Portable oxygen
Bikes: Trek fx 7.2, Giant Defy Advanced 3
Portable oxygen
I get winded. Bad. Poor stamina from being overweight and having smoked 35 years....since quit.
I am am wondering portable O2 systems that I can buy
Professional amateur
Bikes: Does a Big Wheel count ?
Liked 136 Times
Start with Google, do some reading, then maybe call some medical supply places. Tell them what your situation is, and ask them about options. They should have the best info of various products and options.
I'm thinking a cycling forum isn't exactly going to be the motherload for info on portable o2 systems and distributors.
There are a few caveats to using them: cost being one, battery life and some routine maintenance.
The Inogen One G3 is a portable oxygen concentrator, as long as you have a battery to run it you have oxygen.
Lover of Old Chrome Moly
Kudos on quitting smoking.
See your doctor. Supplemental oxygen is a Godsend to many people, but it is not a panacea for every problem that causes shortness of breath on exertion. Getting enough oxygen in is only part of the function of the respiratory system. The other major function is to get rid of excess CO2. You also need to make sure your circulatory system is capable of distributing that oxygen and carbon dioxide to and from the lungs and body tissues. If you have a disease, or even allergies, that affect your lungs or airway, often medication can improve function with or without supplemental oxygen. If your problem is simple deconditioning of your muscular and cardiopulmonary systems, then low oxygen may not even be the problem. I've seen many people, and have been there myself, sucking wind due to physical exertion but when you place them on a pulse oximeter (measures the % of your blood's hemoglobin that is saturated with oxygen) they are running in the high 90s to 100% despite the air hunger (healthy normal is >95%). If your hemoglobin is low, supplemental oxygen may help some, but it isn't your primary problem, and you will need to find out and correct the reason or you will continue to fatigue and feel winded easily.
Stopping smoking was a huge step
Getting more exercise is another positive change
Seeing your doctor is equally important
Supplemental oxygen systems require a prescription and you doctor will have to sign off if you expect insurance to foot any portion of the bill. You can find them from private sellers, often those who have upgraded their system or who have lost a loved one who was on supplemental oxygen, but you have no idea of the condition of the unit, if it was properly cleaned and maintained, or if you will be able to obtain supplies like filters or replacement batteries, or if you will be able to receive service for the unit.
Beware of Dr. Google. There is a lot of good medical information on the internet, but there is also a huge amount of misinformation. Be sure you get your research from reputable sources like the American Heart Association, American Lung Association, or a recognized medical entity such as Mayo or John's Hopkins. If you haven't used it before, Google Scholar is a great search engine for peer reviewed research.
