Hat for stopping wind noise?
Quoted: 5 Post(s)
I really hate wind noise. A solution I've found is to wear a sweatshirt with the hood up and tied around my face. With this, there's a gap of air between my ears and cloth of the hood. Do the Rapha winter hat/peaked merino hat succeed in putting an end to wind noise given the cloth is in contact with the outer portion of the ear? I know of the other solutions such as wind-blox etc. but am specifically looking for a hat.
Sunshine
Quoted: 11067 Post(s)
Liked 7,634 Times
Every hat and ear cover I've used is able to reduce/eliminate wind noise, regardless of brand. There just needs to be some material over your ear.
My favorite setup is a regular cycling cap combined with an inexpensive saucony ear band. It's good breathability up top and covers my ears for warmth and windnoise reduction.
Likes For JohnJ80:
Quoted: 5234 Post(s)
Liked 3,609 Times
do you want just wind protection or also warmth?
a hoodie is not so bad
my cycling headband is good but it doesn't cover the entire ear
a knit balaclava of course does cover the entire ear
a simple knit hat can be pulled down to cover the entire ear
Quoted: 626 Post(s)
Liked 701 Times
Bikes: SL8 Pro, TCR beater
Quoted: 1027 Post(s)
Liked 595 Times
A hoodie over your head? You must overheat on long runs!
I usually put my earphones on, they help. Earplugs would also help, but be dangerous.
Liked 3,609 Times
good point, but any head covering shud be used with discretion, right? meaning, it might change while riding or come off completely. I almost always bring options w/ me. so, at the very least, I can change my head covering 1/2 way thru my ride, because whatever it is, it's usually soaked. reg. the hoodie, if I recall correctly, it went up & down during the ride depending on how I felt. I was surprised how useful it was. I recently found it after misplacing it for a cpl yrs & look forward to using it again soon. it's a super thin & cheap unit from Walmart, I think. if I could change it in any way, I'd add a zipper
Quoted: 4560 Post(s)
Liked 2,804 Times
Neoprene ear covers -- springy frame, goes behind my head, under my ponytail. Holds fine, cuts down on wind noise but it's mostly to keep my ears warm. For really cold days I wear a beanie with my size large Poc helmet. Most of my helmets are medium for warm weather.
Ditto, Cat Ears or similar.
But most wind noise comes from the helmet vents and will vary with different helmets. I have three and when I mount a video camera on the helmet each has different wind noise characteristics.
Quoted: 1638 Post(s)
Liked 741 Times
Virtually all of my wind noise is eliminated by covering my ears. Different covers for different weather conditions. Some reason in warm weather it is less annoying that in cold weather.
nine mile skid on a ten mile ride
Quoted: 18883 Post(s)
Liked 10,646 Times
Did anybody mention am indoor trainer? No? Good.
Try a Belgian style cycling cap. I have a winter cap that covers the ears and keeps me warm and quiet.
For summertime, make certain the helmet straps all fit flush to your skin. They are a great source for wind noise.
Optically Corrected
Not a hat but these work great!
Knock 30db off the "top end" and yet you can still hear the traffic around you.
