Stuck in Sweden seriously need help
Hello.
My brake disk came off and severed the cable on my haven't 1500v wheel. I replaced the whole cable but still the bike has problems. When switched on the error 7 shows on the display, indicating there is a problem with the hall sensor. I thought that replacing the cable would resolve this but didn't?
The wheel will turn when throttle is applied but only if it is moving, and then will only spin while making a clunking noise for a few seconds before it stops administering power. If you release the throttle and then repeat the process before the wheel stops it will again spin for a few seconds.
I put a video of the problem on YouTube if you search " Stuck in Sweden with broken electric bike "
I hope someone can help as I'm completely stuck in the middle of Sweden until I can find a way to get going again.
Regards and hoping for the best.
Liked 283 Times
The three motor phase wires are switching the full battery voltage across the motor while the Hall sensors are powered by only 5 volts. During the time while your brake disk was sawing thru the cable, it probably short circuited the battery voltage across one or more of the three hall sensors inside the motor casing, blowing them out.
Someone has to take off the side cover of the motor and replace the sensors. All motors are different, so maybe someone already did it on your motor and posted a youtube video.
Some questions please that may help me.
1. Are these sensors easily found and replaced?
2. What is an average estimated cost?
3. Would it be possible to use a generic sensor? Are they universal?
4. As I'm new here I'm unable to post links but did you find and watch the video I uploaded to YouTube?
I can't afford to spend money on hotels much longer while I wait for parts. The bike s a 3 wheeler and is custom made by me. It has a trailer which carries my rucksack and dog and cost around €1500 to build. Ill upload pictures if I ever get it going but time is short and I'll be devastated to have to just leave it behind.
Thanks so much for this info, I'm right on it tomorrow, please keep in touch.
Regards and thanks.
Liked 283 Times
Post 7 more times and you can do links, but no, your youtube video is impossible to find. Maybe you should include the youtube user name.
Here's one video...
Sensors look like this when not attached. Nothing special. Electrical places should carry them.
https://www.ebikes.ca/media/catalog/...hallsensor.jpg
In the above video they were on the circuit board.
Edit: Some motors have no Hall sensors. If your motor only has three heavy wires going to it, or only two heavy wires, then it doesn't use them. Motors that use Hall sensors will have 3 heavy wires and 5-6 thinner ones.
Here's one video...
Hi my YouTube name is Henryparsnip. I think the information you have given me has a good chance of resolving the issue. I've done my own research and everything seems to point in the same direction. I can't thank you enough for this. I'm back at the bike shop Monday when they reopen, they have been very helpful. Hopefully with their skill and the information you have provided I may be back on the road. From what I've learnt theses sensors can be very temprimental, fail due to excessive heat, difficult to line up in the correct place but are far more efficient than a brush motor.
Please keep in touch as I'd really like to update you, or ask for additional help in the near future.
Regards and oh so many thanks.
Liked 283 Times
Only a few uploads on youtube under that name, most of them about a spinning dog.
By the way, hope it is not the controller that failed. That could also happen of the wires crossed, but might be easier to replace.
Sorry for the delay, I'm also limited to the number of times I may post in a 24 HR period.
I'm currently at a bike shop ready to order some parts. The voltage on the battery is reading 54v. Next is to check the hall sensors. I really hope I can fix this.
After the YouTube URL add "/watch?v=IoY1z-6ebnU" without quotes and that should take you to the video. If your having trouble still then search my name again as the video was hidden but now you should see it. The spinning dog was my dog Barkley trying to get some cheese off his back
Cheers, any other thoughts after watching it? I ordered 5 hall sensors today. 3.8 - 30v ( or is it amps )I found 2 of them stuck at 3v and not resetting to zero. There was no part number on the sensor I removed leaving me to guess from the shape , size and voltage which to take. Travelled 30 km to the shop only to find they only had 1 in stock, I needed 2. Put an order in and hopefully DHL will drop them off in the morning. Fingers crossed.
Just looked on the website of the place I bought the sensors and noticed there are a few sorts.
https://www.digikey.se/product-detai...2001-ND/701356
And the other,
https://www.digikey.se/product-detail/en/honeywell-sensing-and-productivity-solutions/SS41/480-1999-ND/701354
I had no idea which to get. One is bipolar and the other is unipolar. As I don't have any part numbers or schematics m basically guessing. Sigh
And the other,
Liked 283 Times
Honeywell SS41 or SS411A per this https://endless-sphere.com/forums/viewtopic.php?t=72074
You probably ordered something like the SS411A which is a little more tolerant for the power supply voltage, 3.8-30V,
Does it matter if it's bipolar or unipolar? These befang parts had no markings on them whatsoever. I guess I'll find out today. Not looking forward to soldering these tiny things, any tips on that?
