Inert Lubricant Question
Quoted: 5 Post(s)
Hello. I have this headset cap and it has a rubber gasket seal that needs some type of inert lubricant before snapping the parts together. Would I just use an inert silicone lubricant? My concern is using the wrong lubricant and having some type o corrosive and negative reaction. Thanks!
Quoted: 5 Post(s)
Quoted: 2027 Post(s)
Liked 1,099 Times
Silicone spray or silicone grease should be fine.
Quoted: 4240 Post(s)
Liked 3,978 Times
I haven't done the math but...
I doubt the seal is rubber, more likely a man made material like most all O rings and such are. If you can find out the material it should be easy to look up agreeable lubricant. As example MSC has a info charts here: https://www.mscdirect.com/browse/tn/...navid=12108900
I will say that's it's been my experience that a silicone based protectant works well for real rubber. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1441 Post(s)
Liked 1,095 Times
Ah, I thought you needed an assembly lube. Silicone should work fine. Please note that silicone is very difficult to remove and will cause "fisheyes" when you try to paint over it, so try to keep it away from the paintwork.
Half way there
Quoted: 990 Post(s)
Liked 885 Times
Dow 111 Molycote silicone grease. I bought it specifically for the rubber seals on my espresso machine, but use it for any other time I install an o-ring or similar rubber seal. A little goes a long way.
