449 Times
A little soapy water on the tire bead will allow it to slide into place more readily.
