Rattling Trek Madone SLR 7 Disk
My 4 month old Madone SLR 7 Disk has been making a rattling noise almost from the first day. It only occurs on rough road surfaces and seems to be coming from the left side of the bike, maybe towards the front(ish)? Has anyone experienced this? Were you able to remedy the noise, and if so, how?
Quoted: 20810 Post(s)
Liked 9,456 Times
I don't have a Madone, but I've experienced similar with my Domane, primarily on really jarring hits. I suspect that it's the internally routed hydro hose in the downtube. I haven't checked it out any further because it's not a constant, bothersome rattle, but you might want to pull the access panel under the bottle holder and see if the hose is loose and what you can do to secure it.
Likes For Dean V:
Fax Transport Specialist
Check the cable/wire routing where it enters the bike. There may be a plastic grommet that helps seal the hole in the frame from the elements. Said grommet may have been pushed/pulled into the frame. If you pick up the bike and tilt it forward and back, you may hear the grommet sliding on the cable.
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
"The 2019 Madone SLR is an extremely high maintenance bike," according to Trek-Segafredo lead mechanic at last weekends Tour of California. Owning one myself, I concur!
Yeah, I had to steel myself (carbon myself?) to that idea even before I purchased it. But, dang, it’s fast!!!
I looked under the down-tube plate and find that that is where the battery is mounted (w/ zip ties). If the wiring/hoses are rattling in that area it would have to be closer to the headset end or BB end of the down-tube. I suppose I could jamb some rubber foam or bubble wrap down there and see what happens. I think I'd tie any foam with strong string so I can pull it back out if needs be.
Quoted: 741 Post(s)
Liked 412 Times
Madones are noisy bikes. I have a 9 series and it will make noise on rough pavement. There is not a whole lot that be done. It is a lot of cables squeezed into a small area.
